Tandberg NORWAY 3002A Pre and 3006A 150 Watts Power Amplifier Combo
Post by HiFiLab on Thu Jun 07, 2018 9:55 pm
Made In Norway
MM & MC phono; Well-regarded MM section has switch selectable resistive & capacitive loading on rear panel. Controls incl. sub-sonic filter, loudness, defeatable tone controls, mono/stereo sw., balance. Surprisingly good quality headphone amp cleanly drives just about any 'phones with ease, incl. my high impedance Senn HD600s and Beyer DT880/600's.
REVIEW FOUND ONLINE:
"I have had a 3006A for about 25 years. I would characterize it as fast, hard hitting, slightly warm with extended highs and highly detailed and transparent mids."
TANDBERG 3002A CONTROL AMP SPECS:
Manufacturer: Tandberg Factory, Norway
Inputs: Phono MM: 1.0 mV (33/47/100  kOhms)
           Phono MC: 80 uV (150 Ohm)
           Radio: 140 mV (47 kOhm)
           Tape Monitor I: 140 mV (47 kOhm)
           Tape Monitor II: 140 mV (47kOhm)
           AUX: 140 mV (47 kOhm)
Phono equalization: RIAA: + 0.2 dB
THD (1 kHz): <0004% (20 Hz to 20 kHz/2 V)
Freq.response 20 Hz - 20 kHz (+0/-0,2)
Outputs: tape I and II tape: max. 7.5 V, AF-output: relative to 0004 %
Tone controls: bass at 50 Hz: + 10 dB, treble at 10 kHz: + 10 dB
W:(17.1”) x D:(13.78”) x H:(3.26”)
Weight approx: 13 lbs
TANDBERG 3006A AMPLIFIER SPECS:
Product of Norway
Year of Production:1984
Black Aluminium
Semiconductors: 8 pcs MOSFET
Amplifier:   2 x 150W @ 8 ohms THD (0.02%)
                2 x 220W @ 4 Ohms THD (<0.02%)
Freq.response : 20 Hz - 20 kHz (+0/-0,2) dB
Inputs-Single ended RCA: 5 Hz - 150 kHz (+0/-1.5) dB
Sensitivity: 80 mV
Speakers Impedence form 8 - 16 ohms 1 W/8 ohms: 98dB 150 W/8 ohm: 118dB
115, 230 Volt AC
Weight approx. 25 lbs
Price : RM 3550
HiFiLab
Number of posts : 2475
BUMP
Post by HiFiLab on Sat Sep 08, 2018 8:05 am
Up
HiFiLab
