Onkyo TX-SR605 7.1Ch Av Receiver
Onkyo TX-SR605 7.1Ch Av Receiver Used In Excellent Condition. Now Selling At RM990. Free Shipping Within West Malaysia.
7.1-Channel Home Theatre Receiver
Processing Today’s High-Resolution Media Including Blu-ray Disc and HD DVD with Effortless Efficiency
Meet the first of Onkyo’s new A/V receivers built to embrace high-definition media such as Blu-ray Disc and HD DVD.The TX-SR605 7.1-channel A/V receiver embodies this new generation, with its remarkable processing capabilities courtesy of HDMI (High Definition Multimedia Interface).With the ability to keep everything in the digital domain, the TX-SR605 provides complete control of every video and audio format available today. Bringing high-definition A/V processing to Onkyo’s renowned approach to sound gives this A/V receiver a distinct advantage in the home. Delivering the latest in usability and versatility—such as multi-room playback, a full connectivity suite (with switching and upconversion), room calibration and integrated system control—the TX-SR605 is poised to set new benchmarks in performance-driven home theatre.
ADVANCED FEATURES
AUDIO FEATURES
VIDEO FEATURES
OTHER FEATURES
Specifications :
Amplifier Section
Video Section
Tuner Section (TX-SR605 only)
General
■ Video Inputs
■ Video Outputs
■ Audio Inputs
■ Audio Outputs
Specifications and features are subject to change without
notice.
Rated Output Power (FTC)
All channels: 90 watts minimum continuous power
per channel, 8 ohm loads, 2 channels
driven from 20 Hz to 20 kHz, with a
maximum total harmonic distortion of
0.08%
105/110 watts minimum continuous
power per channel, 8 ohm loads,
2 channels driven at 1 kHz, with a
0.7/0.9%
110 watts minimum continuous power
per channel, 6 ohm loads, 2 channels
driven at 1 kHz with a maximum total
harmonic distortion of 0.1%
Rated Output Power (IEC)
7 ch u 140 W at 6 ohms, 1 kHz, 1 ch
driven
Maximum Output Power (JEITA)
7 ch u 175 W at 6 ohms, 1 kHz, 1 ch
driven
Dynamic Power 210 W + 210 W (3 :, Front)
180 W + 180 W (4 :, Front)
110 W + 110 W (8 :, Front)
THD (Total Harmonic Distortion)
0.08% (Power Rated)
0.08% (1 kHz, 1 W)
Damping Factor 60 (Front, 1 kHz, 8
Input Sensitivity and Impedance
200 mV/47 k: (LINE)
Output Level and Impedance
200 mV/470 : (REC OUT)
Frequency Response 5 Hz - 100 kHz/+1 dB - 3 dB (Direct mode)
Tone Control ±10 dB, 50 Hz (BASS)
±10 dB, 20 kHz (TREBLE)
Signal to Noise Ratio 100 dB (LINE, IHF-A)
Speaker Impedance North American: 6 : - 16 :
Others: 4 : - or 6 : - 16 :
Input Sensitivity/Output Level and Impedance
1 Vp-p/75 : (Component and S-Video Y)
0.7 Vp-p/75 : (Component PB/CB, PR/CR)
0.28 Vp-p/75 : (S-Video C)
1 Vp-p/75 : (Composite)
Component Video Frequency Response
5 Hz - 50 MHz - 3 dB
FM Tuning Frequency Range
North American: 87.5 MHz - 107.9 MHz
Others: 87.5 MHz - 108.0 MHz
AM Tuning Frequency Range
North American: 530 kHz - 1710 kHz
European: 522 kHz - 1611 kHz
Others: 522/530 kHz - 1611/1710 kHz
Preset Channel 40
Power Supply North American: AC 120 V, 60 Hz
European: AC 230 V, 50 Hz
Others: AC 120/220 - 240 V, 50/60 Hz
AC 220 V, 50/60 Hz
Power Consumption North American: 6.5 A
Others: 630 W
Dimensions (W u H u D)
435 u 174 u 377 mm
17-1/8" u 6-7/8" u 14-13/16"
Weight North American: 11.4 kg (25.1 lbs.)
Australian: 11.6 kg (25.6 lbs.)
Others: 11.5 kg (25.4 lbs.)
HDMI IN1, IN2
Component IN1, IN2, IN3
S-Video DVD, VCR/DVR, CBL/SAT, GAME/TV,
AUX
Composite DVD, VCR/DVR, CBL/SAT, GAME/TV,
AUX
HDMI OUT
Component OUT
S-Video MONITOR OUT, VCR/DVR
Composite MONITOR OUT, VCR/DVR
Digital Inputs Optical: 3 (1 on Front Panel)
Coaxial: 2
Analog Inputs DVD (MULTICHANNEL), VCR/DVR,
CBL/SAT, GAME/TV, AUX, TAPE, CD
Multichannel Inputs 7.1
Analog Outputs TAPE, VCR/DVR, ZONE2
Subwoofer Pre Output 1
Speaker Outputs L, R, C, SL, SR, SBL, SBR,
ZONE2 (L/R)
BRANDED led tv
amplifier
speaker
cd player
*4 HDMI Input2 is compatible with HDCP 2.2.
ADVANCED FEATURES
- DTS-HD Master Audio, DTS-HD High Resolution Audio, Dolby TrueHD, Dolby Digital Plus Decoding
- HDMI (v. 1.3a) Audio and Video Processing
- HDTV-Capable HDMI (2 Inputs and 1 Output) and Component Video (50 MHz) Switching (3 Inputs and 1 Output)
- HDMI and Component Video Upconversion
- Bi-Amping Capability for Enhanced Musicality and Power
- Audyssey 2EQ to Correct Room Acoustic Problems and to Calibrate Speakers
- Onkyo RIHD for System Control
- Compatible with RI (Remote Interactive) Dock for the iPod
AUDIO FEATURES
- 140 W/Ch Minimum into 6 Ω, 1 kHz, IEC (1 Channel Driven)
- DTS-ES Discrete/Matrix, DTS Neo:6, DTS 96/24, Dolby Digital EX, Dolby Pro Logic IIx
- H.C.P.S. (High Current Power Supply) Massive High Power Transformer
- 192 kHz/24-Bit DACs for All Channels
- WRAT (Wide Range Amplifier Technology)
- Advanced 32-Bit Processing DSP Chip
- 5 Digital Inputs (3 Optical/2 Coaxial)
- Subwoofer Pre Out
- CinemaFILTER
- A-Form Listening Mode Memory
- Optimum Gain Volume Circuitry
- Non-Scaling Configuration
- Tone Control (Bass/Treble) for Front L/R Channels
- Color-Coded 7.1-Multichannel Inputs
- Independent Crossover Adjustment for F/C/S/SB (40/50/60/80/100/120/150/200 Hz)
- Double Bass Function
VIDEO FEATURES
- 5 S-Video Inputs and 2 Outputs
- 5 Composite Video Inputs and 2 Outputs
- Front Panel Auxiliary Input (for Camcorders, Game Consoles, etc.)
OTHER FEATURES
- Powered Zone 2 and Zone 2 Line-Out for Playback in Another Room (Separate Source)
- Deinterlacer with Faroudja DCDi Edge (Directional Correlational Deinterlacing) Technology
- Pure Audio Mode
- Color-Coded Dual Banana Plug-Compatible Speaker Posts
- A/V Synchronization Function (Up to 100 ms in 10 ms Steps)
- 40 FM/AM Radio Presets
- RDS (PS/RT/PTY/TP)
- 5 A/V Inputs and 1 Output
- 2 Audio Inputs and 1 Output
- Late Night Mode (High/Low/Off)
- Digital Upsampling
- Display Dimmer (3 Modes)
- Headphone Jack
- Sleep Timer (via Remote)
- Battery-Free Memory Backup
- Aluminum Front Panel
- Preprogrammed RI (Remote Interactive) Remote Control with Mode-Key LEDs
Specifications :
Amplifier Section
Video Section
General
■ Video Inputs
■ Video Outputs
■ Audio Inputs
■ Audio Outputs
notice.
0.08%
0.7/0.9%
driven
driven
0.08% (Power Rated)
0.08% (1 kHz, 1 W)
200 mV/47 k: (LINE)
Preset Channel 40
AC 220 V, 50/60 Hz
Others: 630 W
435 u 174 u 377 mm
HDMI IN1, IN2
AUX
AUX
HDMI OUT
Component OUT
Coaxial: 2
ZONE2 (L/R)
BRANDED led tv
amplifier
speaker
cd player
- Number of posts : 1250
» onkyo TX-SR605 AV Receiver (used)
» Onkyo TX-SR605 AV receiver (Used) SOLD
» Onkyo TX-SR605 7.1ch DTS-HD av receiver SOLD
» Onkyo TX SR605
» Onkyo TX- SR605 (used) sold
» Onkyo TX SR605
