Denon AVR-X2500H 7.2Ch Atmos Network AV Receiver
Denon AVR-X2500H 7.2Ch Atmos Network AV Receiver Brand New. Now Selling At RM3,499. Free Shipping Within West Malaysia.
DOLBY ATMOS
DTS:X
DTS VIRTUAL: X
LATEST HDMI SPECS
ADVANCED VIDEO SECTION
HDR / DOLBY VISION
AUDYSSEY MULTEQ XT
CONNECTIVITY
APP CONTROL
Stream music stored on your home network–connect to HEOS wireless speakers or even other HEOS-enabled receivers and listen throughout the whole house. Enjoy music from TuneIn, Internet Radio, Pandora:registered:, Spotify:registered:, Amazon Prime Music, iHeartRadio, SiriusXM, Soundcloud:registered:, Tidal, Napster or Deezer.
串流播放存储在家庭网络的音乐——连接到HEOS无线扬声器或甚至其他HEOS兼容接收机,在家里的任何地方收听。欣赏来自TuneIn 的音乐。
The AVR-X2500H features IP control capability for an integration with major third-party control devices and Control4 SDDP (Simple Device Detection Protocol) certification for quick and easy integration with Control4 home automation equipment. For direct connection to external home automation and control equipment, it's also equipped with an RS-232C serial port.
For simpler integrated control set-ups, the AVR-X2500H features an IR (infrared) remote control input on the rear panel, allowing remote control compatibility with other components in your home theater system.
AVR-X2500H具有IP控制功能,可集成大多数第三方控制设备, 可快速、简单地与家庭自动化设备整合。为了直接连接外部家庭自动化和控制设备,它还配备了一个RS-232C串行端口。
为了简化集成控制设置,AVR-X2500H在后面板上拥有IR(红外)遥控输入,与家庭影院系统的其他组件具有遥控兼容性。
Channels 7.2
Output Power 95 W per channel @ 8 Ohms, 20 Hz to 20 kHz, 0.08% THD
Object-Based Audio Support Dolby Atmos (up to 5.1.2), DTS:X (up to 5.1.2), DTS Virtual:X
Video
Pass-Through 4K/60 Hz, 4:4:4 color resolution, HDR10, HLG, Dolby Vision, and BT.2020
HDCP Version 2.2
Connectivity
Tuner AM / FM
Wireless Connectivity Bluetooth, dual-band Wi-Fi, Apple AirPlay
Inputs 8 x HDMI (1 front)
2 x optical TOSLINK
1 x digital coaxial
1 x component video
2 x composite video
5 x stereo RCA audio (1 phono)
1 x USB (front)
Outputs 2 x HDMI
1 x component video
1 x composite video
2 x subwoofer pre-out
1 x Zone 2 stereo pre-out
1 x 1/4" / 6.35 mm headphone out (front)
Other Ports 1 x setup microphone input (front)
2 x Wi-Fi / Bluetooth antennas
1 x FM antenna
1 x AM antenna
1 x Ethernet
1 x 1/8" / 3.5 mm IR remote in
1 x 1/8" / 3.5 mm IR remote out
1 x RS-232C
Speaker Connectors 7 x color-coded, 4-way binding post pairs
HDMI CEC Yes
General
On-Screen Display Yes
Power Requirements Not specified by manufacturer
Dimensions (W x H x D) 17.1 x 6.6 x 13" / 434 x 67 x 329 mm
Weight 20.7 lb / 9.4 kg
FEATURES- AVR-X2500H
7.2 Ch. 4K AV Receiver with Amazon Alexa Voice ControlOverview
The Denon AVR-X2500H supports Dolby Atmos:registered:, DTS:X:tm: and DTS Virtual:X:registered:, plus the latest video technologies such as Dolby Vision:tm:, HDR, HLG and 4K video upscaling. It features 8 HDMI inputs and 2 outputs with HDCP 2.2 on all HDMI ports. Stream Spotify:registered:, Pandora:registered:, Tidal and more with HEOS multi-room wireless technology, play music in multiple rooms and control it all with your voice through Amazon Alexa compatibility. Ideal for custom integrations, the AVR-X2500H is the entertainment centerpiece to help you build your perfect home theater. With more than 100 years of audio excellence at Denon, true audio-enthusiasts are guaranteed the best quality sound.产品特点 – AVR-X2500H
7.2声道4K AV接收机概述
Denon AVR-X2500H支持Dolby Atmos:registered:、DTS:X:tm:和DTS Virtual:X:registered:以及最新的视频技术,比如Dolby Vision:tm:、HDR、HLG和4K视频升频。它配备8个HDMI输入端口和2个输出端口,所有HDMI端口均支持HDCP 2.2。 等采用HEOS多房间无线技术,在多个房间播放音乐。 AVR-X2500H是自定义集成的首选,是娱乐的核心设备,帮助您创建完美的家庭影院。Denon投身于卓越音响已有100多年历史,为真正的音频发烧友带来最佳音质。POWERFUL 7.2 CHANNEL AMPLIFIER WITH THE LATEST HOME CINEMA SPECS
Featuring discrete high-current amplifiers on all channels, the AVR-X2500H delivers high-power performance at 95 watts per channel (8ohms, 20Hz-20kHz, 0.08% THD). Low impedance drivers provide operational stability for a wide range of speakers and create balanced, tonal sound. The AVR-X2500H features three-dimensional sound formats Dolby Atmos, DTS:X and DTS Virtual:X, plus an HDMI section with HDCP 2.2 support and advanced video processing with 4K upscaling for HDMI sources.具备最新家庭影院规格的7.2声道放大器
AVR-X2500H的所有声道都配备分离式高电流放大器,每声道具有95瓦的高功率性能(8 Ω,20Hz-20kHz,0.08% THD)。低阻抗驱动器为各种扬声器提供工作稳定性,并形成平衡、调和的声音。AVR-X2500H支持立体声格式Dolby Atmos、DTS:X和DTS Virtual:X,其HDMI部分支持HDCP 2.2,另外还配置将HDMI源升频至4K的高级视频处理功能。BLOCKBUSTING 3D-SOUND
Surround yourself in cinema-grade sound from literally any direction.DOLBY ATMOS
SOUND IN THE RIGHT PLACE
Feel every dimension in Dolby Atmos. Dolby Atmos transports you into the story with moving audio that flows all around you with breathtaking realism. Enjoy a 5.2.2 surround sound speaker system including 2 overhead speakers or 2 Dolby Atmos elevation speakers for the ultimate home theater experience - including Dolby Surround upmixer for legacy content.正确到位的声音
全方位感受杜比环绕声。杜比全景声通过具有惊人真实性的环绕移动音频,让您随剧情身临其境。5.2.2环绕声扬声器系统包括2个顶置扬声器或2个杜比全景声高位扬声器,可享受终极家庭影院体验——包括用于传统内容的杜比环绕声上混频器。DTS:X
BE CLOSER TO THE ACTION
DTS:X:tm: immersive audio places sound where it would occur naturally in space, creating a lifelike, multi-dimensional audio experience in the home. The improved immersion and heightened realism draw you into the world of your favorite movies. The included DTS Neural:X:tm: gives your movies, games and music a realism unmatched by traditional 5.1 surround sound.正确到位的声音
全方位感受杜比环绕声。杜比全景声通过具有惊人真实性的环绕移动音频,让您随剧情身临其境。5.2.2环绕声扬声器系统包括2个顶置扬声器或2个杜比全景声高位扬声器,可享受终极家庭影院体验——包括用于传统内容的杜比环绕声上混频器。DTS VIRTUAL: X
LIFE-LIKE SOUND WITHOUT DEDICATED HEIGHT SPEAKERS
DTS Virtual:X provides immersive audio without height channels, creating virtual height effects in a 5.1, 7.1 or 2.1 speaker arrangement.无需专用纵向扬声器即可产生逼真音效
DTS Virtual:X通过5.1、7.1或2.1扬声器结构产生几乎纵向的效果,无需纵向声道即可提供沉浸式音效。GEARED UP FOR 4K ULTRA HD
Enjoy ultra-high-definition pictures, from both analog and digital SD sources.预升级4K超高清
欣赏模拟和数字SD源的超高清图像。LATEST HDMI SPECS
THE LATEST VIDEO TECHNOLOGY
The latest HDMI specs for the best home theater experience. All eight HDMI inputs — and two HDMI outputs — feature HDCP 2.2 support that lets you enjoy copy-protected content uninhibited. Watch movies and shows with 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub-sampling, Dolby Vision, High Dynamic Range (HDR10), Hybrid Log-Gamma (HLG) and 21:9 video, 3D, and BT.2020 pass-through support for exceptional color, clarity and contrast.最新的视频技术
最新的HDMI规格提供最好的家庭影院体验。全部八个HDMI输入 — 外加两个HDMI输出 — 支持HDCP 2.2,让您欣赏版权保护内容不受限制。支持4K超高清60Hz视频、4:4:4纯色子采样、Dolby Vision、高动态范围(HDR10)、Hybrid Log-Gamma(HLG)以及21:9视频、3D和BT.2020直通,让您欣赏到颜色、清晰度和对比度非常出色的电影和节目。ADVANCED VIDEO SECTION
BREATHE NEW LIFE INTO LEGACY SOURCES
The AVR-X2500H boasts an advanced video processor to upscale existing lower resolution video from any analog or digital source to true 4K. With three HDMI outputs, you can even connect a TV and a projector in the main room, while playing back different content on a second zone screen.HDR / DOLBY VISION
NEXT GENERATION VIDEO FORMATS
The AVR-X2500H supports High Dynamic Range (HDR) video format. It is even ready for Dolby Vision and HLG (Hybrid Log Gamma). Dolby Vision transforms the viewing experiences with astonishing brightness, contrast, and color. HLG offers HDR technology over broadcast content.下一代视频格式
AVR-X2500H支持高动态范围(HDR)视频格式。 Dolby Vision和HLG (Hybrid Log Gamma)。 Dolby Vision以令人惊叹的亮度、对比度和色彩转变人们的观看体验。HLG在广播内容上提供HDR技术。SET-UP AND CONNECT WITH EASE
Get your AVR-X2500H up and running in no time, perfectly tailored to your needs.设置和连接极其方便
安装好AVR-X2500H后很快就能运行,完全按您的需求定制。SMART TV CONNECTIVITY
Control your Denon AVR-X2500H with your Smart TV remote via the HDMI CEC functionality associated with your Smart TV. Simply set “HDMI Control” to ON in your receiver, then set “Smart Menu” to ON and begin controlling the AVR-X2500H with your TV remote. The Smart Menu home screen provides you quick access to source and surround mode selections, the AVR's setup menu and four Smart Selects.智能电视连接能力
通过与智能电视相关联的HDMI CEC功能,使用智能电视遥控器控制Denon AVR-X2500H。只需在接收器上将“HDMI控制”设为“ON”,接着将“智能菜单”设为“ON”,即可使用电视遥控器控制AVR-X2500H。智能菜单主屏幕上提供了音源和环绕模式选择、AVR设置菜单以及四个智能选择的快速访问方式。AUDYSSEY MULTEQ XT
CUSTOMIZED SOUND FOR ANY ROOM
The AVR-X2500H features the Audyssey MultEQ room acoustic measurement system. With the supplied microphone, it precisely analyzes the output of each speaker to optimize every channel. Plus, the additional Audyssey MultEQ Editor app (available for purchase) allows advanced users to go "under the hood" for further adjustment and customization of your audio environment.为每一间房间定制声音
AVR-X2500H具有Audyssey MultEQ XT室内声音检测系统。可使用附带的麦克风精准分析每个扬声器的输出,使每个声道达到最佳效果。此外,高级用户可以使用额外的Audyssey MultEQ编辑器应用程序(可购买),“在后台”对您的音频环境进行进一步调整和自定义。CONNECTIVITY
BUILT-IN BLUETOOTH, WI-FI AND AIRPLAY CAPABILITY
The heart of your wireless network. With Bluetooth and Wi-Fi wireless streaming connectivity, the Denon AVR-X2500H is equipped with an advanced dual antenna transceiver system for robust streaming even in congested urban environments. Enjoy listening to your favorite audio content wirelessly from your smart devices.内置蓝牙、WI-FI和AIRPLAY功能
您无线网络的核心。Denon AVR-X2500H具备蓝牙和Wi-Fi无线流媒体连通性,并配备高级双天线收发器系统,即使在拥挤的城市环境,也能提供极可靠的串流传输。通过无线方式聆听智能设备播放的音频内容。APP CONTROL
EVERYTHING UNDER CONTROL
Better control in your back pocket. The free Denon AVR Remote app for iOS and Android makes using the AVR-X2500H even easier — adjust volume, turn it on or off, mute the music, select a source or switch to HEOS. Download the free Denon Remote app to your smartphone today.一切尽在掌控中
更好的控制在您的背包中。适用于iOS和Android的免费Denon AVR Remote应用程序使AVR-X2500H使用更加方便——调节音量、开机或关机、使音乐静音、选择音源或切换到HEOS。今天在您的智能电话中下载免费的Denon Remote应用程序。QUICK SELECTS FOR USER-FRIENDLY AUDIO TUNING
The Denon AVR-X2500H front panel features four Quick Select buttons that store your preferred audio settings for each source. Switch between TV audio, Blu-Ray, media players and more–and the AVR-X2500H adjusts the EQ settings to your preferences for that media source. Use the buttons on the front panel or opt for the same Quick Selects on the AVR remote for faster control.用户友好的音频调试快速选择
Denon AVR-X2500H前面板配备四个快速选择按钮,可储存不同源的首选音频设置。在电视音频、蓝光、媒体播放器及其他音源之间切换,而且AVR-X2500H将按照您的偏好调节不同媒体音源的EQ设置。使用前面板按钮或在AVR遥控器上选择相同的快速选择键进行快速控制。ADVANCED SOUND PROCESSING
Experience extraordinary sound quality from both music and movies.高级声音处理
体验来自音乐和电影的非凡音质。ENJOY SUPERB AUDIO FIDELITY
Discover the incredible fidelity of high-resolution audio tracks and enjoy music as the artist intended. The AVR-X2500H has the ability to decode multiple lossless file types, including ALAC, FLAC, WAV (up to 24-bit/196-kHz) as well as DSD 2.8MHz and 5.6MHz tracks (the audiophile format of SACD). Listen to high-resolution audio through network connected devices like your PC or NAS, or from a USB connected device.欣赏超凡的音频保真度
见识高解析度音频曲目难以置信的保真度,欣赏艺术家原本展现的音乐。AVR-X2500H可以解码多种无损文件类型,包括ALAC、FLAC、WAV(高达24位/196-kHz)以及DSD 2.8MHz和5.6MHz曲目(SACD音响发烧友格式)。通过网络连接设备(如PC、NAS)或从USB连接设备收听高解析度音频。GET THE AMAZING HEOS EXPERIENCE
Enjoy your favorite music in any room of your home wirelessly with built-in HEOS technology. Play the same song in every room, or select a different song for each connected room — the choice is yours. Also works with Amazon Alexa providing cutting-edge voice control and incredible sound for all of your home entertainment–or control it all with the free HEOS app.Stream music stored on your home network–connect to HEOS wireless speakers or even other HEOS-enabled receivers and listen throughout the whole house. Enjoy music from TuneIn, Internet Radio, Pandora:registered:, Spotify:registered:, Amazon Prime Music, iHeartRadio, SiriusXM, Soundcloud:registered:, Tidal, Napster or Deezer.
获得惊人的HEOS体验
使用内置HEOS技术,在家里的任何房间通过无线方式欣赏自己喜爱的音乐。在每个房间播放同一首歌,或为每个连通的房间选择不同的歌——选择权在您手里。还能 使用免费的HEOS应用程序进行控制。串流播放存储在家庭网络的音乐——连接到HEOS无线扬声器或甚至其他HEOS兼容接收机,在家里的任何地方收听。欣赏来自TuneIn 的音乐。
EXTERNAL CONTROL AND IP CONTROL CAPABILITIES
The AVR-X2500H is part of Denon's range of IN·Command series of custom integration friendly AV components, equipped with feature-rich enhanced control capabilities and compatibility with third-party and custom integration solutions.The AVR-X2500H features IP control capability for an integration with major third-party control devices and Control4 SDDP (Simple Device Detection Protocol) certification for quick and easy integration with Control4 home automation equipment. For direct connection to external home automation and control equipment, it's also equipped with an RS-232C serial port.
外部控制和IP控制能力
作为Denon定制集成友好AV组件IN·Command系列中的一员,AVR-X2500H配备一系列功能,提供增强的控制能力和与第三方和定制集成解决方案的兼容性。AVR-X2500H具有IP控制功能,可集成大多数第三方控制设备, 可快速、简单地与家庭自动化设备整合。为了直接连接外部家庭自动化和控制设备,它还配备了一个RS-232C串行端口。
Channels 7.2
Video
HDCP Version 2.2
Connectivity
Tuner AM / FM
2 x optical TOSLINK
1 x digital coaxial
1 x component video
2 x composite video
1 x USB (front)
Outputs 2 x HDMI
1 x component video
1 x composite video
1 x FM antenna
1 x AM antenna
1 x Ethernet
1 x RS-232C
HDMI CEC Yes
General
- Number of posts : 1250
» Denon AVC-X6500H 11.2 Ch Atmos Network Av Receiver
» Denon AVR-S750H 7.2CH Atmos Network AV Receiver
» Denon AVR-X1800H 7.2Ch Atmos Network AV Receiver
» Denon AVR-S760H 7.2Ch 8K Atmos Network AV Receiver
» DENON AVR3300 7.2 ATMOS Network AV Receiver NEW
