Marantz SR5013 7.2Ch Atmos Network AV Receiver
Marantz SR5013 7.2Ch Atmos Network AV Receiver Empty Marantz SR5013 7.2Ch Atmos Network AV Receiver
Post by stylelaser.com.my on Mon Sep 17, 2018 3:13 pm
Marantz SR5013 7.2Ch Atmos Network AV Receiver Brand New. Now Selling At RM3,999. Free Shipping Within West Malaysia.
          Marantz SR5013 7.2Ch Atmos Network AV Receiver Es_mar16     Marantz SR5013 7.2Ch Atmos Network AV Receiver Es_mar17
Marantz SR5013 7.2Ch Atmos Network Av Receiver
Enjoy high-definition home theater and multi-dimensional surround sound with the Marantz SR5013 7.2 channel AV receiver. It features Dolby Atmos, DTS:X and DTS Virtual:X decoding for immersive home theater, and proprietary HDAM circuit boards for more detailed, dynamic sound. Eight HDMI inputs are fully compatible with the latest specifications, including 4K Ultra High Definition video, 60Hz video, HDR, Dolby Vision and Hybrid Log-Gamma (HLG; via future firmware update). Listen to all your favorite music from your smart devices via Bluetooth, AirPlay or the HEOS app. Control the SR5013 with your voice and Amazon Alexa — download the HEOS Home Entertainment skill and ask Alexa to play, pause or stop music, switch inputs for your different media players, turn up the volume and more.
使用馬蘭士SR5013 7.2聲道AV擴音機欣賞高清家庭影院和多維環繞聲。它配備杜比全景聲、DTS:X和DTS Virtual:X解碼,帶來沉浸式家庭影院體驗,並配備專屬HDAM電路板,確保更細膩、動態的聲音。八個HDMI輸入完全兼容最新的規格,包括4K超高清視頻、60Hz視頻、HDR、Dolby Vision和Hybrid Log-Gamma(HLG,通過未來固件更新)。通過藍牙、AirPlay或HEOS應用程序從智能設備聆聽所有您最喜歡的音樂。下載HEOS家庭娛樂技能,並要求Alexa播放,暫停或停止音樂,切換不同媒體播放器的輸入,調高音量等等。
Key Features
  • 7.2 channel discrete power amplifier, 100W per channel (8-ohm, 20Hz – 20kHz, 0.08% THD)
  • 8 HDMI inputs — including one HDMI input on the front panel — with full HDCP 2.2 support, plus two HDMI outputs
  • 4K/60 Hz full-rate pass-through, 4:4:4 color resolution, HDR and BT.2020, plus Dolby Vision compatibility and Hybrid Log-Gamma (HLG)
  • Supports object-based audio formats Dolby Atmos, DTS:X and DTS Virtual:X processing
  • Ability to decode high-resolution audio ALAC, FLAC and WAV lossless files up to 24-bit/192-kHz — plus DSD 2.8MHz and 5.6MHz tracks let you enjoy music exactly as the artist intended
  • Marantz proprietary HDAM circuit boards for more detailed, dynamic sound
  • Built-in HEOS wireless multi-room audio technology
  • Amazon Alexa voice control via the HEOS Home Entertainment skill
  • Stream the most popular music services — like Spotify, Pandora, TuneIn, Deezer and many others — via Bluetooth, AirPlay 2 or the HEOS app
  • Now available – Apple AirPlay 2
  • Integrated Phono input to connect to your turntable
  • Optimize your audio experience with Audyssey MultEQ, Dynamic Volume and Dynamic EQ for a seamless setup within your listening environment
  • Setup assistant, advanced GUI and Marantz 2016 AVR remote app for an easy out-of-box experience
  • Built-in Wi-Fi with 2.4GHz/5GHz dual band support (dual antenna)
主要特色
  • 7.2聲道分離式放大器,每聲道100W(8歐,20Hz – 20kHz,0.08% THD)
  • 8個HDMI輸入——包括一個位於前面板的HDMI輸入——支持全HDCP 2.2,外加兩個HDMI輸出
  • 4K/60 Hz全速率直通、4:4:4彩色分辨率、HDR和BT.2020,外加Dolby Vision兼容性和Hybrid Log Gamma (HLG)
  • 支持基於對象的音頻格式Dolby Atmos、DTS:X和DTS Virtual:X處理
  • 能夠解碼高達24bit /192kHz的高清音頻ALAC、FLAC和WAV無損音樂文件以及DSD 2.8MHz和5.6MHz曲目,讓您欣賞藝術家原來聲音的音樂
  • 馬蘭士專屬HDAM電路確保更細膩、動態的聲音
  • 內置HEOS無線多房間音頻技術
  • 亞馬遜Alexa語音控制-通過HEOS家庭娛樂技能(skill )
  • 串流傳輸最流行的音樂服務 — 通過藍牙、AirPlay或HEOS應用程序
  • 唱頭輸入可連接您的黑膠唱盤
  • 使用Audyssey MultEQ、Dynamic Volume(動態音量)和Dynamic EQ(動態均衡器)優化您的音頻體驗,確保在您的聽音環境進行無縫設置
  • 亞馬遜Alexa語音控制通過HEOS家庭娛樂技能( Skill )
  • 設置助手、高級GUI和馬蘭士2016 AVR遠程控製程序讓您享受開箱即用的輕鬆體驗
  • 內置Wi-Fi並支持2.4GHz/5GHz雙帶寬(雙天線)
HEOS, Bluetooth, Wi-Fi and AirPlay 2 Capability
Dual antenna system lets you stream the most popular music services via Bluetooth, AirPlay or the HEOS app. Listen to your playlists on Spotify, Pandora, TuneIn, Deezer and more.
HEOS、藍牙、Wi-Fi和AirPlay 2功能
雙天線系統讓您通過藍牙、AirPlay 2或HEOS應用程序流傳輸最流行的音樂服務。收聽智能設備上面的播放列表。
Marantz SR5013 7.2Ch Atmos Network AV Receiver 22_HEOS_Multiroom
Powerful Seven-channel Discrete Amplifier
Featuring a high-current output power amp section, you get exceptional sound and the latest formats for movies and music with identical power on all seven channels (100W per channel: 8-ohm, 20Hz - 20kHz, 0.08% two-channel drive) and low-impedance drive capability for superb speaker control.
強大的七聲道分離式放大器
配備高電流輸出功率放大器,所有七個聲道具有相同功率,提供了出色音質和最新電影和音樂格式,以及低阻抗驅動能力,確保卓越的揚聲器控制。
Marantz SR5013 7.2Ch Atmos Network AV Receiver M_SR5013_amplifier
Latest HDMI Connectivity
Includes eight HDMI inputs — with one HDMI input on the front panel for quick connection — each one supporting HDCP 2.2, 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub-sampling, Dolby Vision, HLG, High Dynamic Range (HDR), 21:9 video, 3D and BT.2020 pass-through. The video processor is capable of upscaling SD and HD video to 4K Ultra HD.
最新HDMI連接
包括八個HDMI輸入(一個位於前面板,用於快速連接),均支持HDCP 2.2、4K超高清60Hz視頻、4:4:4純色子採樣、Dolby Vision、HLG、高動態範圍(HDR)、21 :9視頻、3D、和BT.2020直通。視頻處理器能將標清和高清視頻增線至4K超高清視頻。
Marantz SR5013 7.2Ch Atmos Network AV Receiver HDMI
Supports Latest Object-based Audio Formats
Immerse yourself in multi-dimensional audio with the latest surround formats, including Dolby Atmos, DTS:X and DTS Virtual:X (creates virtual height effects in the absence of height channels).
Dolby Atmos
Feel every dimension in Dolby Atmos. Enjoy a 5.1 surround sound speaker system and two additional overhead speakers or two Dolby Atmos elevation speakers for the ultimate home theater experience — including Dolby Surround upmixer for legacy content.
杜比全景聲(Dolby Atmos)
全方位感受杜比環繞聲。只需一個5.1環繞聲揚聲器系統和兩個附加頂置天空揚聲器或2個杜比全景聲反射揚聲器,即可享受終極家庭影院體驗——包括用於傳統內容的杜比環繞聲上混頻器。
Marantz SR5013 7.2Ch Atmos Network AV Receiver DolbyAtmos_Vert_black
DTS:X
DTS:X immersive audio formatting places sound where it would naturally occur in space, creating life-like, multi-dimensional audio. The included spatial remapping engine of DTS Neural:X™ offers improved immersion and heightened realism in all of your favorite movies.
DTS:X沉浸式音頻格式將聲音置於它在空間中自然發聲的位置,在家中創建逼真的多維音頻體驗。 DTS Neural:X™附帶空間空間重整引擎,為您所有最喜愛的電影提供改善的沉浸效果和增強的真實感。
Marantz SR5013 7.2Ch Atmos Network AV Receiver Dtsx
DTS Virtual:X
DTS Virtual:X provides immersive audio without height channels, creating virtual height effects in a 5.1, 7.1 or 2.1 speaker arrangement.
Amazon Alexa Voice Control
Enjoy hands-free control with Amazon Alexa and your voice. Adjust the volume, skip to the next track, switch inputs for your different media players and more — “Just Ask.” Download the HEOS Home Entertainment Skill to enable Amazon Alexa voice commands for SR5013, HEOS devices and other select Marantz products.
Amazon Alexa語音控制
使用Amazon Alexa和自己的聲音免提控制。為不同媒體播放器調節音量、跳到下一首曲目、切換輸入——“只需發出聲音指令”。下載HEOS Home Entertainment Skill,啟用適用於SR5013、HEOS設備和其他精選馬蘭士產品的Amazon Alexa語音指令。
(可用性因國家地區而異)。
Marantz SR5013 7.2Ch Atmos Network AV Receiver Connectivity_tab_logos
Airplay 2
Stream audio from your favorite music services like Apple Music and Spotify or watch videos from services like Youtube and Netflix from any iPhone, iPad, Mac or Apple TV and hear the audio perfectly synced to your speakers Airplay 2 sources.
Airplay 2 also supports multi-room audio – wirelessly stream content to multiple AirPlay 2 compatible devices simultaneously with improved audio buffering to ensure smooth audio playback. AirPlay 2 provides control and grouping of compatible audio devices within the Apple Music or Home app. Use Airplay 2 in-app or with your voice via Siri.
Marantz SR5013 7.2Ch Atmos Network AV Receiver AirPlay_2_Copy_Block_Image_27082018
High-resolution Audio Support
Ability to decode high-resolution audio ALAC, FLAC and WAV lossless files up to 24-bit/192-kHz, as well as DSD 2.8MHz and 5.6MHz tracks (the audiophile format of SACD) lets you enjoy music exactly as the artist intended. Listen to your music via the front panel USB port or over network sources.
支持高清音頻
可以解碼高達24bit/192kHz的高清無損音頻文件ALAC、FLAC和WAV以及DSD 2.8MHz和5.6MHz曲目(SACD音響發燒友格式),讓您欣賞藝術家原生音樂。通過前面板USB端口或從網絡音源聆聽音樂。
  Marantz SR5013 7.2Ch Atmos Network AV Receiver Hi-res
Integrated Phono Input
Easily connect your analog turntable to the receiver and enjoy the pure intent of each recording within your vinyl collection.
集成唱頭輸入
輕鬆將模擬轉盤連接到擴音機,享受黑膠唱片專輯裡每首歌曲純正的音色。
Marantz SR5013 7.2Ch Atmos Network AV Receiver M_SR5013_TT-15S
Marantz HDAM and Current Feedback Topology
Features proprietary HDAM circuit boards, providing a superior low noise wideband performance and an ultra-fast slew rate for maximum dynamic range to support high-resolution audio formats. Plus, Current Feedback Topology technology, another proprietary Marantz innovation, delivers wide closed-loop bandwidth and very high slew rate for superior fidelity with wideband audio sources.
馬蘭士HDAM和電流反饋電流
配備了專屬HDAM電路,提供了超凡的低噪寬帶性能和超快的轉換速率,確保最大的動態範圍,並支持高清音頻格式。此外,另一項專屬馬蘭士創新即電流反饋拓撲技術,提供了寬閉環帶寬和非常高的轉換速率,確保寬帶音頻源的超凡傳真度。
Marantz SR5013 7.2Ch Atmos Network AV Receiver M_SR5013_hdam_board
Advanced 32-bit D/A Conversion on All Channels
Advanced reference-class 32-bit AKM D/A converters on all channels for optimum fidelity and the widest dynamic range with the lowest distortion. This ensures consistent high fidelity and precise channel matching across all channels for the ultimate listening experience.
所有聲道配備高級32bit D/A轉換功能
所有聲道配備高級參考級32bit AKM D/A轉換器,以最低失真獲得最高傳真度和最寬動態範圍。這能確保所有聲道都有一致的高傳真度和準確的聲道配對,實現終極聆聽體驗。
Audyssey MultEQ for Simple Set-up and Room Calibration
Optimize your audio experience with Audyssey MultEQ, Dynamic Volume and Dynamic EQ for a seamless setup of your listening environment. With the supplied measurement microphone, MultEQ analyzes each speaker's output (including the subwoofer) and generates precision digital filters that optimize each channel for the correct frequency and time domain response. Use Audyssey Dynamic EQ to deliver clear dialogue and wide-band response even at reduced volume levels, or Audyssey Dynamic Volume to avoid shocks and normalize volume when content switches between commercials, announcements and TV programs.
Audyssey MultEQ可簡化設置和室內校準
使用Audyssey MultEQ、Dynamic Volume(動態音量)和Dynamic EQ(動態均衡器)優化您的音頻體驗,確保聽音環境的設置天衣無縫。通過附帶的測量麥克風,MultEQ分析各揚聲器的輸出(包括超低音揚聲器),並產生能優化各聲道以獲得正確頻率和時域響應的精確數碼濾波器。即使音量降低,使用Audyssey Dynamic EQ也能帶來清晰的對話和寬頻帶響應,或者,在商業廣告、公告和電視節目之間切換時,使用Audyssey Dynamic Volume可以避免衝擊,使音量保持正常。
Marantz SR5013 7.2Ch Atmos Network AV Receiver 40_Logo%20AudysseyMultEQ%20XT32
Marantz 2016 AVR Remote
適用於iOS和Android的Marantz 2016 AVR遠程控製程序賦予您對最新馬蘭士網絡AV擴音機的全權控制。用它控制開機/關機、調節音量、輸入或設置或即時切換到HEOS應用程序。
Marantz SR5013 7.2Ch Atmos Network AV Receiver Avr-app
Dual Subwoofer Outputs
Supports dual subwoofers for even, low-frequency bass response within your listening environment. Enjoy accurate bass with no audible peaks or dips no matter where you place your subwoofer.
雙超低音揚聲器輸出
支持雙超低音系統,在您的聆聽環境內產生均勻的低頻響應。享受精準的低音,不管將低音炮置於何處,都沒有聲音的波峰和波谷。
Marantz SR5013 7.2Ch Atmos Network AV Receiver Dual-sub
Smart TV Connectivity
Easily control the receiver with your Smart TV remote via the HDMI CEC functionality associated with your Smart TV. Simply set “HDMI Control” to ON in your receiver, then set “Smart Menu” to ON and begin controlling the SR5013 with your TV remote. The Smart Menu home screen gives you quick access to source and surround mode selections, the AVR's setup menu and four Smart Selects.
智能電視連接能力
通過與智能電視相關聯的HDMI CEC功能,使用智能電視遙控器輕鬆控制擴音機。只需在擴音機上將“HDMI控制”設為“ON”,接著將“智能菜單”設為“ON”,即可使用電視遙控器控制SR5013。智能菜單主屏幕上提供了音源和環繞模式選擇、AVR設置菜單以及四個智能選擇的快速訪問方式。
Marantz SR5013 7.2Ch Atmos Network AV Receiver Smart-tv
Simple Smart Select Functions
Four Smart Select function buttons on the included remote control store your preferred setup — including input, volume and Audyssey configuration — for particular sources. With the push of a button, the receiver perfectly configures for any source, from Blu-ray to TV set-top box, to your favorite Internet radio station and more.
簡易智能選擇功能
附帶的遙控器上有4個智能選擇功能按鈕,可儲存您對特定源的首選設置——包括輸入、音量和Audyssey配置。按下按鈕,接收機完美配置各種聲源,從藍光訊源到電視機頂盒,再到您喜愛的互聯網電台等等。
Marantz SR5013 7.2Ch Atmos Network AV Receiver Smart-select
More Than 60 Years of Audiophile Heritage
Founded in 1953, Marantz has a long and rich history of designing audio components embraced by music lovers and critical listeners around the world. Because Music Matters, the SR5013 carries on our long tradition of delivering a best-in-class listening experience for music and cinema.
超過60年的發燒傳統
馬蘭士創辦於1953年,具有悠久豐富的音響元件設計歷史,其產品得到全球音樂愛好者和挑剔收聽者的推崇。因為“音樂至上”,SR5013延續了提供一流音樂和電影聆聽體驗的悠久傳統。
Peter  012-2536225
Fong   016-3098668
Marantz SR5013 7.2Ch Atmos Network AV Receiver Trade
          Marantz SR5013 7.2Ch Atmos Network AV Receiver Es_mar19     Marantz SR5013 7.2Ch Atmos Network AV Receiver Es_mar18
Specification
Multichannel Surround
DTS HD Master / DTS:X o / o
DTS Neo:X / DTS Neural:X - / o
DTS Virtual:X o
Dolby TrueHD / Dolby Atmos o / o
Dolby ProLogic llz / Dolby Surround - / o
Auro 3D -
Audyssey DSX -
Multichannel Stereo o
Max Number of Processing (Preamp) Channels 7.1
Sound Enhancements
Discrete Power Amplifier 7
Copper Plated Chassis -
Power Transformer: Toroidal / EI EI
Current Feedback Topology o
Hyper Dynamic Amplifier Modules (HDAM) o
Pure Direct o
High Grade Audio Components o
Gold plated RCA terminals -
Clock Jitter Reducer -
Audyssey MultEQ XT
Audyssey Dynamic EQ / Dynamic Volume o / o
Audyssey LFC -
Compressed Audio Enhancer: MDAX2 o
Sound Enhancements
Pure Direct o
Audyssey MultEQ XT
Audyssey LFC -
HDMI Inputs: Back / Front 7 / 1
HDCP2.2 Support o
HDMI Outputs: Main / Zone 2 / -
Video Conversion Analog -> HDMI o
Analog to HDMI Scaling 480i/576i up to 4K 60/50
HDMI to HDMI Scaling up to 4K 30/25/24
GUI Overlay on HDMI o
HDMI: 3D / 4K / CEC / ARC / InstaPrevue o / o / o / o / -
Enhanced ARC -
HDR / HLG / Dolby Vision o (HRD10) / o / o
3D Signal Pass-Through o
4K Signal Pass-Through / Scaling / GUI Overlay o / o / o
HDMI Pass-Through in Standby Mode o
Picture Adjust / Noise Reduction o / o
CEC o
DSD Audio Capability -
Audio Return Channel o
Auto LipSync o
Number of Poweramps 7
Power Output (8 ohm, 20 Hz - 20 kHz, 0.08% 2ch Drive) 100 W
Power Output (8 ohm, 20 Hz - 20 kHz, 0.05% 2ch Drive) -
Power Output (6 ohm, 1 kHz, 0.7% 2ch Drive) 140 W
Power Output (6 ohm, 1 kHz, 10% 1ch Drive) 200 W
70% Guarantee o
Metal Front Panel -
System Remote Control RC035SR
Pre-Programmed / Learnable / LCD Display - / - / -
Power Consumption in W 650
Power Consumption No-Sound (ECO on / off) in W 45 W / 75 W
Standby Consumption in W 0.2
CEC Standby Consumption in W 0.5
Network Standby Consumption in W 2.7
Weight in lbs. 22.1
Maximum Dimensions
Antenna:Horizontal:(W x D x H) in mm
Antenna:Vertical :(W x D x H) in mm
W/o Antenna:(W x D x H) in mm 17.3 x 13.7 x 6.3
(17.3 x 13.7 x 9.1)
(17.3 x 13.3 x 6.3)
          Marantz SR5013 7.2Ch Atmos Network AV Receiver Es_mar20
Number of posts : 575
