Sony VPL-HW40ES SXRD Home Cinema 3D Projector (Sold Out)
Post by stylelaser.com.my on Tue May 15, 2018 3:28 pm
Sony VPL-HW40ES SXRD Home Cinema 3D Projector Economical Full HD 3D home cinema projector with SXRD panels, Reality Creation, Bright Cinema and Bright TV modes, Used In Excellent Condition ( Less Than 300 Hour) . Free Shipping Within West Malaysia.
Please visit www.stylelaser.com.my to find out more products for sale at very special price...
An outstanding cinematic experience for home theatre applications
The VPL-HW40ES is a fantastic option for movie lovers who want an incredible cinematic experience at home, far beyond the reach of TV. It is packed with professional technology, including advanced SXRD panels and Reality Creation for an incredibly sharp, crystal clear picture. With 1700 lumens colour brightness, you can enjoy your favourite films at their best, in 3D or 2D. Bright Cinema and Bright TV modes also ensure optimum brightness and superb, rich colour quality.
High quality SXRD panels
Cinema-quality technology for super-sharp images.
High brightness with dynamic picture
1700 lumens brightness with Contrast Enhancer function.
Reality Creation
Best Full HD picture possible.
Wide lens shift for flexible installation
+/–71% lens shift range allows more options for placement.
Extremely low fan noise
Quiet 21db noise with improved tone.
Features
SXRD panel technology
With our SXRD panels technology for super-sharp images, you’ll enjoy incredible high-definition pictures at home.
1700 lumens brightness with faithful colour reproduction
Thanks to an improved optical engine, the VPL-HW40ES is much brighter than our previous standard home cinema projectors. At 1700 lumens, it produces clearer images and faithful colours, even in well-lit rooms.
Reality Creation – Super Resolution function
Developed for our leading 4K home cinema projector (VPL-VW1000ES), Reality Creation reproduces colours and textures that are lost when movies are packaged to disc. It gives you crisper, sharper Full HD pictures, much closer to the 1080p original.
Conventional home cinema projectors sacrifice some colour accuracy by increasing greens to improve brightness. With Bright Cinema and Bright TV modes, the VPL-HW40ES retains true colour and contrast, even in a bright environment.
Contrast Enhancer
Automatically adjusts contrast for optimum viewing by analysing dark and light areas in every scene, without diminishing colour.
Motionflow
See every detail, even in fast-moving action scenes or sports. Motionflow technology shows twice as many pictures per second by creating extra images between the original frames. The result is smoother, sharper motion with less blur.
Wider lens shift range
A wider vertical range than our standard home cinema projectors allows more options for placement and installation, without reducing image quality.
Our advanced cooling system means fan noise is reduced to a whisper-quiet 21db.
Perfect panel alignment
Electronic panel alignment ensures precise colour and clarity. Any colour gaps are corrected by shifting the blue and red areas of each pixel into perfect alignment with green.
Built-in IR 3D transmitter
No set-up time or cables, just synchronise the VPL-HW40ES with your IR 3D glasses via the built-in transmitter.
2D and 3D modes
The VPL-HW40ES automatically recognises 2D or 3D content and allows you to select various picture modes to fit in your contents..
Gamma adjustment
Fine tune image brightness according to the light in the room or the on-screen picture. There are 7 modes to select from.
Real Colour Processing (RCP Version 2)
Adjust the colour and hue using a target on the projected picture. RCP Version 2 also allows you to adjust brightness at the same time.
Display System
Display SystemSXRD projection system
Display device
Size of effective display area0.61" x 3 SXRD
Number of pixels6,220,800 (1920 x 1080 x 3) pixels
Projection lens
FocusManual
Zoom - Powered/ManualManual
Zoom - RatioApprox. x 1.6
Lens shift - Powered/ManualManual
Lens shift - Range Vertical+/- 71%
Lens shift - Range Horizontal+/- 25%
Light source
TypeUltra high pressure mercury lamp
Wattage200 W type
Screen size
Screen size40" to 300" (1.01 m to 7.62 m) (measured diagonally)
Light output
Lamp mode: High1700 lm
Color light output
Display resolution
Computer signal inputMaximum display resolution: 1920 x 1080 dots (HDMI Input only)
Video signal input480/60i, 576/50i, 480/60p, 576/50p, 720/60p, 720/50p, 1080/60i, 1080/50i, The following items are available for HDMI input only; 1080/60p, 1080/50p, 1080/24p
OSD language
OSD language16-languages (English, Dutch, French, Italian, German, Spanish, Portuguese, Russian, Swedish, Norwegian, Japanese, Simplified Chinese, Traditional Chinese, Korean, Thai, Arabic)
INPUT OUTPUT (Computer/Video/Control)
HDMI 1 / HDMI 2HDMI (x2)
Y PB/CB PR/CRPin Jack (x3)
INPUT ARGB/Y Pb/Cb Pr/Cr input connector: Mini D-sub 15-pin (female)
REMOTERS-232C connector: D-sub 9-pin (female)
IR INMini Jack
3D SYNCRJ-45
Acoustic noise
Lamp mode: Low22 dB
Operating temperature / Operating humidity
Operating temperature / Operating humidity5°C to 35°C (41°F to 95°F) / 35% to 85% (no condensation)
Storage temperature / Storage humidity
Storage temperature / Storage humidity-20°C to +60°C (-4°F to +140°F) / 10% to 90% (no condensation)
Power requirements
Power requirementsAC 100 V to 240 V, 3.0 A to 1.3 A, 50 Hz / 60 Hz
Power consumption
AC 100 V to 120 VMax. 300 W
AC 220 V to 240 VMax. 300 W
Power Consumption (Standby Mode)
AC 100 V to 120 V0.4 W (when “Standby mode” is set to “Low”)
AC 220 V to 240 V0.4 W (when “Standby mode” is set to “Low”)
Power Consumption (Networked Standby Mode)
AC 100 V to 120 V6.0 W (LAN) (when "Standby Mode" is set to "Standard")
AC 220 V to 240 V6.0 W (LAN) (when "Standby Mode" is set to "Standard")
Standby Mode / Networked Standby Mode Activated
Standby Mode / Networked Standby Mode ActivatedAfter about 10 Minutes
Dimensions (W x H x D)
Dimensions (W x H x D) (without protrusions)407.4 x 179.2 x 463.9 mm (16 1/8 x 7 1/8 x 18 3/8 inches)
Mass
Mass10 kg (22 lb)
Supplied accessories
Remote commanderRM-PJ23
Peter  012-2536225
Fong   016-3098668
BRANDED led tv
amplifier
speaker
cd player
Number of posts : 327
