Mitsubishi HC4000 HDMI 300-Inch 1080p Front Projector (Black)
Post by HiFiLab on Thu Aug 23, 2018 8:33 am
Note : Low Usage Hours , Lamp Time only use 475Hours  ( used 10% only)
Mitsubishi HC4000 300-Inch 1080p Front Projector (Black)
Estimated Lamp Life Rating: 5000 hours (low mode)Usage, Replacement Lamp: VLT-HC3800LP
• Native 1080p, HDMI connectivity, Manual Focus & Zoom Lens (Zoom Ratio 1.5:1)
• Contrast Ratio: 4,000:1 (on/off), Color Wheel: 6-segment (RGBRGB), Brightness/Lumens: 1300 ANSI Lumens, Decibels: 31dBA (standard mode)
300-Inch Screen Size! Enjoy Sports Movies TV & Games on a Massive Scale
Get an Immersive Big Screen Experience at an Amazing Price
Experience the same DLP technology that powers digital movie theaters, in your home with the Mitsubishi HC4000 home cinema projector. With a maximum image size of 300 inches, the HC4000 can bring your images to life in an incredibly big way. Maximize your entertainment experience without compromise. The precision glass lenses and advanced picture processing of the Mitsubishi HC4000, deliver a stunningly large, crystal clear image extending the boundaries of your home entertainment system.
Mitsubishi HC4000 Home Theater Projector HDMI High Definition Multimedia Interaface
High End Performance that Fits Your Budget
Out of the box the HC4000 home theater projector features a full high-definition zoom lens that improves image depth and reproduction of deep blacks. A feature usually found only in much higher-priced projectors, the anamorphic lens compatibility of the HC4000 accurately widens the projection range of cinema-scope images. A six-segment color wheel and BrilliantColor technology provide dazzling color reproduction, and colors can be adjusted individually with built-in color management. The HDMI input makes it easy to connect your favorite video sources and maximize picture performance.
Designed for High Reliability & Easy Maintenance
Mitsubishi backs up the HC4000 with an industry leading 2-year warranty.
The HC4000's filter free design keeps you focused on entertainment and not thinking about maintenance. The lamp is worry free with an estimated life of 5,000-hour lifespan in low mode. The low-noise fan (25dB) is specially designed for cooling efficiency while not distracting from your entertainment programming.
Price : RM 1550
HiFiLab
Number of posts : 2491
BUMP
Post by HiFiLab on Sun Sep 30, 2018 6:58 pm
Up
HiFiLab
Post by HiFiLab on Fri Oct 26, 2018 9:47 am
HiFiLab
BUMP
Post by HiFiLab on Mon Nov 26, 2018 4:49 pm
Up
HiFiLab
BUMP
Post by HiFiLab on Mon Dec 31, 2018 5:50 pm
Up
HiFiLab
BUMP
Post by HiFiLab on Wed Jan 16, 2019 9:19 pm
UP
HiFiLab
