Linear Power Supply module upgrade for OPPO UDP-203
Post by actsessory on Thu Jun 07, 2018 2:27 pm
  • Non-Destructive-Modification of Linear Power Supply UPGRADE!
  • Specially developed for Oppo UDP-203
  • Custom made fully isolated toroidal transformer
  • Imported HiFi grade components
  • Meticulous craftmanship
  • Precision engineering
  • A comprehensive upgrade kit
  • OPT: Digital SILVER Version available!!
Fully isolated, HiFi-grade, ultra low noise non-destructive-modification linear power supply, specially developed for OPPO UDP-203
Zero-Zone is committed to developing a dedicated HiFi grade linear power supply upgrade.
Based on the serious HiFi grade components for audiophile as well as videophile performance.
An instant performance upgrade solution.
Oppo, and most dvd/bluray players stock power board is of SMPS (switch-mode power supply), due to their efficiency, low cost and ease of manufacturing.
SMPS provides high current, low and multiple voltages easily and cheaply.
They generate a lot RFI (radio frequency interference) at the switching frequency of the supply.
Linear Power Supply provides clean constant voltage and stable current at the output stage.
It provides isolation between the output and input because of the toroidal transformer.
5x made-in-Japan Nichicon audio capacitor as filtering cap structure array, matches with ultra low resistance stabilized power circuit.
A 50VA pure copper toroidal transformer tailored specifically for 203, optimized for low frequency density, strength and depth.
Schuter fuse folder for fuse changing to personal preferences.
Contributes outstanding processing power, constant voltage, stable current to your player.
Full HiFi audiophile grade components supplying juices to the analog decoding board, no longer sounding "tasteless"...
AV-phile grade components with meticulous craftmanship.
Price:  RM630
*  1 Year Local Warranty
*  Installation is provided upon request
************************THIS IS NOT THE END YET....****************************
The Digital SILVER Version non-destructive-mod of Linear Power Supply
Specially developed for Oppo UDP-203,  non-destructive modification of Linear Power Supply upgrade.
This digital silver version is more inclined to 4K bluray visual optimization.
Silver-plated pure copper transformer, specifically tailored for the 4K...
Secondary direct leads output to the power board.
High precision, ultra low ripple wave resistance, high speed stablized power supply module - specially tailored for digital circuit.
Imported HiFi grade components.
Made-in-Japan Nichicon KG TYPE II (FW) HiFi grade filtering capacitors.
Provides outstanding processing power, constant voltage, stable current for 203's digital part (motherboard)
4mm thickness aluminum full spec base, high strength, guaranteed heat dissipation
*The Digital SILVER Ver upgrade is fully optimized for digital power output, to the motherboard for digital input/outputs (HDMI, Coaxial, Optical, USB, Optical Drive)
**Thus the analog audio board (7.1 channel analog output) will be disabled, this will suit the users to have the best performance from the digital in/out while not using the analog outputs.
Price:  RM750
~~~OPTIONAL UPGRADE KITS:
i) Oppo dedicated IEC power upgrade kit. It's Pure Silver cable,  not silver-plated copper.
Made from Gold-plated power inlet IEC, pure silver cables.
ii) Oppo dedicated analog power upgrade kit
Made of silver-plated pure copper OCC cables, lead-free soldering.
iii) Oppo dedicated digital power upgrade kit
Made of silver-plated pure copper OCC cord, lead-free soldering.
Made for Oppo UDP-203 / 205
actsessory
Number of posts : 1287
http://www.actsessory.com
Re: Linear Power Supply module upgrade for OPPO UDP-203
Post by actsessory on Fri Jun 29, 2018 8:57 pm
actsessory
Post by actsessory on Tue Aug 21, 2018 12:17 pm
Standard version, without disabling the analog soundboard.
actsessory
Post by actsessory on Fri Sep 14, 2018 4:24 pm
Ready stock for 203, 103, 105, 103D, 105D, 93, 95 as well!
actsessory
Post by actsessory on Sun Jan 13, 2019 4:50 pm
actsessory
Post by actsessory on Tue Feb 19, 2019 1:06 pm
actsessory
