Marantz SR5007 SOLD
Marantz SR5007 SOLD
Marantz SR5007(used)
7.2-channel home theater receiver
Highlights:
Power and Processing:- 7-channel amplifier
- 100 watts per channel into 8 ohms (20-20,000 Hz) at 0.08% THD, with 2 channels driven
- Dolby TrueHD, DTS-HD Master Audio, Dolby Digital Plus, DTS-HD High Resolution Audio, Pro Logic IIz, and DTS Neo:6
- Audyssey Laboratories' MultEQ auto setup and room calibration system (microphone included)
- M-DAX (Marantz Dynamic Audio eXpander) for better sounding MP3s and other digital music files
Digital Music Options:
- built-in Apple AirPlay for ultra-convenient iTunes music playback
- direct digital connection of iPod/iPhone via the front-panel USB port bypasses your player's digital-to-analog converter for better sound
- Ethernet port for music and JPEG streaming from a wired PC network, and control via a PC
- DLNA (Digital Living Network Alliance) certified to ensure optimal compatibility with other DLNA-enabled equipment
- access Internet radio stations and digital streaming services (broadband connection required)
- optional streaming services include VTuner Internet radio, SiriusXM Internet radio and Pandora Internet radio (registration and subscription may be required)
- wireless Bluetooth capability with optional Marantz Bluetooth receiver
Multi-room Audio:
- dual-room/dual-source output
- powered stereo audio output for 2nd room
- using powered 2nd-room output allows 5.1 home theater in main roomoptical/coaxial digital and HDMI audio sources are not output to Zone 2
- USB and network-connected sources cannot be played back in different Zones at the same time
Audio Performance Features:
- 192kHz/24-bit digital-to-analog converters for all channels
- direct mode switches off unnecessary circuitry to provide cleaner sound
- detachable power cord
Connections:
- 1080p-compatible HDMI digital video switching (6 in, 1 out)
- HDMI version 1.4 with support for 4K, 3D video, Audio Return Channel, Deep Color, x.v.Color, auto lip-sync, and HDMI-CEC
- Audio Return Channel function receives digital audio signals from a compatible HDTV's tuner via HDMI
- component video switching (2 in, 1 out)
- composite video switching (3 in, 1 out)
- digital audio inputs: 2 optical and 2 coaxial
- 1 audio-only input
- no phono input — to connect a turntable you'll need to add a phono preamp
- 7.1-channel analog audio preamp input
- 7.2-channel analog audio preamp outputs
- preamp outputs for 2 powered subwoofers
- RS-232C port for automated control systems
- direct IR flasher input
- 1 pair of main speaker outputs
General Features:
- on-screen display for easier system setup and operation (via HDMI only)
- first-time setup assistant
- free Marantz remote app lets you use your iPod touch, iPhone or Android device as a Wi-Fi remote
- sleep timer
- HDMI standby pass-through allows HDMI switching without powering up receiver
- 56 AM/FM presets
- multibrand remote
- 17-5/16"W x 6-5/16"H x 14-3/8"D
- weight: 22.3 lbs.
Conditions: 7/10 (USED)
Last edited by choyaudiovisual on Sun Oct 28, 2018 2:23 pm; edited 1 time in total
- Number of posts : 5622
Re: Marantz SR5007 SOLD
reload
» Marantz SR5007 (Sold)
» Marantz SR5007 AV Receiver (SOLD)
» Marantz SR5007 7.2 Channel (Sold)
» Marantz SR5007 A/V Receiver (USED) SOLD
» Marantz SR5007 7.2Ch Av Receiver With AirPlay (Sold Out)
