Denon AVR-X5200 11.2 Channel AV Receiver(Made in Japan)[Price Reduced]
Post by alvin_choong on Fri Jun 29, 2018 1:14 pm
Condition : 8.5/10
C/w original packaging, Calibration mic & stand(Paper type), power cord, user manual & Etc.
Price : RM3200 RM2750 (Sold)
Interested, Please contact me @ 016-240 8080 (Alvin)
Power & Processing :
  • 9-channel amplifier
  • 140 watts per channel into 8 ohm(20 Hz - 20 kHz, 0.05% 2ch Drive)
  • Dolby and DTS surround sound decoding
  • Dolby ATMOS processing with up to 7.1.4 configuration.
  • Audyssey Platinum speaker calibration and system optimization (Multi EQ XT32, Dynamic Volume, Dynamic EQ, Sub EQ HT & Low Frequency Containment)
  • Auro-3D built-in for three-dimensional soundfields with Auro-3D soundtrack mixes (supports up to a 10.1-channel configuration; The Auro-3D Upgrade can be purchased for £149)
Digital and Streaming Music Options :
  • Built-in Wi-Fi for listening to music from a networked PC and free internet radio
  • Includes support for Pandora, SiriusXM, and Spotify (subscription required for some services)
  • Will support Apple AirPlay for streaming from compatible iOS devices and multi-room music with compatible speakers and components
  • Built-in Bluetooth for wireless music listening with smartphones, tablets, and compatible computers.
  • Plays high-resolution digital music files via USB storage device or a networked computer (PCM up to 24-bit/192kHz resolution; DSD up to 5.6 MHz)
Multi Room Audio/Video :
  • Three-room/three-source output
  • Powered stereo outputs for second and third rooms allow playback in three rooms at once
  • Amp assign feature lets you reassign extra surround channels to second and third zones
  • Line-level outputs for Zones 2 and 3 for use with additional receiver, amplifier, or powered speakers
  • Independent HDMI outputs for watching video content from different sources in two zones simultaneously
  • Supports 2nd/3rd zone playback of digital sources
  • Composite video output can be assigned to Zone 2
Connection :
  • HDMI audio/video switching: 8 in (includes 1 front-panel input), 3 out
  • component video switching: 2 out (Zone 2)
  • composite video switching: 4 in, 2 out (includes 1 front-panel input)
  • digital audio inputs: 2 optical, 2 coaxial
  • 6 analog stereo RCA audio inputs
  • MM (moving magnet) phono input for connecting a turntable
  • 7.1-channel preamp inputs
  • 11.2-channel preamp outputs
  • two discrete line-level subwoofer outputs for more precise multi-subwoofer setups
  • front-panel USB port for audio playback from USB flash drives
  • Denon Link HD creates a jitter-free connection to compatible Denon Blu-ray players; requires HDMI connection and proprietary Denon Link RCA-style cable
  • Ethernet port for network connection
  • RS-232C port for use with external controllers
  • IR in/out and 12-volt triggers
  • 1/4" headphone jack
  • Removable power cord
General Feature :
  • 4K/60p and 3D video pass-through
  • Setup Assistant guides you through the initial connection process and settings
  • 4 quick select function buttons for one-touch power-up, source selection and recall of volume and Audyssey configuration
  • HDMI standby pass-through allows HDMI switching without powering up receiver
  • support for third-party control systems by Control4 for home automation
  • intuitive, full-color on-screen guide
  • bi-amp compatible front left and right speakers by reassigning Surround Back or Height channels
  • AM/FM tuner
  • remote control
  • Dimension (W x D x H) in mm : 434 x 383 x 167
  • weight: 14.2 Kg
alvin_choong
Regular
Regular
Number of posts : 87
Registration date : 2009-05-23
Denon AVR-X5200 11.2 Channel AV Receiver (Made in Japan)
Post by alvin_choong on Sun Jul 01, 2018 3:05 pm
Photo Edited
alvin_choong
Regular
Regular
Post by alvin_choong on Sun Jul 08, 2018 10:30 am
BUMP
alvin_choong
Regular
Regular
Re: Denon AVR-X5200 11.2 Channel AV Receiver(Made in Japan)[Price Reduced]
Post by alvin_choong on Thu Jul 12, 2018 11:01 am
Price Reduced to RM2750
alvin_choong
Regular
Regular
Post by alvin_choong on Thu Jul 12, 2018 11:02 am
Photo edited
alvin_choong
Regular
Regular
