Klipsch RP-8000F Floorstanding Speaker
Klipsch RP-8000F Floorstanding Speaker Empty Klipsch RP-8000F Floorstanding Speaker
Post by stylelaser.com.my on Thu Aug 09, 2018 1:52 pm
Klipsch RP-8000F Floorstanding Speaker Brand New. Now Selling At RM6,999. Free Shipping Within West Malaysia.
Klipsch RP-8000F Floorstanding Speaker Es_kli27      Klipsch RP-8000F Floorstanding Speaker Es_kli26
Klipsch RP-8000F
The Klipsch RP-8000F floorstanding speaker delivers incredible cinematic sound by leveraging our proprietary Tractrix® horn-loaded technology and dual 8" copper-spun Cerametallic™ woofers.
Features:
  • 1” Titanium LTS Vented Tweeter with Hybrid Tractrix® Horn
  • Dual 8" Spun Copper Cerametallic™ Woofers
  • Bass-Reflex via Rear-Firing Tractrix® port
  • Dual binding posts for bi-wire/bi-amp
  • Dimensions: 43.12” x 10.90” x 17.56”
HYBRID TRACTRIX® HORN TECHNOLOGY
Klipsch proprietary Tractrix® horn loading technology ensures high-frequency energy of the RP-8000F floorstanding speaker is aimed directly at the listener and reduces unwanted, artificial reverb caused by indirect sound bouncing off walls - meaning you experience the most clear, detailed, lifelike sound possible.
HORN ANATOMY
Klipsch Reference Premiere series speakers feature a compressed molded silicon face thats matted to the 90x90 Tractrix horn to reduces horn resonance for a smoother frequency response. Klipsch computer modeled phase plugs acts as a mechanical filter to further ensure a smooth, flat frequency response while protecting the tweeter from damage.
ALL-NEW VENTED TWEETER
Klipsch titanium tweeter diaphragms delivers a smooth high-frequency reproduction thanks to the material’s light weight yet rigid composition that exceeds the performance of aluminum, polymer or silk tweeters.
Our award-winning Linear Travel Suspension technology leverages a pistons motion of the titanium diaphragm that lowers distortion and delivers real-to-life sound.
Housed in a ceramic magnet structure for premium performance, Klipsch Reference Premiere tweeters set the standard in acoustic reproduction.
CERAMETALLIC™ WOOFERS
Klipsch Proprietary Cerametallic™ woofers are the RP-8000F floorstanding speaker signature statement for both sound and aesthetics. This extremely light, rigid materials holds its shape while being able to deliver lower frequencies with maximum efficiency.
WOOFER ANATOMY
Klipsch Cerametallic™ cones are matted to a dual-layer, copper-wound voice coil for exceptional conductivity.
Reference Premiere woofers are housed in a non-resonating, stamped-steal basked that’s secured to a large magnet motor for exceptional efficiency and low distortion thats matched to our horn-loaded tweeters for optimal acoustic execution.
TRACTRIX® PORT + DUAL TERMINALS
The rear Tractrix port is perfectly matched to the cabinet and woofers, creating ideal airflow with minimal distortion or turbulence even at the lowest frequencies.
The RP-8000F floorstanding speaker features dual input terminals so you can bi-wire or bi-amp your speakers for a custom, high-performance experience.
FINISHED TO PERFECTION
The RP-8000F ebony and walnut finishes boast satin painted baffles with a scratch resistant design. The cast aluminum feet provides a modern look with less resonance than MDF or ABS plastic. It is mechanically designed to minimize surface area in contact with the floor, decoupling the speaker for faster, tighter low frequencies and more detail.
Klipsch RP-8000F Floorstanding Speaker Es_kli28      Klipsch RP-8000F Floorstanding Speaker Es_kli29
Peter  012-2536225
Fong   016-3098668
Klipsch RP-8000F Floorstanding Speaker Trade
Specification
Power consumption: 150 W RMS / 600 W peak
Measurements
Sensitivity: 98 dB (2.83 V to 1 m)
Nominal impedance: 8 Ohms
Cutoff frequency: 1750 Hz
Frequency response: 32 Hz to 25 kHz
Grave loudspeakers : 2x 200mm Cerametallic cone speakers
Acute: 25mm diameter titanium diaphragm speaker and tuned compression chamber, mounted on Tractrix Hybrid square horn, with horizontal and vertical diffusion angles 90
Technology
Charged by bass-reflex resonator, with rear laminar vent Tractrix
General information
Single terminal block and magnetic acoustic grid
Dimensions (W x H x D): 277 x 1095 x 446 mm
Weight: 27,2 kg (each)
Number of posts : 575
