QUAD 909 Power Amplifier
Post by jbashok on Fri Apr 13, 2018 10:01 pm
Description
The Quad 909 is a two channel power amplifier using current dumping technology.
It weighs approximately 14kg and is built to be robust.
The performance of the 909 amplifier is as accurate as it is possible to achieve by careful design, selection of components and rigorous test procedures.
The unit has no controls other than a power switch (which is normally left on) and may be mounted out of sight in a cabinet or other convenient location.
To keep BUS connections simple you can place the unit below the 99 preamplifier.
Power amplifiers can be placed alongside or out of sight using a long 99 AMPBUS cable.
The amplifier is full compatible with the ESL-63, ESL-988 and ESL-989 loudspeakers but it should not be used with the earlier model ESL which could be damaged by signal peaks unless a protection circuit is fitted in the loudspeaker.
Power output: 140 watts per channel into 8Ω (stereo)
Frequency response: 13Hz to 40kHz
Total harmonic distortion: 0.01%
Input sensitivity: 0.775V
Signal to noise ratio: 108dB
Dimensions: 321 x 140 x 240mm
Weight: 14kg
good condition never repair or service b4 . unscrewed.
view n demo to belive
see my other post QUAD 99 CDP-2 also available for sale.
price rm 2780
WHATSAPP--- 0143413655--- ipoh.
jbashok
Number of posts : 719
Re: QUAD 909 Power Amplifier
Post by jbashok on Sat Apr 21, 2018 1:03 pm
jbashok
Post by jbashok on Mon Apr 30, 2018 9:20 pm
QUAD CDP-2 n quad 909  AMP combo price rm 5K
jbashok
Post by jbashok on Wed May 09, 2018 3:55 pm
jbashok
Post by jbashok on Sat May 19, 2018 7:35 pm
UP
jbashok
Post by jbashok on Mon May 28, 2018 12:29 am
UP
jbashok
Post by jbashok on Fri Jun 08, 2018 11:07 pm
UP
jbashok
