ART USB Phono Plus
ART USB Phono Plus
The USB Phono Plus is the ideal solution for transferring any highly prized vinyl collection to your computer or laptop. It is also the ideal high performance audio interface between analog and digital sources. Built in low-noise RIAA phono pre-amp circuit with low cut filters (to remove rumble and noise) guarantee pristine audio capture.
Front mounted gain control and Signal/Clip LED allows easy optimization of a wide range of analog input sources. The USB Monitor/headphone provides zero latency monitoring of the input source for easy cueing. The USB PhonoPlusPS can also act as audio playback source for any USB equipped computer or laptop. Optical TOSLINK Input and Output as well as an S/PDIF Input make the USB PhonoPlusPS an ideal analog / digital audio to USB interface as well.
The built-in low noise Phono Preamp circuit is highly accurate and precisely conforms to the RIAA standard. The Line Out jacks are always connected to the input preamp signal for source monitoring or to allow use as a stand-alone phono preamp.
Housed in an all aluminum black anodized case, the USB PhonoPlusPS can be powered by either external power supply or directly via USB port. To ensure maximum versatility, the USB PhonoPlusPS is fully compliant with the USB 2.0 specification and uses USB adaptive mode for playback and USB asynchronous mode for record. It will work with Windows 98SE/ME/2000/XP/Vista/7 USB audio device drivers as well as Apple OS9.1/OS-X computers with native USB support.
Contact : 016 206 8974
Price: RM490
Item condition: Brand new in box
Price: RM490
Black Octagon- Club Member
- Number of posts : 38
Registration date : 2012-12-13
» Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp
» Cyrus Phono Signature Phono Stage Made In England
» Clearaudio Smart Phono V2 Phono Stage (Made In Germany)
» Clearaudio nano phono V2, phono stage (SOLD)
» Bel Canto Phono 1 / Clear Audio Basic Phono (used)
