Yamaha YSP-5600 Sound Bar With Atmos & 4K
Post by stylelaser.com.my on Mon Apr 30, 2018 4:36 pm
Yamaha YSP-5600 Sound Bar With Atmos & 4K Used In Excellent Condition. Now Selling At RM4,750. Free Shipping Within West Malaysia.
Please visit www.stylelaser.com.my to find out more products for sale at very special price...
YSP-5600
MusicCast Sound Bar with Dolby Atmos®️ and DTS:X™️
The YSP-5600 employs a remarkable 46 speaker drivers and Yamaha exclusive Digital Sound Projector technology to deliver Dolby Atmos®️ and DTS:X™️ multidimensional listening experiences. MusicCast provides versatile wireless connectivity (Wi-Fi®️, Bluetooth®️, AirPlay®️ and Spotify Connect), access to streaming services and music libraries, and wireless multiroom audio control using a simple app on your smartphone or tablet.
  • World's first sound bar with 7.1.2-channel multidimensional sound
  • HDMI®️ inputs with 4K Ultra HD pass-through and HDCP 2.2
  • Versatile connectivity – Wi-Fi, Bluetooth, AirPlay and Spotify Connect
  • MusicCast provides access to Pandora®️, Napster, TIDAL, Deezer, Spotify, SiriusXM Internet Radio and more
  • Add audio in up to 9 additional rooms with MusicCast
  • Subwoofer and wireless transmission kit sold separately – see accessories for details
具備數位聲音投射技術,重現7.1.2聲道,讓您以令人驚豔的3D真實環繞聲享受電影及音樂;MusicCast功能讓您透過一個app享受多種音訊來源。
  • YSP技術中史上最多- 由46個揚聲器發出的環繞音
  • 兩側各6個向上陣列揚聲器重現7.1.2聲道
  • 支援最新環繞音格式, Dolby Atmos®️ 以及 DTS:X
  • *DTS:X 透過韌體更新支援
  • 支援3種分類共10種CINEMA DSP 3D程式
  • Dialogue Lift 功能確保人聲對話來自螢幕正中央
  • MusicCast 讓您串流任何音樂至MusicCast產品
  • MusicCast CONTROLLER 讓您由您的智慧型裝置控制音訊設備
  • 支援網路電台以及多種音樂串流服務
  • AirPlay®️ 讓您能從Mac, PC, iPod, iPhone 以及 iPad 無線串流音樂
  • 支援藍牙搭配輸出至YSP-5600或其他藍牙裝置
  • 支援多種格式 MP3, WMA, MPEG4-AAC, Apple Lossless, WAV, FLAC 以及AIFF
  • HDMI支援4K60p直通以及HDCP2.2
  • 操作選單透過HDMI輸入支援透明選單及多國語言
  • Clear Voice 讓人聲更加清晰易聽
  • 簡易外部設計,前方和頂部採用了網狀格柵罩蓋
  • 指示指標在格柵外表中,不需要時將會自動熄滅
  • 可壁掛,您可以挑選您最愛的安裝方式
True Surround Sound from a Single Unit
Beautifully designed with 44 precisely calculated and positioned beam drivers and two woofers, the YSP-5600 effectively creates 7-channel sound beams (front left/right, center, surround left/right, height left/right). Using Yamaha Digital Sound Projector technology, each speaker is controlled by individual delay times and is driven with its own independent amplifier circuit. These beams are projected onto the walls and ceiling, and reflected to the listening position. In addition, the YSP-5600 uses the surround channel sound beam for surround back to support 7.1.2-channel Dolby Atmos or DTS:X reproduction.
數位聲音投射技術,實現由一個單體所發出的3D真實環繞音
網狀外型內部搭載44個位置準確計算的揚聲器單體。為了呈現7聲道環繞音束(前左右方/ 中間/ 環繞左右方/上方左右方),Soundbar的各單體、延遲時間皆透過獨立的擴大器電路控制。這些音束被反射到牆壁及天花板,可精確的反射至聆聽位置,此功能產生同牆壁以及吸頂喇叭的音效-非虛擬的音效,為3D真實環繞重現。此外,YSP-5600後環繞使用環繞音束,而環繞聲道使用虛擬環繞以重現7.1.2聲道的Dolby Atmos或DTS:X聲音格式。
The First Sound Bar to Create Height Channels
透過特定陣列揚聲器音束結合YSP技術創造出高度聲道
The height channels are created by placing six array speakers on each end of the unit (a total of 12). For the maximum sound beam effect, they are mounted on an angled baffle with sound beam vertical control. The result is realistic sound field reproduction with true height, as if real speakers were mounted on the ceiling. You get great sound without having to mount ceiling speakers or run speaker wire.
透過設置一邊六個(共12個)陣列揚聲器呈現垂直音束。使用直徑28mm的陣列揚聲器,為了將音束效果放至最大,他們被安裝於具角度的檔板,垂直音束被最適調整。重現音場,就像揚聲器裝置在您的天花板一樣,您可以不用裝置吸頂喇叭或拉線即可享受高音質。
Height Channel Positions Can Be Precisely Adjusted to Match the Listening Position
For reproduction of the latest surround sound formats such as Dolby Atmos and DTS:X, the relationship between the listening position and the height channel is critical for the best sound. The YSP-5600 adjusts the angle of the sound beam directed at the ceiling allowing the height channel position to match the listening position. This process can be done manually or automatically.
高度音束可被精確調整以符合聆聽位置
搭載最新環繞格式Dolby Atmos and DTS:X,聆聽位置以及高度音束定位對重現聲音就顯得更加重要了。YSP-5600調整直接透過天花板反射的音束角度,讓高度音束更能手動或自動符合聆聽位置。即使聆聽位置改變,您仍然可以感受到自然的3D環繞音。
Directed Sound Beams Realise Distinct Height Channel Audio
The height speakers create multi-dimensional sound by reflecting directed beams off the ceiling to the listening position. The YSP-5600 creates accurate sound position, ensuring realistic reproduction of overhead sound effects such as thunder or airplanes.
定向音束呈現準確的高度音訊
高度揚聲器能盡可能呈現如中置揚聲器一樣靠近聆聽位置的中央。高度揚聲器的位置對於現場演出的多面向聲音的聲音品質有很大的影響;透過天花板反射的直接反射音以重現高度音束,YSP-5600能傳達準確聲音位置以及不同的聲音,確保重現真實的環境音效,如雷擊。您將會體驗到如"天降甘霖"3D環繞音。
Dialogue Lift Ensures Proper Dialogue Orientation
With many sound bars positioned below the TV, dialogue and vocals can often seem misplaced relevant to the people talking onscreen. To correct this problem, the YSP-5600 has a Dialogue Lift function (adjustable in three steps) that raises the reflecting beams from the array speakers to the proper height for accurate onscreen dialogue. Enjoy sounds and images that are perfectly aligned, just as in a movie theater.
Dialogue Lift確保人聲發聲位置
許多Soundbar都擺置於電視下方,尤其是寬螢幕,對話或歌唱常常像由下方傳出;為防止這個問題,YSP-5600搭載Dialogue Lift功能(三個模式調整),讓其由陣列揚聲器反射音束,以提高對話位置。你可以享受聲音以及影像的完美融合,就像在電影院一樣。
Support for the Latest Surround Format, Dolby Atmos®️
搭載最新格式如Dolby Atmos及DTS:X
Enter a new world of sound with Dolby Atmos®️. It transports you from an ordinary moment into an extraordinary experience with captivating, multidimensional sound that fills your room with amazing richness and depth. Music, people, and objects come alive in breathtaking detail and flow in precise choreography all around you, making you feel like you are truly there. The combination of Dolby Atmos and the YSP-5600 will fill the room with multidimensional sound that makes you feel as if you are right in the middle of the story unfolding on the screen.
YSP-5600搭載最新、受矚目電影院環繞格式如 Dolby Atmos及DTS:X, Dolby Atmos 出廠時搭載,DTS:X 透過韌體更新支援。
Support for the Latest Surround Format, DTS:X™️
DTS:X™️ is the next generation object-based, multi-dimensional audio technology from DTS.
Unbound from channels, DTS:X conveys the fluid movement of sound to create an incredibly rich, realistic and immersive soundscape - in front of, behind, beside and above the audience - more accurately than ever before. The combination of DTS:X and the YSP-5600 will fill the room with multidimensional sound that makes you feel as if you are right in the middle of the story unfolding on the screen.
Supports the Exclusive Yamaha CINEMA DSP 3D Mode
支援Yamaha獨家技術 CINEMA DSP 3D 模式
Yamaha’s original CINEMA DSP 3D Mode adds an expansive height direction to the sound field, creating a rich surround space. The YSP-5600 supports this feature by using special array speakers to create vertical beams. You can enjoy the feeling of a live performance with standard sound formats, and combine this effect with Dolby Atmos or DTS:X to enjoy a more natural expansion of the 3D surround sound.
Yamaha’s 原創技術CINEMA DSP 3D 模式新增高度音場,創造出豐富環繞音。 YSP-5600 透過特殊陣列揚聲器產生垂直音束。您可以透過預設聲音格式享受現場表演,也可加入Dolby Atmos或DTS:X的音效,享受更加自然的3D環繞音。
Choose One of Four Listening Modes to Match Your Scenario
The YSP-5600 is equipped with four listening modes: 3D Surround, which commands five horizontal beams and two vertical beams to recreate the equivalent of up to a 7.1.2-channel three-dimensional sound field; Surround, which uses five horizontal beams to perform normal 5.1-channel surround playback; Stereo, which uses a special vertical beam speaker as a tweeter to produce high sound quality 2-channel stereo from audio sources; and Target Playback mode, which aims monaural sound clearly to a precise location in the room.
四選一的聆聽模式,符合你的聆聽環境
YSP-5600搭載四種聆聽模式: 3D環繞模式,搭載五個平行音束以及兩個垂直音束,重現7.1.2的3D音場;環繞模式,以五個平行音束呈現普通5.1聲道播放;立體聲模式,使用特殊兩聲到垂直音束揚聲器作為單體以呈現兩聲道高音質;以及Target模式,此模式目的為了呈現清晰人聲,讓其到達精準位置。在3D環繞模式,你可以選擇CINEMA DSP 3D模式,呈現一個廣闊的音場範圍。
Easy Sound Calibration for Your Room
The YSP-5600 employs IntelliBeam automatic sound optimization using the supplied microphone for the best performance in your listening environment. This also includes setting the position of sound beams directed at the ceiling. Achieve highly accurate and impressive sound field reproduction.
Intellibeam自動校正高度音束設定
YSP-5600搭載音束、聲音最佳化,並透過IntelliBeam麥克風達到音場最佳化,讓您免去麻煩的音場設置並能達到高度準確的聲音設置,符合聆聽環境。這兩種功能統稱為IntelliBeam,透過天花板反射的音樹也可以自動設置,YSP-5600能重現個房間的現場音樂氛圍。
MusicCast
Access all of your music with a simple app and wirelessly stream it throughout your home using your existing Wi-Fi network.
  • Stream it all. Listen to Pandora®️, Spotify, Napster, SiriusXM Internet Radio, TIDAL, Deezer, thousands of free internet radio stations and the music stored on your smart devices and computers.
  • Wireless connectivity. All MusicCast products are fully loaded with Wi-Fi, Bluetooth and AirPlay®️.
  • Expand to a whole home audio experience. When you’re ready, add MusicCast wireless speakers, sound bars or other devices in up to 9 other rooms and listen throughout your home.
  • No wires, easy installation. By using MusicCast, you don't need to fuss with placing wires through walls into other rooms.
Learn more about MusicCast wireless multiroom audio
Bluetooth Output for Convenient Music Streaming
The YSP-5600 is equipped with the latest Bluetooth technology, making wireless operation more convenient than ever. You can stream music from the YSP-5600 to Bluetooth headphones for private listening or to Bluetooth speakers.
方便的藍牙音訊輸出
YSP-5600具備最新最方便的藍牙技術。你可以透過YSP-5600傳送音樂到藍牙耳機獨自聆聽,或者到藍牙喇叭上播放。
HDMI®️ with 4K/60p and HDCP 2.2
HDMI端子及4K Ultra HD支援4K60p,HDCP2.2
The YSP-5600 supports transmission of 4K video at 60 frames per second pass-through, so you can enjoy full high-definition video quality without degradation. It also offers an input that complies with the HDCP 2.2 copyright protection standard for 4K video transmission.
YSP-5600完全支援最新的HDMI標準。透過4K每秒60幀幅率直通,你可以享受完全不降級的4K高畫質影片,同時也支援HDCP2.2數位版權保護標準。
Streaming Services Offer a Huge Range of Listening Choices
Support for the music streaming services Spotify, Pandora, Rhapsody and Sirius XM means you’ll enjoy a wide variety of music content. Furthermore, support for the vTuner radio station database enables sampling of internet radio broadcasts from around the world. *Streaming service availability varies by region.
Simple Exterior Design
The front panel and the indicator section are covered by a mesh grille achieving a simple, elegant look. In addition, the indicator section lights only when needed, to avoid any distraction while viewing. The YSP-5600 can be placed on TV furniture using the included feet or it can be wall-mounted using an optional bracket (see Accessories). It stands at only 8-3/8” tall and 3-5/8” deep (without the feet) fitting beautifully into any décor.
優雅外觀設計,不影響觀看
前面板和顯示部分都涵蓋了網狀格柵,呈現簡單、優雅的外觀。在每一端曲線網格繞到上方面板,精巧的呼應環繞聲設計。指示信號只會在需要時出現,不會影響觀看;即使是特殊垂直揚聲器設計,也只有1100毫米,比之前的YSP-5100更小100毫米,深度只有93毫米(不含架子),符合房間放置。
Optional Wireless Subwoofer Kit
The optional SWK-W16 kit can be attached to a subwoofer unit to connect it wirelessly. You won’t need to use any connecting wires between the unit and the subwoofer, increasing your system layout options.
Custom Integration Friendly
The YSP-5600 has an IR input and pass-through output for use with third-party control systems. In addition, it is certified for use with Control4 home automation and smart home systems for network-based control.
Additional Menus for Hotel Room Use
Additional menus are provided for settings such as preventing accidental operation by guests. For example, with the Turn-On Volume setting, when power is turned on the volume is automatically set to a reasonable volume to avoid the surprise of very loud sounds. The Max. Volume can block high volume settings, and the Input Lock can prevent accidental operation.
Other Notable Features
• Clear Voice makes dialogue and narrations easy to hear
• Music Enhancer improves the sound of compressed sources
• Adaptive DRC enables volume and dynamic range adjustment
• OSD supports overlay and multiple languages
(English, German, French, Spanish, Italian, Dutch, Russian, Swedish, Turkish, Japanese)
• Subwoofer output terminal for system expansion
支援客製化安裝
此Soundbar支援IR-OUT端子作為紅外線通道輸出功能,意味著它可以偵測前方幾乎所有的遙控信號,他亦具備IR-IN端子可接收其他單體的遠端電子控制信號。此外,亦支援Control4家庭自動化信號,適合客製化安裝。
額外選單,適合旅館使用
支援額外選單,防止客人意外操作,如音量設定,當電源開啟時,音量自動被調整到最適音量,以防驚嚇到客人。最大音量可被調適,輸入鎖可以防止意外操作。
其他功能
• Clear Voice 讓人聲更清晰
• Music Enhancer 改善壓縮音樂品質
• Adaptive DRC 支援音量及動態範圍調校
• 超低音輸出端子可用於系統擴充
Specifications :
Sound bar:
Yamaha's Digital Sound Projector technology delivers 7.1.2-channel sound with support for Dolby Atmos
built-in amplifiers: 2 watts x 44 (beam drivers), 20 watts x 2 (subwoofers)
features 46 total built-in speakers:
thirty-two 1-1/2" horizontal beam drivers
twelve 1-1/8" vertical beam drivers
two 4-1/2" cone subwoofers
Yamaha IntelliBeam auto calibration system optimizes the sound bar for your room (setup microphone included)
height channel sound beam can be adjusted to match the listening position
Dolby Digital®️ and DTS®️ decoding, including Atmos
next-generation DTS:X surround sound available via a future firmware update
Cinema DSP modes add richness and depth to music and movie soundtracks
Dialogue Lift for clearer, louder dialogue on movies and shows
sits on a TV stand or can be mounted on a wall (hardware not included)
sits 8-3/8" tall when placed on a stand
MusicCast wireless multi-room music system:
connects to your Wi-Fi network for wireless music listening
built-in Bluetooth lets you stream directly from compatible devices
also sends audio wirelessly to Bluetooth-enabled speakers or headphones
free MusicCast app lets you play music with your Apple or Android device
support for online music services, including Spotify, Pandora, SiriusXM, and thousands of free Internet radio stations (subscription required for some services)
connects wirelessly to other Yamaha speakers and receivers with MusicCast to play the same song through multiple speakers or different songs in different rooms
plays MP3, AAC, WMA, FLAC, ALAC, WAV, and AIFF files
supports high-res playback for PCM-based files up to 24-bit/192kHz
built-in music enhancer for smoothing out the sound of over-compressed MP3 files
Apple AirPlay®️ for streaming from compatible Apple devices and computers running iTunes®️
DLNA support for streaming music from compatible networked computers and NAS drives
supports 802.11 b/g/n Wi-Fi (2.4 GHz)
Connections and general info:
HDMI switching: 4 in, 1 out
HDCP 2.2 technology for 4K Ultra HD sources and TVs (HDMI input 1 and monitor output only)
does not support HDR pass-through
digital audio inputs: 2 optical, 1 coaxial
analog stereo RCA inputs
Ethernet port for network connection
subwoofer output for adding your own powered subwoofer
optional SWK-W16 kit can be attached to a subwoofer (not included) to connect it wirelessly
wall-mountable with optional bracket (sold separately)
remote control
43-5/16"W x 8-3/8"H x 4-7/8"D (with feet installed)
weight: 25.8 lbs.
Peter  012-2536225
Fong   016-3098668
BRANDED led tv
amplifier
speaker
cd player
Number of posts : 324
