NAD 302 Stereo Intergrated Amplifier
Post by HiFiLab on Thu Feb 01, 2018 4:25 pm
Description
The NAD 302 is an integrated amplifier. This 2-channel model is fitted with Phono MM/MC inputs. Furthermore, the stereo amplifier is integrated with preamp output and features LED indicators.
Because our engineers put sound quality first, the budget NAD 302 was voted European Amplifier of the Year 1993 - 94 and also a HiFi Choice ‘Best Buy’.
The 302 is modestly rated at 25 watts per channel into 8 ohms, but effortlessly handles peaks of 75 watts.
Tone Defeat allows you to switch out the tone control circuitry for a more direct signal path.
Important fine detailing like the low noise phono pre-amp, separate pre and power amplifier sections (for future upgrading) and heavy duty loudspeaker binding posts all add up to make a fine sounding, easy to use and hugely successful amplifier.
Power output: 25 watts per channel into 8Ω (stereo)
Total harmonic distortion: 0.03%
Damping factor: 60
Input sensitivity: 2.7mV (MM), 165mV (line)
Signal to noise ratio: 77dB (MM), 90dB (line)
Dimensions: 420 x 108 x 320mm
Weight: 6kg
Price : RM 580
HiFiLab
Number of posts : 2179
