Duntech Sovereign 2001 Floorstanding Speakers
Post by lsc1 on Sun Aug 19, 2018 6:38 pm
SPECIFICATIONS
Electrical
Frequency Response
Measured at 3.5M (11.5ft) on the tweeter axis
27Hz-20KHz
±2dB
Efficiency
Referenced at 1M (3.3 ft) on tweeter axis with an input of 2.83 volts RMS (1 watt at 8 ohms)
90dB SPL
Nominal Impedance
Variance
4 ohms
3.0-4.5
Power Rating Peak power for 10 mS1000 watts
Recommended Amplifier Power
Minimum RMS per channel
100 watts
Crossover
First order type
Yes
Drivers
Woofers
Bass
Mid
Tweeter
2x300mm (12")
2x175mm (7")
2x54mm (2")
1x19mm (3/4")
Input Terminals
Gold plated and accepts banana, spade or cable connections
Yes
Bi-WiringYes
Passive Bi-AmplificationYes
Mechanical
Finish
Rosewood
Acoustically transparent black cloth
Yes
Size
Height
Width
Depth
1875mm (74")
360mm (14")
862mm (34")
Weight
Per cabinet
125Kg
(275lbs)
Condition: 8/10
Price: RM26,000
H/P: 012-2191238
lsc1
Number of posts : 6
Registration date : 2009-12-24
