Bowers & Wilkin HTM 61 S2
Bowers & Wilkin HTM 61 S2 Empty Bowers & Wilkin HTM 61 S2
Post by SMARTECH on Tue Jul 24, 2018 3:22 pm
Bower & Wilkins have revised their 600 line of speakers, bringing in engineering from other ranges as well as advances specific to the series. The HTM61 S2 now features a decoupled double dome tweeter, ideal for delivering the clarity needed for dialogue. The double dome gives a more precise response, while unwanted resonances and vibration are removed by keeping the tweeter detached from the main body of the speaker. The HTM61 S2 also features two 6.5-inch bass drivers with aluminium cones, for a mix of power and precision.
Below the tweeter and between the two bass drivers is a Kevlar midrange driver. On the rear of the speaker are two "Flowport" bass ports. The speakers and bass ports work together to produce incredible audio across the entire frequency range. The HTM61 is a great centre speaker, ideally suited to delivering stunning big-screen action.
Bass port?2 x rear ports
Biwireable?Yes
Connections4mm banana plug/binding posts
Crossover frequency (kHz)400hz, 4khz
DriversHF: 25mm aluminium dome
MF: 100mm woven Kevlar cone
LF: 2 x 165mm aluminium cone
FinishBlack ash or white
Frequency response (Hz)38 - 22,000
Magnetically shielded?Yes
Nominal impedance (ohms)8
Recommended amp power (watts)30 - 150 (8 ohms RMS)
Sensitivity (dB)88
Supplied accessoriesRemovable front grilles, rubber pads
W x H x D (mm)590 x 218 x 304
Weight (kg)17.2
PLEASE CALL BRIAN 012-2589079 RM3000
SMARTECH
Club Member
Club Member
Number of posts : 29
Registration date : 2017-05-11
