Klipsch R-610F Floorstanding Speaker
Klipsch R-610F Floorstanding Speaker  Empty Klipsch R-610F Floorstanding Speaker
Post by stylelaser.com.my on Sat Sep 15, 2018 6:48 am
Klipsch R-610F Floorstanding Speaker Brand New. Now Selling At RM2,799. Free Shipping Within West Malaysia.
Standing at only 37" tall, yet able to produce deep bass extension, The R-610F floorstanding speaker takes your movies and music to another level by delivering incredible sound from our signature Klipsch horn-loaded tweeter and a spun-copper IMG woofer.
          Klipsch R-610F Floorstanding Speaker  Es_kli66     Klipsch R-610F Floorstanding Speaker  Es_kli67
Features:
  • 1" Aluminum LTS tweeter
  • 90x90 Square Tractrix Horn
  • Single 6.5" Spun-Copper IMG Woofers
  • Bass-Reflex via Rear-Firing Tractrix® ports
  • Dimensions: 37" x 9.4" x 15.1"
          Klipsch R-610F Floorstanding Speaker  Es_kli68     Klipsch R-610F Floorstanding Speaker  Es_kli69
TRACTRIX® HORN TECHNOLOGY
Klipsch exclusive 90x90º Tractrix® horn technology ensures that the R-610F high frequency energy is aimed at the listener and reduces artificial reverb or filtering caused by indirect sound bouncing off of walls. Using this proprietary focused technology gives you the best clarity, dynamics, and detail from your movies and music.
LINEAR TRAVEL SUSPENSION TWEETER WITH KAPTON® SUSPENSION
Klipsch exclusive Linear Travel Suspension (LTS) aluminum tweeter minimizes distortion for enhanced, detailed performances. Using Kapton®, an extremely light and rigid material, in the tweeter suspension provides high efficiency and improve resolution and detail. LTS tweeters are a hallmark of Klipsch speakers, making them some of the best speakers in the world.
SPUN COPPER IMG WOOFERS
Injection Molded Graphite (IMG) woofer cones are exceptionally light while being extremely rigid – providing remarkable low frequency response, with minimal cone breakup and distortion. When paired with the Tractrix Horn-Loaded LTS Tweeter, it provides speaker efficiency highest in its class.
REAR TRACTRIX® PORT
The rear Tractrix port is perfectly matched to the cabinet and woofers, creating ideal airflow with minimal distortion or turbulence even at the lowest frequencies.
SLEEK DESIGN
Exposed fasteners, angled feet, low profile magnetic grilles and a scratch-resistant, textured wood grain vinyl give the R-610F floorstanding speaker a polished, modern appearance.
HIGH QUALITY CABINET DESIGN
The R-610F floostanding speaker's reinforced MDF construction reduces cabinet vibration for less audible coloration and improved sonic accuracy - giving you the ultimate listening experience that's built to last.
Peter  012-2536225
Fong   016-3098668
Klipsch R-610F Floorstanding Speaker  Trade
Specification
FREQUENCY RESPONSE 45Hz - 21kHz +/- 3dB
SENSITIVITY 94 dB @ 2.83V/1M
POWER HANDLING (CONT/PEAK) 85W/340W
NOMINAL IMPEDANCE 8 ohms Compatible
CROSSOVER FREQUENCY 1,800 Hz
HIGH FREQUENCY DRIVER 1” Aluminum LTS tweeter mated to a 90 x 90 square
Tractrix®️ Horn
LOW FREQUENCY DRIVER Single 6.5” spun-copper IMG woofer
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass-Reflex via rear-firing Tractrix®️ports
INPUTS Single Gold Plated Binding Posts
HEIGHT INCHES (MM) 37” (940 mm)
WIDTH INCHES (MM) 9.4” (240 mm)
DEPTH INCHES (MM) 15.1” (384 mm)
PRODUCT WEIGHT LBS (KG) 36 lbs (16.3 kg)
FINISHES Black Textured Wood Grain Vinyl
INCLUDED ACCESSORIES Injection molded feet & screws
BUILT FROM 2018
          Klipsch R-610F Floorstanding Speaker  Es_kli71     Klipsch R-610F Floorstanding Speaker  Es_kli70
Number of posts : 573
