BMC B.M.C. Audio PureDAC
Post by raymond88 on Tue Jan 16, 2018 11:24 pm
Item: B.M.C. Audio PureDAC
Condition: 8.9/10. Item in excellent condition. Comes with original remote control and manual. Selling coz hardly use at all.
Price: sold
For sale here was an excellent DAC/digital preamp/headphone amp. Very well built unit, German design and engineering, with very good reviews. This unit has USB, COAX, AES/EBU and TOS inputs and can handle DSD and other hi-res audio with the USB input. It has XLR and RCA outputs for connecting to a power amp. In addition it has a reference quality balanced headphone amp.
Features:
  • Top-grade Digital/Analog Converter with Current Injection current-to-voltage (I/V) conversion
  • High-resolution asynchronous USB interface up to 32bit/384kHz
  • USB PCM: 16...32bit; 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384kHz.
  • USB DSD: DSD64, DSD128.
  • ASIO driver for Windows; Linux and Mac compatible
  • AES/EBU, coaxial and Toslink digital inputs up to 24 bit / 192kHz
  • Balanced, reference-class headphone amplifier with digital/analog power conversion (DAPC), a new super-low impedance hybrid LEF output stage, and lossless Digital Intelligent Gain Management (DIGM) volume control.
  • ¼" headphone output with separate amplification trunk.
  • Balanced LEF, CI-compatible preamp that optionally operates in B.M.C. Mode, with DIGM and a and new hybrid LEF-balanced output stage.
  • Separate volume controls for the line and headphone sections.
  • Fixed line output level operation possible.
  • Second-generation DIGM with optimized gain distribution between power amps and internal and DIGM volume levels
  • Optical B.M.C. Link for connecting with B.M.C. amps like the PureAmp
  • Remote Control
  • Top grade parts like MPP (conductive film polypropylene, non inductive) and balanced current capacitors, precision metal film resistors...
  • Massive and stylish extruded aluminum chassis
  • Dimensions: 14.37 x 4.06 x 12.91 inches, W/H/D (365 x 103 x 328 mm)
  • Weight: 11.9 lbs (5.4 kg)
Websites:
https://www.dagogo.com/b-m-c-puredac-review/
http://singaporehifi.blogspot.sg/2014/02/bmc-audio-puredac.html
https://parttimeaudiophile.com/2014/04/04/headphone-bliss-b-m-c-audio-amazes-with-puredac/
Actual Unit:
Thank you.
Number of posts : 4175
Re: BMC B.M.C. Audio PureDAC
Post by raymond88 on Tue Jan 23, 2018 5:41 pm
