Monitor Audio Silver 300 5.1 Home Theater Package
Monitor Audio Silver 300 5.1 Home Theater Package Empty Monitor Audio Silver 300 5.1 Home Theater Package
Post by stylelaser.com.my on Sun May 06, 2018 5:51 pm
Monitor Audio Silver 300 5.1 Home Theater Package Brand New. Now Selling At RM24,499. Free Shipping Within West Malaysia.
Monitor Audio Silver 300 5.1 Home Theater Package Monito22
Monitor Audio Silver 300 5.1 Home Theater Package Monito23
The Monitor Audio Silver AV is a complete 5.1 Channel Home Cinema Speaker System comprising:
1 Pair of Monitor Audio Silver 300 Fronts
1 Pair of Monitor Audio Silver FX Rear ( White )
1 Monitor Audio Silver C350 Centre
1 Monitor Audio Silver W12 Subwoofer.
Monitor Audio Silver 300 Floorstanding Speakers
The Monitor Audio Silver 300 floorstander retains the familiar award-winning configuration of its predecessor, with several crucial improvements to drivers. The full three-way design delivers class-leading mid-range, while a pair of long-throw 6½-inch bass drivers work together to produce incredible power from the tall, but slim cabinet design, making it the perfect choice for serious audiophile and AV installations.
The three-way configuration allows each driver to be optimised to do a better job over a narrower frequency band; the only real way to deliver elevated performance in every respect. Superlatively natural mid-range comes courtesy of a dedicated 4-inch driver, specially designed with ‘under hung’ voice coil and motor system. This technique ensures the voice coil always remains in the magnetic gap under all conditions for demonstrably lower distortion than usually found at this level – an advance which can be immediately heard.
Monitor Audio Silver C350 Centre Speaker
The Silver C350 centre speaker from Monitor Audio is designed for serious home theatre installations, where performance is the most critical factor. The three-way, four-driver configuration utilises the same driver complement as the Silver 300 although, in this case, the bass drivers have been designed and tuned to work in a sealed box for easier placement in a cabinet or close to a boundary/wall. For the perfect A/V enjoyment, you can’t better the Silver C350 for crisp, articulate dialogue. Don’t miss a word.
What makes the Silver C350 so special is the vertical orientation of the mid and tweeter axis which delivers the same directivity as the other speakers in the system. A high percentage of the total sound balance in a theatre system is delivered to the centre channel (typically 60%), so this crucial speaker should not to be overlooked when specifying a high-performance, no-compromise theatre system for the home.
Monitor Audio Silver FX Dipole Speakers
Enjoy the immersive quality of high performance home cinema with Sliver’s specialised surround speaker. The discreetly profiled angled baffle design of the new Silver FX incorporates a single front-mounted 6” C-CAM®️ RST®️ bass/mid driver and twin side-mounted C-CAM tweeters. It can be flush-mounted on side or rear walls and its dispersion characteristics changed at the flick of a switch for dipole or bi-pole operation.
The new Silver W12 active subwoofer introduces a number of new design developments housed in a compact high power unit. A new 500 watt DSP controlled amplifier utilises advanced switch-mode power conversion techniques and superior processing to increase dynamic control and deliver far greater head-room. The W12’s sealed box construction ensures that this potent unity of power and control delivers tight, fast and tuneful bass all the way down to a thunderous 22Hz in a typical room set up. The sealed box, front-firing driver design makes for easy installation and EQ where close proximity to a room boundary may be necessary.
Specification:
System Format
3-way
Frequency Response (-6 dB)
32 Hz – 35 kHz
Sensitivity (1W@1M)
90 dB
Nominal Impedance
8 ohms
Minimum Impedance
3.5 ohms @ 146 Hz
Maximum SPL
116 dBA (pair)
Power Handling (RMS)
200 W
80 – 200 W
Bass Alignment
Bass reflex. HiVe II port system
Crossover Frequency
LF/MF: 570 Hz
MF/HF: 3.5 kHz
Drive Unit Complement
2 x 6" C-CAM RST bass driver
1 x 4" C-CAM RST mid-range driver
1 x 1" (25 mm) C-CAM Gold Dome tweeter
Cabinet Dimensions (Excluding Grille and Terminals)
1000 x 185 x 300 mm
(393/8 x 75/16 x 1113/16")
External Dimensions (Including Grille and Terminals)
1000 x 185 x 329 mm
(393/8 x 75/16 x 1215/16")
External Dimensions (Including Out-Rigger Plates, Feet and Spikes)
1034 x 252 x 367 mm
(4011/16 x 915/16 x 147/16")
Weight (each)
20 kg
Sensitivity 87 dB
Impedance 8 Ohms
Power Rating 85 Watts
Dimensions (H x W x D) 250 mm x 322 mm x 147 mm (inc grille and terminals)
Weight 4.3 kg
Freq Response (Hz) 60 - 35,000
Speaker Enclosure Type Infinite Baffle (Sealed)
Crossover Freq (Hz) 40 - 120
Power Rating 500 Watts
Dimensions (H x W x D) 340 mm x 340 mm x 380 mm
Weight 20.1 kg
System Format
3-way
40 Hz – 35 kHz
Sensitivity (1W@1M)
90 dB
Nominal Impedance
8 ohms
Minimum Impedance
3.2 ohms @ 176 Hz
Maximum SPL
113 dBA
200 W
80 – 200 W
Bass Alignment
Sealed cabinet
Crossover Frequency
LF/MF: 830 Hz
MF/HF: 3.2 kHz
2 x 6" C-CAM RST bass/mid driver
1 x 4" C-CAM RST midrange driver
235 x 560 x 240 mm
(91/4 x 221/16 x 97/16")
235 x 560 x 270 mm
(91/4 x 221/16 x 105/8")
Weight (each)
14.9 kg
Peter  012-2536225
Fong   016-3098668
Monitor Audio Silver 300 5.1 Home Theater Package Trade
BRANDED led tv
amplifier
speaker
cd player
Number of posts : 575
