MS HD POWER S20 V2 Silver 6 Ways UK Filter Sockets with Surge Protection
Post by aaronosk on Fri Feb 02, 2018 7:27 pm
RM700
Pls call or msg Aaron 0124549051
Features
6 Ways BS-1363 13A Socket with Master ON/OFF Switch
PRRT Noise Filtration Network using Selected Components
Excellent EMI and RFI Suppression to Improve Audio and Visual Performance
48,000 Amp. Surge Suppression Protect Hi Fi / AV Appliances
High Spring Rate Phosphor Bronze Sockets Clips Pass the BS Standard 30,000 times plug IN / OUT test
3.0 µm Pure 925 Silver Plating to All Power Clips
5 mm² Power Transmission Bus Bars with Pure Silver plating on High Current Flow
Original 3 Cores 6N OFC Double Screened Extension Cord
Moulded-on Type Power Plug with 3.0 µm Pure 925 Silver Plated Pins
High Spring Rate Phosphor Bronze Fuse Clamps with 3.0 µm Pure 925 Silver Plating
Chassis Made of USA V-0 Grade Nonflammable Materials
Fitted with BS-1362 Silver 13A Fuese
Full Life-Time Warranty
Number of outlets: 6
Type of outlets available: UK conform to BS1363
Length of extension cord: 2 Meter conform to VDE standards
Inlet plug: UK - conform to BS1363; fused and unswitched
Fuse: 13A BS-1362 Silver Fuse fitted at plug
13A BS-1362 Silver Fuse fitted at strip
Main Switch: Yes. Fitted at strip
Mains Voltage : 200 - 240 VAC / 50~60Hz
Max. Current : 13 Amp.
Max. Wattage : 3,000 Watt (230V)
Dimensions : 60mm x 402mm x 30mm (W x L x H)
Net Weight: 0.8 KG (net)
Last edited by aaronosk on Mon Jun 25, 2018 6:30 am; edited 1 time in total (Reason for editing : sold)
aaronosk
Number of posts : 2
Registration date : 2018-02-02
