NAD 214 Stereo High Output Current Power Amplifier
NAD 214 Stereo High Output Current Power Amplifier  Empty NAD 214 Stereo High Output Current Power Amplifier
Post by HiFiLab on Fri Aug 17, 2018 10:30 am
NAD 214 Stereo High Output Current Power Amplifier  20180832
NAD 214 Stereo High Output Current Power Amplifier  20180834
NAD 214 Stereo High Output Current Power Amplifier  20180833
NAD 214 Stereo High Output Current Power Amplifier  20180835
CONTINUOUS AVERAGE POWER OUTPUT INTO 8 ohms: 80W - Rated distortion(THD 20Hz-20kHz): 0.03%
Can be Bridge Mono 240 Watts @ 8 Ohm
The NAD 214 is designed with the capability to drive all types of musical signals effortlessly into the even most unreasonable of loudspeaker loads, down to below 1ohm.
This is achieved by implementing a high output current amplifier powered from a "stiff" power supply. The 214 couples a bank of reservoir capacitors to a large toroidal transformer. Using a bank of capacitors rather than a single pair is both technically superior and more economical
The special Holmgren toroidal transformer has less hum and magnetic leakage than conventional toroidal transformers but retains the usual benefits of high efficiency and high power to weight ratio. The entire "front-end" is fed from a separate low-noise, high voltage, discrete component regulated power supply which effectively isolates the amplifier from power ripple and noise. Careful design incorporating sensible grounding results in an amplifier with an exceptionally clean, noise free output signal.
Dimensions
- [ W x H x D ] : 435 x 128 x 383mm
- Weight : 11.3kg
Price : RM 1100
HiFiLab
Number of posts : 2544
NAD 214 Stereo High Output Current Power Amplifier  Empty BUMP
Post by HiFiLab on Fri Oct 26, 2018 9:49 am
HiFiLab
Post by HiFiLab on Fri Nov 16, 2018 11:34 am
Up
HiFiLab
