Yamaha Restio ISX-803 Bluetooth Audio System
Yamaha Restio ISX-803 Bluetooth Audio System Empty Yamaha Restio ISX-803 Bluetooth Audio System
Post by stylelaser.com.my on Tue Jul 31, 2018 11:08 am
Yamaha Restio ISX-803 Bluetooth Audio System Brand New. Now Selling At RM2,899. Free Shipping Within West Malaysia.
Yamaha Restio ISX-803 Bluetooth Audio System Thumb_71     Yamaha Restio ISX-803 Bluetooth Audio System Thumb_70
ISX-803
Yamaha Restio ISX-803 Bluetooth Audio System CD-DigitalAudio_08_90x90_beccc6fc4924203dba6a2129eea23192   Yamaha Restio ISX-803 Bluetooth Audio System 23B079142B814435958DFBD13A13DA47_12024_90x90_b874399ce420a0e3af8c1c37d31310b2   Yamaha Restio ISX-803 Bluetooth Audio System 2ACD4FA64A514795A130896CFEC396FB_12024_90x90_6fefcbb01964f4cb51239e9391fe60b4   Yamaha Restio ISX-803 Bluetooth Audio System 3DAAD4AC00B14AEDBBCC2485C6EE7B64_12024_90x90_6c4f69997d7bd3360228ba748439cc97   Yamaha Restio ISX-803 Bluetooth Audio System Made_for_ipod_iphone_ipad_90x90_19e498ee51865f7980fc10bf7f87d5be   Yamaha Restio ISX-803 Bluetooth Audio System BE2320562C4940BAA8615FD5E45D2442_12024_90x90_35eccc7aa6581fea382ca9d364284870   Yamaha Restio ISX-803 Bluetooth Audio System 1310D3A44BE741E0A14CFF3F4F930A14_12024_90x90_f7a3b9c0d8f097644b99568125ff3bf4   Yamaha Restio ISX-803 Bluetooth Audio System 9B39781489F44170BD1FE6D1AE7557E3_12024_90x90_c45aaeb0d8af30108a805a7173f7aeae
Rest after your day with a new style audio.Entertaining and energising,it's an endlessly enchanting companion.Bluetooth compatibility makes operationand placement smartly convenient.Stylish and wireless — the new Restio.
Enjoy a Musical Interior
享受純音樂的本質
Yamaha Restio ISX-803 Bluetooth Audio System Feature_01_Enjoy-a-Musical-Interior_1200x464_5a58a326ccf7894dc04f7b33f0b630a6
With a sleek stand and minimal proportions, Restio looks like a work of art. It was created by completely re-imagining the concept of a music source as part of the interior. The independent body style makes music an interior design element, and because the sides are slanted, it appears to be a thin panel. The front grille uses expanded metal, providing an attractive texture.
The striped pattern printed underneath the grille conveys a feeling of depth, giving the impression that the music is coming from within the entire front surface. Merging beautifully into the living space, this is an entirely new audio form that you can match to your lifestyle.
輕巧的底架及極簡的比例,Restio 就如同一件藝術作品般。將音源視為空間的一部份,完全的重新構思。獨立機型使音樂以薄層面板呈現,並成為室內設計的元素之一。由於兩端採斜角設計,而帶來極具吸引力的質感。正面的鉍合金網格帶來具深度的感受,給予一種音樂似乎是從這完整方形表面而來的印象。完美地與生活空間融合,這是一個符合您生活風格的全新音響。
Freedom of Movement and Use
自由移動與使用
Yamaha Restio ISX-803 Bluetooth Audio System B2A6D68C7A974C4EAFD59B586ECC6361_12074_200x275_a984ad539e7f841980b1e86a57256532
Built-in Bluetooth® means that you can enjoy all the music from your iPhone, Android or Tablets wirelessly. Put your Restio wherever you want it, and use your smartphone as you usually do to operate the playback functions. In addition to operating the main unit, you can use Yamaha’s DTA Controller app to set the alarm time for each day of the week individually, as well as make detailed IntelliAlarm settings.
If you have an NFC-compatible device, simply hold it near the Restio, and the device syncs automatically. No annoying pairing settings to make—just a one-touch operation to connect or disconnect.
內建藍牙功能使您可無線連結 iPhone, Android 或平板。將您的Restio放置在您想要的地方,就像平常您使用智慧型手機般的操作播放功能。除了透過主機操作之外,您亦可使用Yamaha的DTA Controller app 控制應用設定週間每一天不同的鬧鈴時間,及進階的intelliAlarm智慧鬧鈴設定。若您有搭載支援NFC功能的裝置,只要將其放置在靠近Restio的地方,裝置便會自動同步。不需要做任何設定 - 只需透過觸控操作或取消連結功能。
Minimal Design Allows Flexible Placement
麻雀雖小,彈性俱佳
Yamaha Restio ISX-803 Bluetooth Audio System Feature_03_Minimal_Design_Allows_Flexible_Placement_1200x475_50ed7ba0c78bbf8c2658b3ed8117f1db
With a 9cm body and a half-moon shaped stand, you can position Restio right up against a wall. What’s more, the standalone style doesn’t require a shelf, so there are no restrictions on where you can put it. You can even remove the stand and hang it on a wall (requires an optional bracket AT-800). It’s the perfect way to match your music source to any room’s decor.
9公分長的機身和半月形的座架,你可以將Restio直立靠在牆邊。更重要的是,它的直立外型並不需要安裝另外的架子,因此你可以隨意放置毫無限制。您甚至可以移開座架將它掛在牆上 (它需要選配1個支架AT-800)。這是最能符合任何房間飾品的音源。
讓你愛上音樂的聲音
Sound That Lets You Appreciate Music
Yamaha Restio ISX-803 Bluetooth Audio System C6D05E2DEA6E4D4997D48FC19C366A3F_12074_400x507_bb0d8b486fbe32d38f5556a8f57a1619
Restio is designed for premium quality sound from a wide range of input sources, including Bluetooth, CD, Radio, USB and AUX input. A two-way, four-speaker system fi nely tuned to HiFi audio standards delivers powerful, expansive bass and crisp, precisely contoured treble. It also features a three-band equaliser, so you can adjust the sound to match your own preferences.
Restio 為能呈現來自任何音源輸入之極佳音質而設計,包含藍牙、CD、廣播、USB及音源輸入。二音路,搭載四組揚聲單體的系統,以HiFi音響標準完美調音,並傳遞強力、具延展性的低音及清晰、精準的高音輪廓。同時也搭載三段等化器,因此您可依您偏好調整音質。
Time — Artistically Displayed
時間 - 顯示的藝術
Yamaha Restio ISX-803 Bluetooth Audio System 4E47BF6256234AB4839EC7D529E7BD7D_12074_400x307_9553baaf6de25821788fbbb7e6034026
The stylish digital clock gives you a choice of two patterns: the usual number display and a unique display that combines numbers and an indicator. An auto dimmer function adjusts the brightness of the display to match the brightness of the room. It also features Yamaha’s IntelliAlarm, which first gently plays the music of your choice and then beeps to ensure that you are fully awake.
時尚有型的數位時鐘能讓你從兩種模式中任意挑選:一般型數字螢幕和結合數字和指標的獨創時鐘,其自動調光功能能調節顯示的亮度並適度搭配房間的亮度。
此外,它也有山葉的IntelliAlarm設計,會先輕柔播放您挑選的音樂,然後發出蜂鳴聲,確保您完全清醒。
Dimensions
尺寸
Yamaha Restio ISX-803 Bluetooth Audio System ISX-803_dimensions_900x372_d47dc09dd45616e868206daab87cb88c
Peter  012-2536225
Fong   016-3098668
Yamaha Restio ISX-803 Bluetooth Audio System Trade
Yamaha Restio ISX-803 Bluetooth Audio System Thumb_73     Yamaha Restio ISX-803 Bluetooth Audio System Thumb_72
Specification
Bluetooth Version/Profile Ver. 3.0 (A2DP)
Audio Codec SBC, AAC, aptX®️
Maximum Communication Range 10 m/38 ft. 10in. (without interference)
NFC Yes
CD Audio CD, MP3, WMA
USB MP3, WMA
Tuner FM
Preset Memory 5 x FM
Input Terminal 3.5 mm STEREO mini Jack
Alarm Alarm, Snooze, Sleep
Speaker Unit Dual 3cm soft dome tweeters, Dual 10 cm woofers
Power Supply AC
Dimensions (W x H x D) 410 x 997 x 295 mm; 16-1/8" x 39-1/4" x 11-5/8" (with Stand) / 410 x 410 x 85.7mm (without Stand)
Weight 12 kg; 26.5lbs. (with Stand) / 6.44 kg (without Stand)
Colours Black
Number of posts : 557
