Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 Empty Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93
Post by actsessory on Thu Jun 07, 2018 2:55 pm
  • Non-Destructive-Modification of Linear Power Supply UPGRADE!
  • Specially developed for Oppo BDP-103D / 103 / 93
  • Custom made fully isolated toroidal transformer
  • Imported HiFi grade components
  • Meticulous craftmanship
  • Precision engineering
  • A comprehensive upgrade kit
  • OPT: Digital SILVER Version available!!
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 103s2_10
Fully isolated, HiFi-grade, ultra low noise non-destructive-modification linear power supply, specially developed for OPPO BDP-103D / 103 / 93
Zero-Zone is committed to developing a dedicated HiFi grade linear power supply upgrade.
Based on the serious HiFi grade components for audiophile as well as videophile performance.
Oppo, and most dvd/bluray players stock power board is of SMPS (switch-mode power supply), due to their efficiency, low cost and ease of manufacturing.
SMPS provides high current, low and multiple voltages easily and cheaply.
They generate a lot RFI (radio frequency interference) at the switching frequency of the supply.
Linear Power Supply provides clean constant voltage and stable current at the output stage.
It provides isolation between the output and input because of the toroidal transformer.
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 103s1_10
An instant performance upgrade solution.
A 50VA pure copper toroidal transformer tailored specifically for 103D / 103 /93, optimized for low frequency density, strength and depth.
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 103s3_10
Build of ELNA, Nichicon, Philips etc capacitors structure array involved in the performance tuning.
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 103s4_10
4mm thickness aluminum full spec base, high strength, guaranteed heat dissipation, relatively to the bearing of just PCB board.
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 103s5_10
Schuter fuse folder for fuse changing to personal preferences.
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 103s6_10
Contributes outstanding processing power, constant voltage, stable current to your player.
Full HiFi audiophile grade components supplying juices to the analog decoding board, no longer sounding "tasteless"...
AV-phile grade components with meticulous craftmanship.
Price:  RM580
*  1 Year Local Warranty
*  Installation is provided upon request
************************THIS IS NOT THE END YET....****************************
The Digital SILVER Version non-destructive-mod of Linear Power Supply
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 103d_210
Specially developed for Oppo BDP-103D / 103 / 93,  non-destructive modification of Linear Power Supply upgrade.
This digital silver version is more inclined to digital circuit optimization.
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 205_d211
Specifically tailored Silver-plated pure copper transformer
Secondary direct leads output to the power board.
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 103d_310
High precision, ultra low ripple wave resistance, high speed stablized power supply module - specially tailored for digital circuit.
Imported HiFi grade components.
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 103d_110
Provides outstanding processing power, constant voltage, stable current for 203's digital part (motherboard)
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 103d_410
*The Digital SILVER Ver upgrade is fully optimized for digital power output, to the motherboard for digital input/outputs (HDMI, Coaxial, Optical, USB, Optical Drive)
**Thus the analog audio board (7.1 channel analog output) will be disabled, this will suit the users to have the best performance from the digital in/out while not using the analog outputs.
Price:  RM750
~~~OPTIONAL UPGRADE KITS:
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 Psu_co13
i) Oppo dedicated IEC power upgrade kit. It's Pure Silver cable,  not silver-plated copper.
Made from Gold-plated power inlet IEC, pure silver cables.
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 6p_act11
ii) Oppo dedicated analog power upgrade kit
Made of silver-plated pure copper OCC cables, lead-free soldering.
iii) Oppo dedicated digitalg power upgrade kit (coming soon...)
actsessory
Number of posts : 1480
http://www.actsessory.com
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 Empty Re: Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93
Post by actsessory on Thu Jul 05, 2018 8:09 am
All these are from same owner..!
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 3_oppo10
With his BDP-93 upgraded with NuForce Extreme Edition sound board.
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 93b10
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 93_a10
actsessory
Post by actsessory on Sat Sep 01, 2018 9:28 am
actsessory
Post by actsessory on Thu Sep 27, 2018 3:44 pm
Ready stock
actsessory
Post by actsessory on Fri Dec 28, 2018 4:48 pm
Available
actsessory
Post by actsessory on Wed Feb 06, 2019 6:14 pm
Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93 Oppo_c10
actsessory
