Klipsch RP-504C Reference Premier Center Speaker
Klipsch RP-504C Reference Premier Center Speaker Empty Klipsch RP-504C Reference Premier Center Speaker
Post by stylelaser.com.my on Thu Aug 09, 2018 3:19 pm
Klipsch RP-504C Reference Premier Center Speaker Brand New. Now Selling At RM3,399. Free Shipping Within West Malaysia.
Klipsch RP-504C Reference Premier Center Speaker Es_rp-10      Klipsch RP-504C Reference Premier Center Speaker Es_rp-11
Klipsch RP-504C
The Klipsch Reference Premiere RP-504C center channel speaker brings movie dialogue and music lyrics to life. Four 5.25" Cerametallic™ woofers and a hybrid Tractrix® horn emit lifelike, front row sound.
Features:
  • 1” Titanium LTS Vented Tweeter with Hybrid Tractrix® Horn
  • Quad 5.25" Spun Copper Cerametallic™ Woofers
  • Bass-Reflex via Rear-Firing Tractrix® port
  • Premium Scratch Resistant Ebony and Walnut Finishes
  • Dimensions: 6.81” x 31.13” x 14.46”
HYBRID TRACTRIX® HORN TECHNOLOGY
Klipsch proprietary Tractrix® horn-loaded technology ensures high-frequency energy of the RP-504C center channel speaker is aimed directly at the listener and reduces unwanted, artificial reverb caused by indirect sound bouncing off walls - meaning you experience the most clear, detailed, lifelike sound possible.
HORN ANATOMY
Klipsch Reference Premiere series speakers feature a compressed molded silicon face thats matted to the 90x90 Tractrix horn to reduces horn resonance for a smoother frequency response. Klipsch computer modeled phase plugs acts as a mechanical filter to further ensure a smooth, flat frequency response while protecting the tweeter from damage.
ALL-NEW VENTED TWEETER
Klipsch titanium tweeter diaphragms delivers a smooth high-frequency reproduction thanks to the material’s light weight yet rigid composition that exceeds the performance of aluminum, polymer or silk tweeters.
Our award-winning Linear Travel Suspension technology leverages a pistons motion of the titanium diaphragm that lowers distortion and delivers real-to-life sound.
Housed in a ceramic magnet structure for premium performance, Klipsch Reference Premiere tweeters set the standard in acoustic reproduction.
CERAMETALLIC™ WOOFERS
Klipsch Proprietary Cerametallic™ woofers are the RP-504C center channel speaker's signature statement for both sound and aesthetics. This extremely light, rigid materials holds its shape while being able to deliver lower frequencies with maximum efficiency.
WOOFER ANATOMY
Klipsch Cerametallic™ cones are matted to a dual-layer, copper-wound voice coil for exceptional conductivity.
Reference Premiere woofers are housed in a non-resonating, stamped-steal basked that’s secured to a large magnet motor for exceptional efficiency and low distortion thats matched to our horn-loaded tweeters for optimal acoustic execution.
REAR TRACTRIX® PORT
The rear Tractrix port of the Reference Premiere center channel speakers is perfectly matched to the cabinet and woofers, creating ideal airflow with minimal distortion or turbulence even at the lowest frequencies.
FINISHED TO PERFECTION
The RP-504C ebony and walnut finishes boast satin painted baffles with a scratch resistant design for an elegant audio solution to your home theater system.
Strong, flexible, magnetic grilles provide protection and a sleek aesthetic to compliment your home's decor.
Klipsch RP-504C Reference Premier Center Speaker Es_rp-12      Klipsch RP-504C Reference Premier Center Speaker Es_rp-13
Peter  012-2536225
Fong   016-3098668
Klipsch RP-504C Reference Premier Center Speaker Trade
Specification
Klipsch RP-504C loudspeaker specifications:
Power consumption: 150 W RMS / 600 W peak
Measures :
Sensitivity: 97 dB (2.83 V to 1 m)
Rated impedance: 8 Ohms
Cutoff frequency: 500/1500 Hz
Frequency response: 59 Hz to 25 kHz (+/- 3 dB)
Serious: 4x 133 mm Cerametallic cone speakers
Acute: 25mm diameter titanium diaphragm loudspeaker and tuned compression chamber, mounted on Tractrix Square Hybrid horn, with 90 ° horizontal and vertical diffusion angles
Technology:
Charge by bass-reflex resonator, with rear laminar vent Tractrix
General
Simple terminal block and magnetic acoustic grid
Dimensions (W x H x D): 791 x 173 x 367 mm
Weight: 15.4 kg
Number of posts : 557
