Klipsch RP-600M Bookshelf Speaker
Klipsch RP-600M Bookshelf Speaker Empty Klipsch RP-600M Bookshelf Speaker
Post by stylelaser.com.my on Mon Aug 27, 2018 3:28 pm
Klipsch RP-600M Bookshelf Speaker Brand New. Now Selling At RM3,199. Free Shipping Within West Malaysia.
Klipsch RP-600M
Klipsch RP-600M Bookshelf Speaker Es_kli36      Klipsch RP-600M Bookshelf Speaker Es_kli37
Leveraging a 1" titanium tweeter matted to our proprietary hybrid Tractrix®️ horn - the RP-600M bookshelf speaker delivers incredible acoustics to fill your home with loud, crystal-clear sound and robust bass that no ordinary bookshelf speaker can.
Klipsch RP-600M Bookshelf Speaker Es_kli38      Klipsch RP-600M Bookshelf Speaker Es_kli39
Features:
  • 1” Titanium LTS Vented Tweeter with Hybrid Tractrix® Horn
  • 6.5" Spun Copper Cerametallic™ Woofers
  • Bass-Reflex via Rear-Firing Tractrix® port
  • Dual binding posts for bi-wire/bi-amp
  • Dimensions: 15.69” x 7.95” x 11.85”
HYBRID TRACTRIX® HORN TECHNOLOGY
Klipsch proprietary Tractrix® horn-loaded technology ensures high-frequency energy of the RP-600M bookshelf speaker is aimed directly at the listener and reduces unwanted, artificial reverb caused by indirect sound bouncing off walls - meaning you experience the most clear, detailed, lifelike sound possible.
HORN ANATOMY
Klipsch Reference Premiere series speakers feature a compressed molded silicon face thats matted to the 90x90 Tractrix horn to reduces horn resonance for a smoother frequency response. Klipsch computer modeled phase plugs acts as a mechanical filter to further ensure a smooth, flat frequency response while protecting the tweeter from damage.
ALL-NEW VENTED TWEETER
A vented tweeter design reduces standing waves behind the tweeter diaphragm for a smoother high frequency reproduction.
The titanium tweeter diaphragm's light weight yet rigid composition exceeds the performance of aluminum, polymer or silk tweeters.
Klipsch award-winning Linear Travel Suspension technology leverages a piston motion of the titanium diaphragm that lowers distortion and delivers real-to-life sound.
A ceramic magnet housing provides premium performance, Klipsch Reference Premiere tweeters set the standard in acoustic reproduction.
CERAMETALLIC™ WOOFERS
Klipsch Proprietary Cerametallic™ woofers are the RP-600M bookshelf speaker signature statement for both sound and aesthetics. This extremely light, rigid materials holds its shape while being able to deliver lower frequencies with maximum efficiency.
WOOFER ANATOMY
Klipsch Cerametallic™ cones are matted to a dual-layer, copper-wound voice coil for exceptional conductivity.
Reference Premiere woofers are housed in a non-resonating, stamped-steal basked that’s secured to a large magnet motor for exceptional efficiency and low distortion thats matched to our horn-loaded tweeters for optimal acoustic execution.
TRACTRIX® PORT + DUAL TERMINALS
The rear Tractrix port is perfectly matched to the cabinet and woofers, creating ideal airflow with minimal distortion or turbulence even at the lowest frequencies.
The RP-600M bookshelf speaker features dual input terminals so you can bi-wire or bi-amp your speakers for a custom, high-performance experience.
FINISHED TO PERFECTION
The RP-600M ebony and walnut finishes boast satin painted baffles with a scratch resistant design for an elegant audio solution to your home theater system.
Strong, flexible, magnetic grilles provide protection and a sleek aesthetic to compliment your home's decor.
Peter  012-2536225
Fong   016-3098668
Klipsch RP-600M Bookshelf Speaker Trade
Klipsch RP-600M Bookshelf Speaker Es_kli40
SPECIFICATIONS
FREQUENCY RESPONSE 45-25kHz +/- 3dB
SENSITIVITY 96dB @ 2.83V / 1m
POWER HANDLING (CONT/PEAK) 100W/400W
NOMINAL IMPEDANCE 8 Ohms Compatible
CROSSOVER FREQUENCY 1500Hz
HIGH FREQUENCY DRIVER 1” Titanium LTS Vented Tweeter with Hybrid
Cross-Section Tractrix®️ Horn
LOW FREQUENCY DRIVER 6.5” Cerametallic Cone Woofer
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass Reflex via rear-firing Tractrix®️ Port
INPUTS Dual binding posts/bi-wire/bi-amp
HEIGHT 15.69” (39.9 cm)
WIDTH 7.95” (20.2 cm)
DEPTH 11.85” (30.1 cm)
WEIGHT 16 lb (7.3 kg)
FINISH Ebony, Walnut, Piano Black
ACCESSORIES Rubber Feet (Cool
BUILT FROM 2018
Number of posts : 573
