Klipsch R-52C Center Speaker
Klipsch R-52C Center Speaker Empty Klipsch R-52C Center Speaker
Post by stylelaser.com.my on Sat Sep 08, 2018 3:22 pm
Klipsch R-25C Center Speaker Brand New. Now Selling At RM1,399. Free Shipping Within West Malaysia.
     Klipsch R-52C Center Speaker Es_kli62     Klipsch R-52C Center Speaker Es_kli61
Get crystal-clear sound for your movie dialogue and music lyrics with the incredible acoustics from the R-52C center channel speaker. Our proprietary Tractrix® horn-loaded technology gives you a lifelike, front-row listening experience unlike any other.
Features:
  • 1" Aluminum LTS tweeter
  • 90x90 Square Tractrix Horn
  • Dual 5.25" Spun-Copper IMG Woofers
  • Closed Back Design for Flexible Placement
  • Dimensions: 7.3" x 18.75" x 7.6"
TRACTRIX® HORN TECHNOLOGY
Klipsch exclusive 90x90º Tractrix® horn technology ensures that the R-52C high frequency energy is aimed at the listener and reduces artificial reverb or filtering caused by indirect sound bouncing off of walls. Using this proprietary focused technology gives you the best clarity, dynamics, and detail from your movies and music.
LINEAR TRAVEL SUSPENSION TWEETER WITH KAPTON® SUSPENSION
Klipsch exclusive Linear Travel Suspension (LTS) aluminum tweeter minimizes distortion for enhanced, detailed performances. Using Kapton®, an extremely light and rigid material, in the tweeter suspension provides high efficiency and improve resolution and detail. LTS tweeters are a hallmark of Klipsch speakers, making them some of the best speakers in the world.
SPUN COPPER IMG WOOFERS
Injection Molded Graphite (IMG) woofer cones are exceptionally light while being extremely rigid – providing remarkable low frequency response, with minimal cone breakup and distortion. When paired with the Tractrix Horn-Loaded LTS Tweeter, it provides speaker efficiency highest in its class.
SLEEK DESIGN
Exposed fasteners, low profile magnetic grilles and a scratch-resistant, textured wood grain vinyl give the R-51M bookshelf speakers a polished, modern appearance.
HIGH QUALITY CABINET + CLOSED DESIGN
Reinforced MDF construction reduces cabinet vibration for less audible coloration and improved sonic accuracy - giving you the ultimate listening experience that's built to last.
The closed back design of the R-52C gives you flexible placement options with optimal bass response regardless of your entertainment system shelving.
     Klipsch R-52C Center Speaker Es_kli64     Klipsch R-52C Center Speaker Es_kli63
Peter  012-2536225
Fong   016-3098668
Klipsch R-52C Center Speaker Trade
Specification
FREQUENCY RESPONSE 89Hz - 21kHz +/- 3dB
SENSITIVITY 95 dB @ 2.83V/1M
POWER HANDLING (CONT/PEAK) 100W/400W
NOMINAL IMPEDANCE 8 ohms Compatible
CROSSOVER FREQUENCY 1,630 Hz
HIGH FREQUENCY DRIVER 1” Aluminum LTS tweeter mated to a 90 x 90 square
Tractrix®️ Horn
LOW FREQUENCY DRIVER Dual 5.25” spun-copper IMG woofers
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Sealed
INPUTS Single Gold Plated Binding Posts
HEIGHT INCHES (MM) 7.3” (185 mm)
WIDTH INCHES (MM) 18.75” (476 mm)
DEPTH INCHES (MM) 7.6” (194 mm)
PRODUCT WEIGHT LBS (KG) 7 lbs (3.2 kg)
FINISHES Black Textured Wood Grain Vinyl
INCLUDED ACCESSORIES Rubber Feet (4)
BUILT FROM 2018
      Klipsch R-52C Center Speaker Es_kli65
Number of posts : 592
