Marantz PM-75
Marantz PM-75
Post by jbashok on Fri Apr 06, 2018 10:46 pm
Marantz PM-75
RM1,750
Ipoh, Perak
Power output: 100 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 150kHz
Total harmonic distortion: 0.008%
Input sensitivity: 0.25mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 72dB (MC), 83dB (MM), 105dB (line)
Digital inputs: coaxial, optical
Dimensions: 454 x 151 x 379mm
Weight: 16.8kg
Accessories: remote control
Year: 1989
Marantz PM-75
Description
The Integrated Amplifier which carries a digital analog converter.
A version LSI (TDA1541A) which Philips is proud of is adopted as a digital analog converter, and the digital signal is made to link to a highly precise analog circuit.
Thorough serious consideration of the S/N was carried out at the volume part, and the 4-unit master volume is adopted.
Moreover, the final stage of an amplifier part has adopted the three-step Darlington parallel push pull.
A large-sized transformer and capacitor are carried in the power-source part.
In order to prevent the wraparound of a digital noise, the D/A independent-source circuitry is adopted, and the analog system serves as a high stable high speed power source which made full use of high-integrated IC of a low-noise wide band.
The side panel of die-casting is adopted as a sub-.
Furthermore, die-casting framing which eliminated the ill effect of the oscillation is adopted, and the fine oscillation of the circuit board is also effectively controlled by the newly developed vibration suppression substrate material.
Digital one corresponds to three optical 1 coaxials, and the input unit supports all sampling-frequency 32/44.1/48kHz signals.
Moreover, the analog input serves as a design corresponding to the multi-source having those with seven line, and a Phono equalizer (MC, man month). The tapes circuitries are two analogs which can do mutual dubbing freely.
A tone control circuit is the shelving type which set center frequency as 60Hz and 15kHz, is suppressing an elevation of an unnecessary band, and it is considered so that a distorted incrementation and inflow of a noise may be prevented.
The Source-Direct functionality is carried, each stage to flat amplifier is jumped, and not only the output of a digital analog converter but analog output can be directly linked with a master volume.
The Jitter absorbing circuit is carried so that the fluctuation of the optical digital signal by oscillation of an optical cable etc. (Jitter) may be rectified.
The remote control which summarized the functionality compactly is equipped standard.
http://audio-database.com/MARANTZ/amp/pm-75-e.html
Amp with original remote REMOTE
Whats app--- 0143413655-----
jbashok
Number of posts : 452
Re: Marantz PM-75
Post by jbashok on Tue Apr 17, 2018 12:42 pm
jbashok
