Custom Print Acoustic Panel Echo Noise Reduction *Any Size Can Be Made
Hi up for sale is custom prints acoustic panels. If you are facing echo noise issue in your listening room and want a unique solution to it, I offer you this solution.
Links to my recent work picture: https://goo.gl/7eSznC
Common dimension available:
- 24 inch x 24 inch (album art)
- 24 inch x 48 inch
- 32 inch x 48 inch (movie poster)
Thickness: 50mm approx.
Material option:
a) Mineral Wool at selected density
b) Polyester Acoustic Materials
Price: from RM 180/ pcs (depending on material option/ artwork needed/ dimension) drop me a message informing me the requirement you need, I will make an estimation for you fully custom made to your needs.
*If you want to test, I have sample panels for you to test (deposit required & refundable), panel can be collected from Butterworth (or packaging & postage cost at buyer's expenses)
Whatsapp: www.wasap.my/601111663838
- 24 inch x 48 inch
Material option:
eddiemooncake- Frequent Contributor
- Number of posts : 252
Registration date : 2011-12-23
» [SOLD] Custom Size Sound Absorbing Panel (Bundle 6 pieces)
» SAE 5000 Phono Noise Reduction System
» acoustic form & acoustic panel (rockwool)
» Goldring - NS 1000 Noise Reduction Headphone (New)
» Custom-made speaker stands; 100% made from marble
