Monitor Audio Gold C150 Center Speaker
Monitor Audio Gold C150 Center Speaker Empty Monitor Audio Gold C150 Center Speaker
Post by stylelaser.com.my on Mon Apr 30, 2018 5:08 pm
Monitor Audio Gold C150 Center Speaker Brand New. Now Selling At RM5,399. Free Shipping Within West Malaysia.
Monitor Audio Gold C150 Center Speaker G893gc11
Gold C150
The ultra-compact Gold C150 centre speaker is small enough to fit into most AV racks and is designed to match the smaller Gold speakers in a more bijou home theatre configuration.
AWARDS
Monitor Audio Gold C150 Center Speaker Trusted-gold
However, because it shares tonal characteristics with all models, its capabilities are also compatible with any 'Gold' system design. The Gold C150's lustrous sealed cabinet is home to twin 5.5" drivers and the ribbon in a two way orientation, providing superior dispersion across a range from 50 Hz to 60 kHz.
This product is now available to use with home theatre design software, The Cinema Designer. Read more.
Technology
  • C-CAM (Ceramic-Coated Aluminium/Magnesium) ribbon transducer design – providing extension to a class leading 60 kHz
  • Single bolt through driver fixings for improved bracing, rigidity and driver/baffle de-coupling
  • New C-CAM RST (Rigid Surface Technology) bass/mid-range driver
  • Die-cast alloy terminal panel arrangement with high quality bi-wire terminals and high end spade type link cables
  • Pureflow silver internal cabling
  • Selected premium quality wood veneer or high gloss lacquer finishes
  • Rigid 20 mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
  • Invisible magnetic grille fixings provide a sleek visual effect.
Monitor Audio Gold C150 Center Speaker Gold-tech-3.600x450
System Format
2-Way
Frequency Response
55 Hz — 60 kHz
Sensitivity (1W@1M)
89 dB
Nominal Impedance
8 ohms
Maximum SPL
111.5 dB
Power Handling (RMS)
150 W
100 — 150 W
Bass Alignment
Sealed Cabinet
Crossover Frequency
2.8 kHz
Drive Unit Complement
2 x 51/2" RST bass/mid-range driver
1 x C-CAM H.F ribbon transducer
Cabinet Dimensions (H x W x D)
172 x 461 x 303 mm
(611/16 x 181/8 x 1115/16")
Complete Dimensions (Including Terminals (H x W x D))
172 x 461 x 330 mm
(611/16 x 181/8 x 13")
Weight (each)
6 kg (13 lb 4 oz)
Peter  012-2536225
Fong   016-3098668
Monitor Audio Gold C150 Center Speaker Trade
BRANDED led tv
amplifier
speaker
cd player
Number of posts : 557
