Klipsch RP-500C Reference Premier Center Speaker
Klipsch RP-500C Reference Premier Center Speaker Empty Klipsch RP-500C Reference Premier Center Speaker
Post by stylelaser.com.my on Thu Aug 09, 2018 3:11 pm
Klipsch RP-500C Reference Premier Center Speaker Brand New. Now Selling At RM2,299. Free Shipping Within West Malaysia.
Klipsch RP-500C Reference Premier Center Speaker Es_kli30      Klipsch RP-500C Reference Premier Center Speaker Es_kli31
Klipsch RP-500C
Get crystal-clear sound for your movie dialogue and music lyrics with the incredible acoustics of the Klipsch RP-500C center channel speaker. Our proprietary Tractrix® horn-loaded technology gives you a lifelike, front-row listening experience unlike any other.
Features:
  • 1” Titanium LTS Vented Tweeter with Hybrid Tractrix® Horn
  • Dual 5.25" Spun Copper Cerametallic™ Woofers
  • Bass-Reflex via Rear-Firing Tractrix® port
  • Premium Scratch Resistant Ebony and Walnut Finishes
  • Dimensions: 6.81” x 18.50” x 9.5”
HYBRID TRACTRIX® HORN TECHNOLOGY
Klipsch proprietary Tractrix® horn-loaded technology ensures high-frequency energy of the RP-500C center channel speaker is aimed directly at the listener and reduces unwanted, artificial reverb caused by indirect sound bouncing off walls - meaning you experience the most clear, detailed, lifelike sound possible.
HORN ANATOMY
Klipsch Reference Premiere series speakers feature a compressed molded silicon face thats matted to the 90x90 Tractrix horn to reduces horn resonance for a smoother frequency response. Klipsch computer modeled phase plugs acts as a mechanical filter to further ensure a smooth, flat frequency response while protecting the tweeter from damage.
ALL-NEW VENTED TWEETER
Klipsch titanium tweeter diaphragms delivers a smooth high-frequency reproduction thanks to the material’s light weight yet rigid composition that exceeds the performance of aluminum, polymer or silk tweeters.
Our award-winning Linear Travel Suspension technology leverages a pistons motion of the titanium diaphragm that lowers distortion and delivers real-to-life sound.
Housed in a ceramic magnet structure for premium performance, Klipsch Reference Premiere tweeters set the standard in acoustic reproduction.
CERAMETALLIC™ WOOFERS
Klipsch Proprietary Cerametallic™ woofers are the RP-500C center channel speaker's signature statement for both sound and aesthetics. This extremely light, rigid materials holds its shape while being able to deliver lower frequencies with maximum efficiency.
WOOFER ANATOMY
Klipsch Cerametallic™ cones are matted to a dual-layer, copper-wound voice coil for exceptional conductivity.
Reference Premiere woofers are housed in a non-resonating, stamped-steal basked that’s secured to a large magnet motor for exceptional efficiency and low distortion thats matched to our horn-loaded tweeters for optimal acoustic execution.
REAR TRACTRIX® PORT
The rear Tractrix port of the Reference Premiere center channel speakers is perfectly matched to the cabinet and woofers, creating ideal airflow with minimal distortion or turbulence even at the lowest frequencies.
FINISHED TO PERFECTION
The RP-500C ebony and walnut finishes boast satin painted baffles with a scratch resistant design for an elegant audio solution to your home theater system.
Strong, flexible, magnetic grilles provide protection and a sleek aesthetic to compliment your home's decor.
Klipsch RP-500C Reference Premier Center Speaker Es_kli32     Klipsch RP-500C Reference Premier Center Speaker Es_kli33
Peter  012-2536225
Fong   016-3098668
Klipsch RP-500C Reference Premier Center Speaker Trade
Specification
Frequency response: 60-25kHz +/-3dB
Sensitivity: 96dB @ 2.83V/1m
Power handling (cont/peak): 100W/400W
Nominal impedance: 8 ohms compatible
Crossover frequency: 1800Hz
High-frequency driver: 1” Titanium LTS vented tweeter with hybrid cross-section Tractrix horn
Low frequency driver: Dual 5.25” Cerametallic cone woofers
Enclosure material: MDF
Enclosure type: Bass Reflex via rear-firing Tractrix port
Inputs: Single binding posts
Dimensions (H x W x D): 6.81" x 18.5" x 9.5"
Weight: 18 lbs.
Number of posts : 557
