Fiio E17K ALPEN 2 USB DAC Headphone Amplifier
Post by raymond88 on Wed Jan 24, 2018 7:05 pm
Item: Fiio E17K ALPEN 2 USB DAC Headphone Amplifier
Condition: 9/10. Item is in excellent condition. Comes in original box with all the accesories. Selling as the item is hardly used.
Price: RM400 or swap/topup
Product Description
The FiiO E17K is a portable headphone amplifier and digital to analog converter (DAC). The E17K has a built in rechargeable lithium battery and USB charger, allowing you to charge on your PC or with a USB adapter. The E17K has fewer buttons on the front than that of its predecessor the E17. The FiiO E17K has a new multi-functional wheel that responds to both turns and clicks, providing an intuitive agile control replacing many buttons from the older model. The all-new E17K Utilises the SA 9027 USB receiver, allowing the E17K to be used as an external sound card for your computer. This supports up to 96 kHz/32bit and supporting DSD decoding * (with ASIO driver and SACD plugin). The FiiO E17K exploits TI's all-new PCM5102, which processes higher S/N ratio, lower distortion and more linear digital-analog conversion characteristics. Also added to the new E17K is the TI's flagship OPA1622, as a low pass filter and OPA1642+LMH6643 in an OP+BUF architecture usually only seen in high end units.
Feature
USB audio decoding; can be used as external sound card
High-quality DAC and op-amp from Texas Instruments
Scroll wheel menu navigation
Coaxial digital input and dual-function line in/out port
Standard Micro USB Interface - connect with PC to make digital audio transfer possible and make battery charge possible
Brand : Fiio
Item model num : E17K
MPN(PartNumber) : E17K
EAN : 0091037936936
Product Dimensions(LxWxH) : 11x2x7cm ; 141 g
Package Dimensions(LxWxH) : 14x14x4cm ; 141 g
https://www.lazada.com.my/fiio-e17k-alpen-2-usb-dac-headphone-amplifier-121497687.html?spm=a2o4k.searchlist.list.5.5e1c3ce4ph1Tca
https://www.head-fi.org/threads/fiio-e17k-review.750264/
https://www.head-fi.org/showcase/fiio-e17k-alpen-2-usb-dac-headphone-amplifier.20540/reviews
Actual item pictures:
Number of posts : 4175
