NAD 3020i stereo Amplifier
Post by HiFiLab on Fri Jun 15, 2018 5:18 am
NAD 3020i is a improved version of well known 3020 from the list of Ten Most Significant Amplifiers of All Times. As usuall it will not surprise you by its look, or futures... but that is not what you buy it for. If you google it you will find that those babes are not cheap. The reason for that is.... ooh why should I answer, buy one and find out yourself.
SOUND
As soon as I have plugged it into the system and started music I realized one thing... The power rating is misleading. Honestly speaking this small amplifier can rock the block. Sounds are gentle all accross the frequency range. It is definately worth a lot... and deserves its reputation. Buy one and just listen... it will stay for ever in your system.
TECHNICAL SPECYFICATION
Model : 3020i
Continuous power output [W] :  2 x 20 at 8 Ohm
Frequency Response [Hz] :  20 - 20000
Preamplifier Section Input Impedance :  47 Kohm
THD :  <0.03%
High Level Input Impedance :  40Kohm
Controls :  Volume, Balance, Trable, Bass, Input selector
Phono preamp :  YES
Colour : Grey
Height x Width x Depth [mm] :  80 x 420 x 250
Weight [kg] : 5
Price : RM680
HiFiLab
Number of posts : 2475
BUMP
Post by HiFiLab on Sun Jun 24, 2018 4:31 am
UP
HiFiLab
