Pro-Ject RPM 6.1 turntable + Projjet Connect it Phono cable + Rega Bias 2 Cartridge- sold
Post by vintageguys on Wed Mar 28, 2018 6:18 am
With Pro-Ject RPM 6.1 SB the mass principle with its advantages in optimising resonance was established at a remarkable price. A heavy weight platter made from MDF and covered with a vinyl mat is utilized. The design of the chassis is more radical and compacted, comparded to RPM5. Ceramic main bearing and acrylic sub-platter add up to a resonance-free combination. Special Sorbothane®️ feet are used for effi cient decoupling of the whole system.
Manual turntable with electronic Speed selection
Turntable
• Massive 4.25 kg MDF platter with vinyl playing surface and brass record puck
• Acryl-subplatter
• Inverted main bearing Type 1with ceramic thrust-pad
• Central metal block optimizes centre of gravity
• Motor decoupled by 4 point suspension to reduce vibration
• Integrated Speed Box allows electronically switchable speed between 33 and 45 Upm
• 78 Upm speed switchable
• Height adjustable Sorbothane®️-damped aluminum cones
• Gold-plated RCA phono sockets
Tonearm 9c
• 9" Carbon fibre tone-arm with aluminum headshell
• Conical armtube avoids standing wave refl ections
• Inverted bearing design with four hardened ABEC7 spec ballraces
• Solid armbase permits accurate height adjustment of armtube and VTA (vertical tracing angle)
• Single-screw fixing of armtube allows rotation for easy adjustment of needle azimuth despite fixed headshell
• Highly flexible top-grade copper internal wiring
• Silicon damped tone-armlift
• Resonance optimized counterweight construction
Selling together with Pro-ject connect it phono cable 1.2m , also came with Rega Bias 2 Cartridge (seldom use) the turntable completely with original box .
Asking : sold
Please contact / whatsapp +60 16 800 8896 Mr Tan for more info
Thank You
GOOD LUCK!
vintageguys
vintageguys
Number of posts : 635
Amplification: WESTERN ELECTRIC 91B MONO POWER AMP
Speakers: WESTERN ELECTRIC 753C / Altec A800 1946 c/w Wings +420A 15' Fullranged Speakers
http://myvintage-world.blogspot.com
