Cyrus Two & Cyrus PSX Power Supply
Post by superfi on Fri Jun 01, 2018 12:50 pm
The Cyrus Two set the standard for ultimate audiophile amplification in the British hifi industry. Designed to eliminate the extraneous aberrations caused by non-essential circuitry, the straight line Cyrus Two was “the” integrated amplifier for the purist.
Cyrus engineers have identified high current swing capability as being the most important criteria in amplifier design rather than mere wattage.  This is due to the reactive nature of loudspeakers requiring high currents rather than current-starved wattage.  Being able to deliver currents demanded by the loudspeaker readily ensures true reproduction of the complex musical signal.  At 50 Watts per channel, the Cyrus Two can swing a substantial current of 60 amps peak to peak, a remarkable achievement indeed!
As an additional bonus, the Cyrus Two also incorporates a truly refined moving coil phono stage with excellent noise figures and minimal hysteresis, designed to work esoteric cartridges often costing many times as much as the amplifier. This eliminates extra expense for a separate phono stage. Further, the direct CD input of the Cyrus Two eliminates unnecessary components that would otherwise interfere with the fidelity of compact disc reproduction. Coupled with the PSX dedicated power supply, you derived even great head-room with an increase of power and control - see specs below
Technical Specifications:
Continuous power – 50W/CH (both driven into 8 Ohms) 80W/CH (both driven into 4 Ohms)
Increased continuous power (with PSX connected) – 70W/CH (both driven into 8 Ohms) 125W/CH (both driven into 4 Ohms)
Frequency response (line input) – -3 dB, 1Hz and 50kHz
Frequency response (phono RIAA) – 20Hz – 20kHz ± 0.2dB
Input impedance – 14k (RCA), 47k (MM), 100k (MC)
Condition : Well taken care of by previous owner - condition 8/10 and performing well!
Price: Great value buy @ RM 3600 RM 3200 for both for a piece of highly regarded, honest British sound.
Please contact Greg at 011-39300083/03-76104466 or 012-2955266 (George) for inquiries or come audition them at our shop at APS, Lot 223 on the 2nd Floor, Amcorp Mall, Petaling Jaya
avatar
superfi
Number of posts : 371
Re: Cyrus Two & Cyrus PSX Power Supply
Post by superfi on Sat Jun 09, 2018 6:34 pm
bump.
avatar
superfi
