Rotel Stereo control Pre amp RC-971(used)
Post by pleong on Mon Jan 29, 2018 2:59 pm
https://servimg.com/view/19849789/32
This is an excellent sounding stereo pre-amplifier made by Rotel model RC-971. The pre amp has excellent sound quality and the cosmetic condition is nearly mark free. The pre amp is fully operational with no audible defects. The pre amp has inputs for CD, Tuner, Aux, Tape 1 & Tape 2. There are 2 outputs for 2 power amplifier connections.
Here is an excellent sounding stereo pre-amplifier made by Rotel model RC-971. This preamp is in outstanding cosmetic condition which is nearly mark free. The pre amp was made in the early 2000's and is simple and elegant.
The pre amp has inputs for CD, Tuner, Aux, Tape 1 & Tape 2. There are 2 outputs for 2 power amplifier connections and twin AC power outlets. Note: there is no on board phono circuit. If you need this ability you will have to connect a separate phono preamp to the Aux input.
The pre amp has excellent sound quality and the cosmetic condition is nearly mark free. The pre amp is fully operational with no audible defects. Shipped insured and professionally packaged. You are guaranteed It sounds superbly clean and sharp. Using this incredible pre-amp the cleanness of the sound is razor sharp. the sound is perfect and each instrument is positioned in a well defined place. I have been using this pre amp to driveĀ  Parasound 1200II (200W) power and QUAD 405 power amp and driving ATC speaker. It sound very good and matching .
Frequency response: 4Hz to 100kHz
Total harmonic distortion: 0.004%
Input sensitivity: 150mV (line)
Signal to noise ratio: 95dB (line)
Output: 1V (Pre out)
Output Sensitivity / Impedance= 1 V/100 Ohm
Frequency Response= 4 - 100.000 Hz, + 0 dB, - 3 dB
Tone Controls= 6 dB bei 100 Hz und 10 kHz
Power Requirements= 230 V Ac 50hz
Power Consumption= 10 Watt
Dimensions: 440 x 72 x 286mm
Weight: 3kg (COD in pj only)
price RM=1100/=
phone :0123889665
Last edited by pleong on Mon Jan 29, 2018 5:04 pm; edited 2 times in total (Reason for editing : learning to use the features!! sorry)
pleong
Number of posts : 9
Registration date : 2018-01-29
Re: Rotel Stereo control Pre amp RC-971(used)
Post by pleong on Mon Mar 19, 2018 9:00 am
test
pleong
Number of posts : 9
