Marshal HDD Tower 4 3.5" External Hard Disk Case
Marshal HDD Tower 4 3.5" External Hard Disk Case Brand New. Now Selling At RM280. Free Shipping Within West Malaysia.
Technical Specifications
Features of 3.5-inch external hard disk case
Four built-in SATA 3.5 inch HDDs can be installed by adopting AC built-in type that responds to user requests
Four SATA 3.5 HDD can be used. Also, the AC adapter employs a built-in type that requires a lot of requests from users, so it does not get in the way, and you can use it as refreshing around the outlet.
Easy to expand with toolless threadless
SATA 3.5 HDD can be loaded and unloaded easily without tools. In addition, fixing of HDD can be fixed with a jig attached to a special tray, so it can be used with threadless.
* When using 2.5 inch HDD / SSD, it is necessary to fix with the attached screw.
A maximum of 40 TB is realized by supporting 10 TBHDD!
It is possible to use 4 SATA 3.5 HDD 10 TB, and you can use it for a total of 40 TB.
* To create volumes exceeding 2 TB Your OS supports GUID partitions (GPT)
There must be.
※ RAID function is not installed.
High-speed interface USB 3.0 and eSATA compatible
High-speed interface USB 3.0 and eSATA are supported. Video and photo data which has been taking time to transfer data can be transferred at high speed. It transfers at 2 to 4 times the speed of USB 2.0. Even with USB 2.0
You can use it. Moreover, it recognizes automatically without driver.
※ When connecting with USB 3.0, eSATA, USB 3.0, eSATA compliant IF and cable are necessary.
* When connecting with USB 2.0, the maximum transfer speed is 480 Mbps (theoretical value).
※ For transfer speed, it depends on hard disk performance.
Individual HDD power switch installed
It is possible to individually turn on / off the power of HDD / SSD that was built in. Even while using another HDD / SSD
You can use it by switching one by one, you can cut wasteful power.
* When changing the power with the individual HDD switch, be sure to turn off the power once with the POWER button on the front of the main body
Please switch individual HDD switch from. It may cause the HDD to malfunction.
Cool FAN installed
A cooling fan was installed. Cool down the heat of the drive, it can be used with stable operation. Also,
When turning off the PC's power it will automatically stop rotating.
Equipped with cooling fan which can change air volume
The air flow of the cooling fan can be switched easily with the switch. Switching of 4 steps (it is possible to stop rotation)
It is possible. Body is excellent in heat dissipation. Cool down the drive's heat, stable operation
Can be used with.
PC interlocking function installed
Since "PC power interlocking function" which stops the rotation of the HDD instantly when PC power supply is turned off is carried,
There is no use of wasted power.
BRANDED led tv
amplifier
speaker
cd player
There must be.
Cool FAN installed
Can be used with.
BRANDED led tv
amplifier
speaker
cd player
- Number of posts : 1250
» Marshal ML77P Floorstand Speaker -SOLD
» WTB - Lp/Vinyl/Record Case
» IsoAcoustics Carpet Disk II (8 Pcs)
» Chord Hugo with leather case
» Chord Mojo+Poly+Case (Used)
