Paradigm Monitor SUB 10 10" Powered Subwoofer
Paradigm Monitor SUB 10 10" Powered Subwoofer Brand New. Now Selling At RM4,699. Free Shipping Within West Malaysia.
Input Facilities:
Control Facilities:
THE DIFFERENCE BETWEEN A GOOD SOUNDING SUBWOOFER AND A GREAT SOUNDING SUBWOOFER IS IN THE DESIGN: PARTS, POWER, PRECISION
PARTS
In today’s market, the call is for subwoofers in much smaller form factors but without any sacrifice in performance. Part of Paradigm’s success in this area is our proprietary design, our commitment to high-quality materials and a process known as Finite Element Analysis (FEA). FEA allows us to analyze the movement of the cone, monitor magnetic flux, evaluate heat dissipation and perform stress analyses on both component parts and the enclosure. We can enact “what if” scenarios, making virtual material substitutions or design changes and observing their effects on the magnet/motor structure before we even start building a sub. This ability to experiment is what has allowed us to achieve such incredible performance from a form factor as small as that of the tiny Monitor SUB 8.
POWER
PRECISION
INJECTION-MOLDED CARBON-LOADED POLYPROPYLENE CONES
A high stiffness-to-mass ratio is an important aspect in a woofer’s ability to deliver that loud, deep, clean and articulate bass we all desire. In this case, in-house injection-molding and a 30% carbon content made for a wonderfully stiff cone while the polypropylene, an inherently well-damped material, delivered the necessary lightness, the cone is never weighed down in its movement.
ACTIVE RIDGE (ART) TECHNOLOGY SURROUNDS
Crafted in-house using audiophile-grade injection-molded thermoplastic elastomer, and then overmolded directly onto our driver cones, the exclusive ART Surround design achieves greater excursion than any standard surround. With ART Surrounds, drivers achieve a 3dB gain in distortion-free output (50% greater output).
Monitor SUB 10 Specifications
Made In Canada
Design
Single driver, acoustic suspension, built-in advanced Ultra-Class-D amplifier, USB port for PBK?equalization, removable grille
Amplifier
900 watts Dynamic Peak; 300 watts RMS Sustained
Amplifier Features
Auto-on/off, soft clipping, thermal protection
Room Correction
Paradigm Perfect Bass Kit (sold separately)
Low Pass Filter Frequency
Variable 35 Hz - 150 Hz; Bypass Option
Low Frequency Driver
254-mm (10 in) carbon-loaded polypropylene cone, Active Ridge (ART) Technology surround, 38-mm (1-1/2 in) 4-layer copper-clad aluminum voice coil. Nomex spider, 4.5 lb ferrite magnet, AVS die-cast heatsink chassis
Low Frequency Extension
17 Hz (DIN)
Sub / Sat Phase Alignment
Variable 0° - 180°
Finishes
Black Ash
Inputs
Two RCA (L/R-Mono) for L/R lineout or Sub-Out/LFE-Out of receiver/processor or other line-level source
Compatible Products
PT-2 Wireless Transmitter (sold separately)
Weight
30 lbs. (13.6 kg)
Dimensions HxWxD
13" × 11.125" × 12.75"
(33.0cm × 28.3cm × 32.4cm)
BRANDED led tv
amplifier
speaker
cd player
Monitor Subwoofers
- A compact footprint without compromising bass output or bass extension.
- Trickle-down Paradigm Reference technology … despite cone size, the Active Ridge (ART) Technology surrounds help cones move huge volumes of air for bass so loud and so deep it will send the cat running for cover.
- State-of-the-art room-tuning technology. Don’t worry about perfect placement, put the sub where it looks best and let Paradigm’s Perfect Bass Kit (sold separately) dial in perfect bass.
- Go wireless! Paradigm’s PT-1 transmitter (sold separately) can be used with up to four Monitor subwoofers simultaneously.
- The clean, modern aesthetic matches the new Monitor Series 7 speakers.
- Monitor Series 7 subs were designed, engineered and manufactured in our state-of-the-art Toronto, Canada facility.
Input Facilities:
- Line-level Inputs
Control Facilities:
- Auto On/Standby
- Subwoofer Level
- Subwoofer Cut-Off Frequency (continuously variable 50 Hz – 150 Hz); Bypass Option
- Sub/Sat Phase Alignment (continuously variable 0° to 180°)
PARTS
POWER
- 900 watts Dynamic Peak Power / 300 watts RMS Sustained
- Ultra-Class-D Power Amplifier with Unique Switching Power Supply.
- BIG Power from a Compact Package: The low-noise high-power compact transformer (0.29 lb/0.13 kg) boasts an ETD core purpose-designed for smaller applications that must have high power. Noise suppression networks and top quality MOSFETs help to achieve high current but with quiet operation. Unlike conventional Class-D amplifier designs, our design inherently rejects variations in the power supply.
- Full-Bridge Output Stage: Operates from split power suppy rails ensuring exceptionally low distortion. Not only does the design increase the speed of switching it also dramatically increases switching efficiency.
- Precision Driver Components and Military-Spec (FR-4-Rated) Glass-Epoxy Circuit Board: Reference-quality component parts and a circuit board painstakingly designed by hand guarantee an enviable degree of performance and long-term reliability even under extreme conditions.
- Unique Temperature Sensors: Maintain a safe operating temperature even when the Monitor subwoofers are operating under maximum output conditions.
- Superior Short Circuit Protection: Should current through the MOSFETs exceed our internally preset limit, the Digital Signal Processing (see below) disables the output stage. Reaction time is typically within 10 μs.
- Digital Signal Processing: Monitors the line current and voltage so that long-term average output power remains continuous. Sophisticated mathematical algorithms shape frequency response (see graph) ensuring accurate, consistent and musical bass without distortion even when the subs are pounding out bass at the highest levels.
PRECISION
Made In Canada
Design
Amplifier
Amplifier Features
Room Correction
17 Hz (DIN)
Variable 0° - 180°
Finishes
Black Ash
Inputs
Compatible Products
Weight
30 lbs. (13.6 kg)
Dimensions HxWxD
BRANDED led tv
amplifier
speaker
cd player
- Number of posts : 1250
» Paradigm Monitor SUB 8 8" Powered Subwoofer
» Paradigm Defiance V8 8" Powered Subwoofer
» Paradigm Defiance V10 10" Powered Subwoofer
» Paradigm Defiance V12 12" Powered Subwoofer
» Monitor Audio Monitor MRW10 10" Powered Subwoofer
