Onkyo TX-SR252 5.1Ch Home Theatre System
Onkyo TX-SR252 5.1Ch Home Theatre System Empty Onkyo TX-SR252 5.1Ch Home Theatre System
Post by stylelaser.com.my on Mon Jul 23, 2018 2:44 pm
Onkyo TX-SR252 5.1 CH Home Theatre System Brand New. Now Selling At RM1,899. Free Shipping Within West Malaysia.
Onkyo TX-SR252 5.1Ch Home Theatre System Thumb_19     Onkyo TX-SR252 5.1Ch Home Theatre System Thumb_20
Onkyo TX-SR252 5.1Ch Home Theatre System Thumb_21     Onkyo TX-SR252 5.1Ch Home Theatre System Thumb_22
Onkyo TX-SR252
5.1-Channel A/V Receiver
Unlock the Full Movie Experience with Authentic 5.1 Sound
Soundbars definitely have their place, but if explosive surround sound is what you’re dreaming of—without an eye-watering price tag— check out the all-new TX-SR252. It serves as a next-gen 4K/60 Hz-ready hub for all your devices (game consoles, media streamers, VCRs, and BD players) and sends everything to your TV through a single cable. It can even be set up to switch on and off automatically with your regular TV remote. But best of all, its fully discrete analog amps immerse you in 100 W/Ch of clear and dynamic surround sound, whether it’s from your regular TV shows, DTS-HD Master Audio™-encoded Blu-rays, an AM/FM radio station, or MP3s played via the front USB. So if you’re set on fixing your flatscreen sound, do it properly and do it affordably with this compact A/V solution.
Key Features
  • HDMI® 4 In / 1 Out for UltraHD
  • Lossless High-Definition Movie Soundtracks
  • True Power from Discrete Amplifiers
  • Easy Connection Guide on Back Panel
  • Front USB Port for MP3, WMA, and AAC Playback
DM Dream Series X1 – 5.1 Speaker System
Home-Cinema-System with active subwoofer system
Onkyo TX-SR252
Features
HIGHLIGHTS
  • 100 W per Channel
  • HDMI® 4 In / 1 Out (4K UltraHD / HDCP 2.2 / 4:4:4 Color Space)
  • True Driving Power from Discrete Amp Circuits
  • USB Port for MP3/WMA/AAC Playback
  • Quality 192/24-bit DAC
AMPLIFIER FEATURES
  • 100 W/Ch (6 Ω, 1 kHz, 0.7% THD, 1 Channel Driven, IEC)
  • Discrete Output Stage Circuitry
  • Five-Channel Analog Amplifiers
PROCESSING FEATURES
  • HDMI Support for 4K/60 Hz, 3D, Audio Return Channel, DeepColor™, x.v.Color™, LipSync, Dolby® TrueHD, DTS-HD Master Audio™, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC
  • Dolby® TrueHD and DTS-HD Master Audio™ Decoding
  • 192 kHz/24-bit DAC for All Channels
  • SACD Playback via HDMI (2.8 MHz, 2 Channels)
  • Direct Mode
CONNECTION FEATURES
  • 4 HDMI Inputs and 1 Output
  • USB Port (Front) for Music Playback via Flash Drive
  • 2 Composite Video Inputs and 1 Output
  • 2 Digital Audio Inputs (1 Optical and 1 Coaxial)
  • 3 Analog Audio Inputs (3 Rear)
  • Subwoofer Pre-Out
  • Headphone Jack
OTHER FEATURES
  • A/V Sync Control (Up to 500 ms in 5 ms Steps at 48 kHz)
  • HDMI Passthrough Function
  • Tone Control (Bass/Treble)
  • 3-Mode Display Dimmer (Normal/Dim/Dimmer)
  • 30 FM/AM Random Presets
  • Full-Function RI (Remote Interactive) Remote Control
  • Sleep Timer
  • AM/FM with RDS
  • Dimensions: 435 x 168 x 326.5mm
  • Weight: 7.3kg
Type
Engineering Principle
Front, Center, Surround: 2-way closed system
Subwoofer: Bandpass system
Nom. /Music power handling
Front, Center, Surround: 100 watts
Musical output
Subwoofer: 100 watts
SPL (1 watt/1m)
85 dB
Frequency response
Front, Center, Surround: 120...25.000 Hz
Subwoofer: 38...140 Hz (adjustable)
Crossover frequency
Front, Center, Surround: 5.000 Hz
Subwoofer: 80...140 Hz (adjustable)
Woofer
Front: 1 x 80 mm (3.2''), Aluminum finish
Center: 2 x 80 mm (3.2''), Aluminum finish
Surround: 1 x 80 mm (3.2''), Aluminum finish
Subwoofer: 1 x 200 mm (8''), Aluminum finish
Tweeter
Front: 1 x 15 mm (1''), aluminum
Center: 1 x 15 mm (1''), aluminum
Surround: 1 x 15 mm (1''), aluminum
Special Features
Wall brackets included
Subwoofer:
Adjustable crossover frequency
Adjustable bass level
SC-technology
Nominal Impedance
4…8 ohms
Dimensions (WxHxD)
Front: 8.9 x 9 x 10.6 cm (3.5 x 3.5 x 4.2)
Center: 19.6 x 8.9 x 10.6 cm (7.7 x 3.5 x 4.2)
Surround: 8.9 x 9 x 10.6 cm (3.5 x 3.5 x 4.2)
Subwoofer: 23 x 38 x 42 cm (9.1 x 14.2 x 15.Cool
Weight
Front: 0.6 kg, Center: 1.3 kg, Surround: 0.6 kg
Subwoofer: 9.4 kg
Power consumption
0,42 Watt
Peter  012-2536225
Fong   016-3098668
Onkyo TX-SR252 5.1Ch Home Theatre System Trade
BRANDED led tv
amplifier
speaker
cd player
Number of posts : 592
