Oppo HA-1 (Headphone Amplifier, DAC & Pre-Amplifier)
Stereo Pre-Amplifier with Home Theater Bypass
Discrete Class A Balanced Headphone Amplifier, Asynchronous USB DAC Up to 384 kHz and DSD256, Stereo Pre-Amplifier with Home Theater Bypass
The HA-1 doubles as a high fidelity stereo pre-amplifier with both RCA and XLR output ports. A special "Home Theater Bypass" mode can be assigned to any input source, making it very easy to integrate the HA-1 as a stereo pre-amplifier into a home theater sound system.
SPECIFICATIONS
DAC Performance Specifications
Pre-amplifier Performance Specifications
Headphone Amplifier Performance Specifications
Selling for RM 3,900.00 (negotiable for serious buyer) Please contact 012-3090744 (Subra) to deal. This unit is not meant for low ballers.
Following is the photos of the actual unit. No box but comes with complete and full accessories. Remote is wrapped with removable plastic for protection.
SPECIFICATIONS
General | |
Dimensions (W x H x D) | 10.0 x 3.6 x 13.1 inches, 254 x 91 x 333 mm |
Mass | 13.0 lbs, 5.9 kg |
Power Supply | AC 110-120 V~ / 220-240 V~, 50/60 Hz auto-sensing |
Power Consumption | 70 W (operation), 0.5 W (standby) |
Trigger Input | 3.5 V – 15 V, 10mA minimum |
Trigger Output | 12 V, 100 mA maximum |
Operating Temperature | 41 °F - 95 °F, 5 °C - 35 °C |
Operating Humidity | 15% - 75% No condensation |
Recommended Headphone Impedance | 32 ohm – 600 ohm |
Balanced Headphone Jack Output (XLR-4) Pin order | 1: L+, 2: L-, 3: R+, 4: R-, Shell: GND |
6.35 mm Headphone Jack Output Pin order | Tip: L, Ring: R, Sleeve: GND |
XLR Balanced Audio Input | |
Input Impedance | 15k ohm |
Maximum Input Level | 18 Vrms, +27.3 dBu (0 dBu = 0.775 Vrms) |
RCA Stereo Audio Input | |
Input Impedance | 10k ohm |
Maximum Input Level | 9 Vrms, +21.3 dBu (0 dBu = 0.775 Vrms) |
Coaxial, Optical, AES/EBU Digital Inputs | |
Input Format | Stereo PCM |
Sampling Frequencies | 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz |
Word Length | 16-bit, 24-bit |
USB DAC Audio Input (USB B Type) | |
Input Format | Stereo PCM, Stereo DSD (DoP v1.1 or native) |
PCM Sampling Frequencies | 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz, 352.8 kHz, 384 kHz |
PCM Word Length | 16-bit, 24-bit, 32-bit |
DSD Sampling Frequencies | 2.8224 MHz (DSD64), 5.6448 MHz (DSD128), 11.2896 MHz (DSD256, native mode only) |
Profile | USB 2.0, USB Audio 2.0 |
Mobile USB Audio Input (USB A Type) | |
PCM Sampling Frequencies | 44.1 kHz, 48 kHz |
VBUS Power Output | +5 V, 2.1 A |
Bluetooth Audio Input | |
Standard | Bluetooth 2.1+EDR |
Profile | iAP, SPP, AVRCP, A2DP |
Audio Transmission Format | SBC, aptX |
Specification | XLR Output | RCA Output |
Output Level | 4.6 ± 0.3 Vrms | 2.3 ± 0.3 Vrms |
Frequency Response (Tested with -10 dBFS / 384 kHz) | 10 Hz – 170 kHz (+0/-3 dB) 20 Hz – 20 kHz (+0/-0.07 dB) | 10 Hz – 170 kHz (+0/-3 dB) 20 Hz – 20 kHz (+0/-0.07 dB) |
THD+N at 1 kHz (A Weight, 20 Hz – 20 kHz) | < 0.00056% (< -105 dB) | < 0.00056% (< -105 dB) |
Channel Separation | > 105 dB | > 105 dB |
Signal-to-Noise Ratio (A Weight, 20 Hz – 20 kHz) | > 115 dB | > 113 dB |
Dynamic Range (1 kHz -60 dBFS, A Weight, 20 Hz – 20 kHz) | > 115 dB |
Specification | XLR Input – XLR Output | RCA Input – RCA Output |
Rated Output Level | 4.6 Vrms | 2.3 Vrms |
Frequency Response | 10 Hz – 200 kHz (+0/-2 dB) 20 Hz – 20 kHz (+0/-0.04 dB) | 10 Hz – 200 kHz (+0/-2 dB) 20 Hz – 20 kHz (+0/-0.04 dB) |
THD+N at 1 kHz (A Weight, 20 Hz – 20 kHz) | < 0.00056% (< -105 dB) | < 0.00071% (< -103 dB) |
Channel Separation | > 120 dB | > 110 dB |
Signal-to-Noise Ratio (A Weight, 20 Hz – 20 kHz) | > 110 dB | > 105 dB |
Dynamic Range (1 kHz -60 dB, A Weight, 20 Hz – 20 kHz) | > 120 dB | > 115 dB |
Maximum Gain (100 mVrms input) | 6 dB | 6 |
Specification | Condition | XLR Input - Balanced Output | RCA Input - 6.35 mm Output |
Maximum Output Power (Per Channel) | Into 600 Ohm | 2400 mW | 600 mW |
Into 32 Ohm | 3000 mW | 3500 mW | |
Rated Output Power (Per Channel) | Into 600 Ohm | 800 mW | 200 mW |
Into 32 Ohm | 2000 mW | 500 mW | |
Frequency Response | 10 Hz – 200 kHz (+0/-1 dB) 20 Hz – 20 kHz (+0/-0.04 dB) | 10 Hz – 200 kHz (+0/-1 dB) 20 Hz – 20 kHz (+0/-0.04 dB) | |
THD+N at 1k Hz (A Weight, 20 Hz – 20 kHz) | Rated Power | < 0.0018% (< -95 dB) | < 0.0056% (< -85 dB) |
50 mW | < 0.001% (< -100 dB) | < 0.0022% (< -93dB) | |
Channel Separation | > 120 dB | > 90 dB | |
Signal-to-Noise Ratio (A Weight, 20 Hz – 20 kHz) | > 111 dB | > 111 dB | |
Dynamic Range (1 kHz -60 dB, A Weight, 20 Hz – 20 kHz) | > 120 dB | > 115 dB | |
Output Impedance | 0.5 Ohm |
subval999- New Member
- Number of posts : 10
Registration date : 2012-12-05
» Oppo HA-1 (Headphone Amplifier, DAC & Pre-Amplifier)
» Lightly Used Oppo HA-1 (Headphone Amplifier, DAC & Pre-Amplifier)
» SOLD Oppo HA-1 Headphone Amplifier, DAC & Pre-Amplifier
» Oppo Headphone Amplifier HA-1
