Musical Fidelity A3.5 DUAL MONO INTEGRATED AMPLIFIER(SOLD)
Post by thw on Wed May 23, 2018 9:46 pm
Musical Fidelity A3.5 Dual Mono Pre Amplifier come with remote control.
Condition: 8.5/10. Item is in excellent condition. Comes with original remote control. Have very good soundstage, details and depth. Very good bass response, smooth and musical.
Price: sold
Contact/whatsapp 012-5503130 TONG
150 Watts per channel into 8 Ohms (22dBW),
240 Watts per channel into 4 Ohms
Voltage, RMS : 34 Volts 20Hz to 20kHz
Voltage, Peak-to-peak : 96 Volts
Current peak-to-peak : 50 Amps
Damping factor : 142
Output devices per channel : 4
Pre-out impedance : 50 Ohms
Line inputs :
Total harmonic distortion + noise, < 0.01%, 20Hz to 20kHz
Signal / noise ratio : > 100dB ‘A’-weighted
Input sensitivity for 147 Watts into 8 Ohms : 282mV
Input impedance : 100k Ohms
Overload margin : 26dB
Channel separation : > 82dB typical
Frequency response : 20Hz to 20kHz, +0, -0.1dB
Home Theatre direct input sensitivity : 30dB gain (31.5 times) nominal
Inputs : 5 pairs line level RCA connectors,
1 pair direct power amplifier input RCA connectors for
Home Theatre use (not controlled by volume adjustment)
Outputs : 2 amplifier channels via 1 pair binding posts per channel
1 pair RCA audio outputs controlled by the volume,
1 pair RCA tape record fixed line level output.
Last edited by thw on Sun Jun 03, 2018 6:57 pm; edited 2 times in total (Reason for editing : Sold)
thw
Number of posts : 20
Registration date : 2009-03-18
Source(s): Naim CD5i,Lenco L75
Amplification: Naim Supernait,Sansui AU70
Speakers: Sansui SP-3500,Xavian XN125,Sonus Faber Concertino
Re: Musical Fidelity A3.5 DUAL MONO INTEGRATED AMPLIFIER(SOLD)
Post by thw on Wed May 30, 2018 4:19 pm
Price reduce.
thw
