( SOLD)Rotel RQ-970BX Moving-Magnet/Coil Phono Pre-Amplifier
Post by jbashok on Sun Apr 15, 2018 12:57 pm
Rotel RQ-970BX Moving-Magnet/Coil Phono Pre-Amplifier(EQUALIZER)
RM SOLD
Ipoh, Perak
Rotel RQ-970BX
description
With the increased use of digitally based audio media, many modern high performance audio components lack the circuitry needed to handle the signals produced by phono systems.
The RQ-970BX is a high-performance phono equaliser, the output of which can be plugged straight into any line level input.
Using the same sophisticated circuit designs and high quality components that have made Rotel a world-wide standard of performance, the type of design used in the RQ-970BX is expensive to manufacture, but it is better for the music.
Total harmonic distortion: <0.004%
Intermodulation distortion: <0.004%
Input sensitivity: 210uV/100ohm (MC), 2.5mV/47kohm (MM)
Phono overload: 16mV (MC), 160mV (MM)
Output sensitivity: 150mV/100ohm
Frequency response: 20 to 20,000Hz
Signal to noise ratio: 70dB (MC), 75dB (MM)
Dimensions: 440 x 72 x 195mm
Weight: 3.1kg
Review
it's a no brainer for someone with a modest vinyl system who wants to keep it that way, financially speaking.
[Apr 06, 2002]
royphil345
Audio Enthusiast
STRENGTH: GREAT SOUND!!! RUNS SUPER QUIET!!
WEAKNESS: HARD TO GET
i don''t see how you could go wrong here!!! Has better power supply, More advanced RIAA EQ, better design than anything else in the price range. Parts are high quality. Will run SUPER QUIET with a moving magnet or even a moving coil!!! To me, it just sounds "right". Not too bright, not too dark. EXCELLENT rhythm and pace. Maybe not as extended or effortless as the super high priced stuff. But, overall VERY smooth sounding. I''m using it with a Rotel RP-955 turntable, and an Audio Technica AT 440ML. Sounds GREAT for a MM setup, of course, now I''m getting tempted to try a moving coil for that little extra helping of extension and dynamics.(never had a phono pre that would handle MC before) It''s one of the few audio purchases I''ve made that I''m COMPLETELY satisfied with. No regrets at all!! (so I had to write a review) Only drawback is that not many stores that carry Rotel keep the phono pre in stock. And Rotel seems to be super careful about not having their stuff sold on the web. I just went to the Rotel web site, found my nearest dealer and had them order it for me. It took about three weeks for it to come in, but it was WELL WORTH the wait!!! Obviously, I HIGHLY recommend this unit. Don''t settle for less just because this is a little harder to get!!!
WORKING EXCELENT
COSMETIC MINT LIKE NEW
whatsapp ----0143413655---- ipoh
Last edited by jbashok on Sun Apr 15, 2018 1:52 pm; edited 1 time in total (Reason for editing : SOLD OUT)
jbashok
Number of posts : 1428
