Yamaha AVENTAGE RX-A870 7.2Ch Atmos Network AV Receiver
Post by stylelaser.com.my on Sat Jan 27, 2018 4:34 pm
Yamaha AVENTAGE RX-A870 7.2Ch Atmos Network AV Receiver BRAND NEW, NOW SELLING AT RM3999.
FREE SHIPPING WITHIN WEST MALAYSIA.
This 7.2-channel AVENTAGE network AV receiver features Dolby Atmos® and DTS:X™ for surround sound realism. With the latest in HDMI® technologies, experience movies in stunning 4K Ultra HD and high dynamic range (HDR). In addition, Dolby Vision™ and Hybrid Log-Gamma compatibility provide incredible contrast, smooth tone and rich, bright colors. The free MusicCast app makes it easy to access your music library and streaming music services. Add audio in up to 9 additional rooms with MusicCast wireless speakers or other MusicCast devices. Connect wirelessly via Wi-Fi®, Bluetooth® and AirPlay®. Additionally, a phono input for vinyl playback, Zone B HDMI out and added Zone 2 control options provide added system versatility.
  • The AVENTAGE Advantage: Designed to deliver the highest levels of audio performance through engineering
  • Aluminum front panel with door and Anti-Resonance Technology (A.R.T.) Wedge
  • 7.2-channel Dolby Atmos®️ and DTS:X™️ (5.1.2-ch)
  • 9 speaker terminals with Intelligent Amp Assign for Zone 2
  • Add audio in up to 9 additional rooms with MusicCast
  • 8-in, 2-out HDMI
  • 4K Ultra HD pass-through with HDCP 2.2 support, HDR Video including Dolby Vision and Hybrid Log-Gamma, and BT .2020
  • Zone B HDMI out
  • Fully loaded with Wi-Fi®️, Bluetooth®️, AirPlay®️, Spotify Connect, TIDAL, and Deezer music streaming service
  • Stream Pandora®️, Spotify, Napster, SiriusXM Internet Radio and thousands of free internet radio stations
  • DSD 2.8 MHz / 5.6 MHz, FLAC / WAV / AIFF 192 kHz / 24-bit, Apple®️ Lossless 96 kHz / 24-bit playback
  • Phono input to connect to your favorite turntable
  • Room acoustics optimization using YPAO™️ - R.S.C. with multipoint measurement
  • Zone 2 control options
Craftsmanship in engineering design. The AVENTAGE line of high-performance AV receivers is based on the audio design concept of providing a massive, full-bodied sound for movie sound effects and the accurate reproduction of music sources. By expertly harmonizing traditional and advanced technologies, every factor that affects sound quality, from materials and parts to construction, layout, vibration damping (unique foot) and “fine-tuning” the sound, is handled with no other thought than to achieve the best possible audio quality. As a result, every AVENTAGE model has the ability to reproduce the most subtle details of high-definition sound, so that listeners can enjoy a truly high-class sound studio experience at home.
Total Purity
Enjoy fine sound quality. The Total Purity Concept, which Yamaha has been cultivating for many years, encompasses high drive amp technology, high purity preamplification, anti-vibration technology and independent pure power supplies. All models have fully discrete power amplifiers that help minimize distortion. They also adopt pure independent power supplies, allowing dedicated power supplies for the analog and digital circuitry to prevent digital noise from affecting analog circuitry. The anti-vibration heat sinks are designed to suppress vibration from transistors and sound pressure. Independent power supplies for the DACs are designed to further eliminate noise on certain models. Down to every detail, these AV receivers are designed with full emphasis on the highest possible sound quality.
High Quality Parts for Optimum Performance
The whole is greater than the sum. Every single part in an AV receiver affects the sound quality. For AVENTAGE models, extra time is taken to find (or develop) the exact parts needed to achieve the highest performance possible. Sound technicians go through a testing process to, in effect, “tune” the receiver’s sound.
Anti-Resonance Technology Foundation
A firm foundation. The Anti-Resonance Technology Wedge is a fifth foot in the center of the unit. It dampens vibrations from the power transformer, power transistors and heat sinks, as well as vibrations that might be caused by the sound from the speakers.
Advanced Design Feet
Foot fetish. The feet of the receiver feature a newly designed, high-density structure which utilizes two different kinds of interior ribs — straight and curved — to enhance strength and damping performance. Installation stability is improved and chassis resonance is dispersed, effectively eliminating external vibration. The low-range response is enhanced, while resonance peaks in the mid- and high-range are reduced, providing dynamic sound and accurate reproduction.
Aluminum Front Panel
Shielded from noise. All of the AVENTAGE components feature the same sleek, clean design, with an elegant aluminum front panel and silky touch volume/selector knobs. The aluminum front panel is used to effectively shield sensitive circuitry from external noise and electronic radiation generated by dimmer switches, fluorescent lighting, video monitors and so on. This ensures optimum sonic performance in the widest range of installation environments.
Advanced Graphical User Interface
Multilingual user interface. The latest graphical user interface from Yamaha has a high-resolution display with clear, easy-to-use menus and also includes a selectable status bar that shows input source, volume level, DSP mode and audio format. The GUI provides a choice of eight languages: English, French, German, Spanish, Italian, Russian, Japanese and Chinese and can be displayed over both normal and 3D pictures.
MusicCast
Access all of your music with a simple app and wirelessly stream it throughout your home using your existing Wi-Fi network.
  • Stream it all. Listen to Pandora®️, Spotify, Napster, SiriusXM Internet Radio, TIDAL, Deezer, thousands of free internet radio stations and the music stored on your smart devices and computers.
  • Wireless connectivity. All MusicCast products are fully loaded with Wi-Fi, Bluetooth and AirPlay®️.
  • Expand to a whole home audio experience. When you’re ready, add MusicCast wireless speakers, sound bars or other devices in up to 9 other rooms and listen throughout your home.
  • No wires, easy installation. By using MusicCast, you don't need to fuss with placing wires through walls into other rooms.
Bluetooth®
Play your favorite streaming service. This AV receiver is equipped with Bluetooth functionality to let you enjoy easy wireless music playback from mobile devices. The Compressed Music Enhancer from Yamaha is now optimized for Bluetooth audio transmissions to ensure that your music will have vivid, lively sound quality during wireless playback.
Bluetooth Output
In and out. The RX-A870 is equipped with the latest Bluetooth technology, making wireless operation more convenient than ever. You can stream music from the RX-A870 to Bluetooth headphones for private listening or to Bluetooth speakers.
Airplay®
iCompatible. This AV receiver supports AirPlay, which means they can accept wireless music streaming from iPod touch®, iPhone®, iPad®, as well as from iTunes® on a Mac® or PC. This makes it easy to enjoy music from your mobile devices or computer at your home theater system. You can view metadata such as song title, artist name as well as album art inside the receiver's on-screen display.
Network Functions
Access more. This AV receiver provides a variety of network functions that enable you to access more sources and also enhance operation. You can connect the receiver to your home network or internet to enjoy Internet Radio, Spotify®*, Pandora®* or music stored on a NAS and home PC. The AV Controller app (from iTunes App Store or Google play) lets you control various functions from your iPod, iPhone, iPad or Android phones / tablets.
Find every dimension. Enter a new world of sound with Dolby Atmos and DTS:X. These sound technologies transport you from an ordinary moment into an extraordinary experience with captivating, multidimensional sound that fills your room with amazing richness and depth. Music, people, and objects come alive in breathtaking detail and flow in precise choreography all around you, making you feel like you are truly there. These new sound technologies will fill the room with multidimensional sound that makes you feel as if you are right in the middle of the story unfolding on the screen.
Enhanced CINEMA DSP HD3
Thrilling realism in surround sound. With this year marking thirty years since the release of the first DSP-1 unit in 1986, Yamaha has continued its history of innovation with the development of the Enhanced next-generation CINEMA DSP. This sound field program is installed in the receiver and features a new sound field processing algorithm that further elevates its ability to process the motion and spatial representation data found in the latest audio-visual media. This includes three-dimensional surround formats like Dolby Atmos and DTS:X. The result is a natural sound field effect that follows every sound source, including objects present in the most modern formats and delivers dynamic sensations of motion and spatiality.
Yamaha Eco-Product
With an advanced energy saving design, this AV receiver achieves a low power consumption of not more than two watts when in Network Standby mode.
Please visit our website to find out more products for sale at very special price..
www.stylelaser.com.my
Chris  012-2309169
Fong   016-3098668
BRANDED led tv
amplifier
speaker
cd player
SPECIFICATIONS
Amplifier
  • Channels: 7.2
  • Rated output power (1kHz, 2ch driven): 110W (8 ohms, 0.9% THD)
  • Rated output power (20Hz - 20kHz, 2ch driven): 100W (1kHz, 8 ohms, 0.06% THD)
  • Maximum effective output power (1kHz, 1ch driven) (JEITA): 160W (6 ohms, 10% THD)
  • Dynamic power per channel (8/6/4/2 ohms): 130/170/195/240W
Surround Sound Processing
  • Cinema DSP: Yes (3D)
  • DSP programs: 17
  • Dialog level adjustment: Yes
  • Virtual presence speaker: Yes
  • Virtual surround back speaker: Yes
  • Dialogue lift: Yes
  • Silent Cinema/Virtual Cinema DSP: Yes (Virtual Cinema Front)
  • Dolby Atmos: Yes
  • Dolby TrueHD: Yes
  • Dolby Digital Plus: Yes
  • Dolby Surround: Yes
  • DTS:X: Yes
  • DTS-HD Master Audio: Yes
 Audio
  • Compressed music enhancer: Yes (including enhancer for Bluetooth)
  • Pure Direct: Yes (with voice on mode)
  • YPAO sound optimization: Yes
  • Adaptive DRC (Dynamic Range Control): Yes
  • Initial volume & maximum volume setting: Yes
  • YPAO volume: Yes
  • A.R.T. wedge: Yes
  • Bi-amp capability: Yes
  • Audio delay: Yes (0 - 500ms)
  • 192kHz/24-bit DACs for all channels: Yes (Burr-Brown)
Video
  • 4K Ultra HD passthrough and upscaling: Yes (4K/60p, 4:4:4)
  • HDMI 3D passthrough: Yes
  • HDMI audio return channel: Yes
  • HDMI upscaling: Yes (HDMI to HDMI)
  • Deep Color/x.v.Color/24Hz Refresh Rate/Auto Lip-Sync: Yes
Extensive Connection
  • HDMI input/output: 8/2 (HDCP 2.2, HDR 10/Dolby Vision/HLG and BT.2020 compatible)
  • HDMI CEC: Yes
  • USB input: USB memory, portable audio player
  • Network port: Yes
  • Front AV input: USB/mini-jack
  • Digital audio input/output (optical): 2/0
  • Digital audio input/output (coaxial): 2/0
  • Analog audio input/output: 5 (front 1)/0
  • Composite video input/output: 1/0
  • Preout: Preout 7.2 channel
  • Phono input: Yes
  • Component video input/output: 1/0
  • Headphone output: 1
Connectivity
  • Wi-Fi: Yes (with Wireless Direct)
  • AirPlay: Yes
  • Bluetooth: Yes (SBC/AAC)
Tuner
  • FM/AM tuner: Yes
User Interface
  • On-screen display: Yes (color OSD)
  • SCENE: SCENE (4 sets)
  • App control: Yes (iPhone, iPad, Android phone/tablet)
  • Remote control unit: Yes
  • Web browser control: Yes
Zone Control
  • Zone B output: Yes (HDMI)
  • Zone 2 audio output: Pre out
  • Powered zone: Zone 2
  • +12V trigger output: 1
  • RS-232C interface: Yes
  • Remote (IR) input/output: 1/1
  • Party mode: Yes
  • Zone HDMI: Yes (Zone B)
General
  • Standby power consumption (IR only): ≤0.1W
  • Auto power standby: Yes
  • ECO mode: Yes
  • Dimensions (W x H x D): 17 1/8" x 6 3/4" x 15"
  • Weight: 23.1 lbs.
Number of posts : 191
