Krell KRC-2 Full Balanced "CLASS A" Pre-amplifier
Post by Azlan on Thu Apr 26, 2018 11:43 am
The KRC-2 is described by Krell as being fully balanced internally.
All input and output terminals are gold-plated; the phono sockets are high-grade solid machined types with a PTFE dielectric.
The KRC-2's single-ended inputs are labeled S-1 to S-4, with one nominated for the auxiliary analog disc input. B-1 and B-2 are the two balanced inputs.
For the tape monitor, an additional "S" input may be used as an auxiliary input if no tape system is in use. (The tape output is buffered to prevent interaction with the main signal path.) The remote preamp controls are replicated in pushbuttons on the KRC-2's handsome, brushed-alloy fascia.
Description: Solid-state line-level preamplifier.
Frequency response: 0.2Hz–400kHz +0, –—dB.
Distortion: lower than 0.002%, –94dB, 20Hz–20kHz
Letting go of this gem at RM5.1k.
If you are genuinely interested, kindly whatsapp/contact me at 019-3464456.
Azlan
Number of posts : 292
Registration date : 2018-02-12
Re: Krell KRC-2 Full Balanced "CLASS A" Pre-amplifier
Post by Azlan on Thu May 03, 2018 11:39 am
Available.tq
Azlan
Post by Azlan on Fri May 11, 2018 3:31 pm
Available. Tq
Azlan
Post by Azlan on Fri May 18, 2018 11:37 am
available.tq
Azlan
