Elac Debut A4 Atmos Enabled Elevation Speaker
Elac Debut A4 Atmos Enabled Elevation Speaker  Empty Elac Debut A4 Atmos Enabled Elevation Speaker
Post by stylelaser.com.my on Mon Aug 20, 2018 6:29 pm
Elac Debut A4 Atmos Enabled Elevation Speaker Brand New. Now Selling At RM1,319. Free Shipping Within West Malaysia.
Elac Debut A4 Atmos Enabled Elevation Speaker  Es_317       Elac Debut A4 Atmos Enabled Elevation Speaker  Es_214
Three-dimensional Dolby Atmos® modules.
Dolby Atmos® technology expands the sonic landscape, creating a true 3-D space that you’ve got to hear to believe. With Dolby Atmos-enabled AV receivers and processors, simply add the Debut A4 to the top of your bookshelf or floorstanding speakers to achieve dimensionality that puts you in the middle of the music and the action.
Elac Debut A4 Atmos Enabled Elevation Speaker  Elac_a4
Product Highlights:
  • Dolby Atmos enabled speaker modules
  • designed to sit on top of front speakers such as the ELAC B6 speakers
  • 4" woven aramid-fiber cone
  • 1/2" polymer aluminum dome tweeter
  • drivers are angled up to reflect sound off the ceiling for overhead effects
  • binding post speaker terminals
  • acoustic suspension (sealed) enclosure
  • frequency response: 180-20,000 Hz
  • sensitivity: 85 dB
  • impedance: 6 ohms
  • 7-15/16"W x 4-7/8"H x 8-15/16"D
  • weight: 5.2 lbs. (each)
Features
Dolby Atmos Loudspeaker: The Elac Debut A4 has been specifically designed to be used as the "elevation" or "height" speaker in a Dolby Atmos system from 5.1.2 to 7.1.4. The A4's constructions & performance characteristics follow the strict guidelines set by Dolby in order to deliver a true Dolby Atmos experience. The Elac Debut A4 fires sound toward the ceiling which is then reflected to the main listening area to create the height information embedded into Dolby Atmos soundtrack.
Dolby Atmos: Dolby Atmos takes surround sound to a completely new level, by adding the third dimension of height to the two dimensional front/back left/right 5.1 or 7.1 sound mix. In Dolby Atmos, the floor speakers create the sound "bed" and the Dolby Atmos enabled elevation speakers are fed a separate, discrete signal to move "sound objects" around the room with pinpoint accuracy. The effect is totally convincing, and really elevates the home cinema experience to new heights.
Note: A Dolby Atmos AV receiver or processor (sold separately) will be required for Dolby Atmos surround.
Two-Way Coaxial Driver Design: The Elac Debut A4 Dolby Atmos enabled loudspeaker features a two-way coaxial driver design with a 0.5" tweeter, 4" woofers, and a 2,000Hz crossover. The tweeter is positioned in the center of the woofer cone. Both the tweeter and woofer have been custom designed by Andrew Jones to deliver an exceptional audio experience that can't be delivered with typical off-the-shelf parts
  • Polymer Dome Tweeter: The Debut A4 features a coaxially mounted 0.5" polymer dome tweeter for crisp, clear highs.
  • Woven-Aramid Fiber Woofer: The Dolby Atmos enabled speaker features a single 4" woven aramid-fiber cone woofer with rubber surround, oversized magnet, and vented pole piece. Woven aramid fiber offers a superior stiffness-to-weight ratio and damping over common polypropylene or paper cones. The added strength allows more flexibility in design to achieve a smoother, extended frequency response.
  • Custom Crossover: A custom seven-element crossover (2,000Hz) with audio-grade components is implemented to ensure smooth transition between the tweeter and woofer.
Acoustic Suspension MDF Cabinet: The Elac Debut A4 Dolby Atmos enabled loudspeaker uses an acoustic suspension (sealed) cabinet for tight, accurate midbass performance. The cabinet is made of MDF (Medium Density Fiberboard), helping minimize unwanted vibrations that can discolor music or movie content. The MDF outer walls of the cabinet are covered with a textured vinyl black finish. Detachable metal grilles are included.
5-Way Binding Posts: The Elac Debut series A4 is fitted with a set of 5-way binding-post terminals which will accept bare-wire (up to 10AWG), pin-connectors, spade-lugs, and banana plugs (single or dual).
Applications: The Elac Debut series A4 can be used in 5.1.2, 5.1.4, and 7.1.4 Dolby Atmos configurations. Make sure to following mounting, placement, and room requirements for best performance.
  • Mounting Options: The A4 is designed to set on top of the Debut Elac B5/B6 bookshelf or F5/F6 floorstanding loudspeakers, matching perfectly. It can also be used with other brands of conventional bookshelf or floorstanding speakers that feature a flat top-panel on the speaker cabinet.
  • Placement: For optimal effect and to minimize direct radiating audio at listener level, place the Dolby Atmos enabled speakers at or slight above the height of your ears when seated. Avoid placing the Dolby Atmos enabled speakers higher than one-half the height of your wall. The Dolby Atmos enabled speakers should be placed no closer than 3' from the main listening position; ideally they should be positioned 5' or more away.
  • Room Height: For optimal performance, the ceiling should be flat, (not angled or vaulted), with a height of 14' or less, and made of an acoustically reflective material; such as drywall, plaster, or hardwood. The ideal ceiling height is between 7.5' and 12'. Sound-absorbing and sound-diffusing treatment for handling unwanted reflections from the walls and floor is recommend to improve sound quality and system performance.
Elac Debut Series: The Elac Debut series family of loudspeakers consists of two bookshelf speakers, two floorstanding speaker, a center-channel speaker, a Dolby Atmos enabled speaker, and two powered subs.
Elac Debut A4 Atmos Enabled Elevation Speaker  Es_113      Elac Debut A4 Atmos Enabled Elevation Speaker  Es_511
Peter  012-2536225
Fong   016-3098668
Elac Debut A4 Atmos Enabled Elevation Speaker  Trade
Number of posts : 592
