Sony TA-F444ESX Extremely High Standard Stereo Integrated Amplifier with MM and MC
Made In JAPAN
This amp was built in the mid to late 80's and is highly respected for its great sound quality
Sony's first amp series to have its "Gibraltar Chassis" made from polyester, calcium and carbon to reduce chassis vibrations. (insane).
Part of the units designed by the first official ES team assembled as such in 1986. Incredible as it may seem but there was no such "fixed" team since... 1965 !
Sony's first units to sport the Gibraltar chassis made of polyester, calcium and carbon.
The F444ESX has a double output push-pull of Sanken A1186/C2897, high Gm FETs in the phono section, Great Supply ELNAs and, as always, an assortment of exotic Nichicon MUSE.
The big heatsink seems to have remained bare for the japanese and US models but anodized black for the european versions...
This thing comes in at 18.3Kg.
2 x 110w continuous Rms into 8 ohms (0.004% THD).
2 x 145w continuous Rms into 4 ohms (0.008% THD)
Impressive specs.
Magnificent audiophile machine from Sony’s Extremely High Standard division.
* A phono input with different cartridge load settings (MM & MC)
* 3 inputs for tape decks / multiple cd players can be hooked up here
* Speakers (4-16 ohms): A, B, A+B
Power output: 110 watts per channel into 8 ohm (stereo)
Frequency response: 2Hz to 200kHz
Total harmonic distortion: 0.004%
Damping factor: 100
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 84dB (MM), 105dB (line)
Output: 150mV (line)
Speaker load impedance: 4 ohm (minimum)
Dimensions: 430 x 160 x 436mm
Weight: 18.3kg
it sounds great. Very clean and smooth sounding; and completely quiet when no signal is present.
It powers my 86db Speaker wonderfully with plenty of power reserved
Price : RM 2450
- Number of posts : 2967
BUMP
Up
BUMP
UP
BUMP
Up
BUMP
Up
BUMP
Up
Up
» Sony TA-F333ESR Extreamely High Standard Stereo Integrated Ampifier with MM MC
» SONY TA-F444ESX Integrated Amplifier (Used) SOLD
» Sony TA F444ESX integrated amp (sold)
» Sony TA F444ESX Amplifier
» Myryad Z240 High-end Integrated Stereo Amplifier (Used)
