Marantz NR1509 Slim 5.2Ch Network Av Receiver
Marantz NR1509 Slim 5.2Ch Network Av Receiver Empty Marantz NR1509 Slim 5.2Ch Network Av Receiver
Post by stylelaser.com.my on Mon Sep 17, 2018 3:32 pm
Marantz NR1509 Slim 5.2Ch Network AV Receiver Brand New. Now Selling At RM2,749. Free Shipping Within West Malaysia.
          Marantz NR1509 Slim 5.2Ch Network Av Receiver Es_121     Marantz NR1509 Slim 5.2Ch Network Av Receiver Es_518
Marantz NR1509 Slim 5.2 Channel AV Receiver with HEOS
With a slim profile that never sacrifices performance for looks, the Marantz NR1509 AVR delivers 5.2 channels and high-resolution surround sound from Dolby TrueHD and DTS-HD Master Audio. With 6 HDMI inputs — including one on the front panel — the NR1509 is fully compatible with the latest 4K Ultra HD video specifications, including 60 Hz full rate content, 4:4:4 Pure Color sub-sampling, BT.2020, HDR and Dolby Vision. The NR1509 features a power amplifier section with high-current discrete transistors to support high-resolution audio. Enjoy your favourite music services via Bluetooth, Apple AirPlay 2 or the HEOS app. Control NR1509 with your voice and Amazon Alexa — download the HEOS Home Entertainment skill and ask Alexa to play, pause or stop music, switch inputs for your different media players, turn up the volume and more.
配置HEOS的馬蘭士NR1509超薄5.2聲道AV擴音機
馬蘭士NR1509 AVR機身超薄(但未對其外觀性能造成影響),配置5.2聲道,提供來自Dolby TrueHD和DTS-HD Master Audio的高解析度環繞聲。 NR1509配備6個HDMI輸入端口(其中1個在前面板),完全兼容最新的4K超高清視頻規格,包括60 Hz全速率內容、4:4:4純色子採樣、BT.2020、HDR和Dolby Vision 。 NR1509的功率放大器部分配置分離式高電流晶體管,支持高清音頻。使用藍牙、Apple AirPlay 2或HEOS應用程序欣賞自己喜愛的音樂服務。通過語音和Amazon Alexa控制NR1509——下載HEOS家庭娛樂技能,請Alexa播放、暫停或停止音樂,切換不同媒體播放機的輸入,調高音量等等
Key Features
  • Now available – control with Amazon Alexa voice commands.
  • Slim profile that’s half the height of a traditional AVR delivers exceptional performance and sound quality
  • 5-channel discrete power amplifier, 85W per channel
  • 6 HDMI inputs — including one input on the front panel — with full HDCP 2.2 support
  • 4K/60 Hz full-rate pass-through, 4:4:4 color resolution, HDR and BT.2020, plus Dolby Vision compatibility and Hybrid Log-Gamma (HLG)
  • Supports surround formats like Dolby TrueHD and DTS-HD Master Audio
  • Ability to decode high-resolution audio ALAC, FLAC and WAV lossless files up to 24-bit/192-kHz — plus, DSD 2.8MHz and 5.6MHz tracks let you enjoy music exactly as the artist intended
  • Built-in HEOS wireless multi-room audio technology
  • Amazon Alexa voice control via the HEOS Home Entertainment skill
  • Stream the most popular music services — like Spotify, Amazon Music, TuneIn, Deezer and many others — via Bluetooth, AirPlay 2 or the HEOS app
  • Integrated Phono input to directly connect your turntable
  • Optimize your audio experience with Audyssey MultEQ, Dynamic Volume and Dynamic EQ for a seamless setup within your listening environment
  • Setup assistant, advanced GUI and Marantz 2016 AVR remote app for an easy out-of-box experience
  • Built-in Wi-Fi with 2.4GHz/5GHz dual band support (dual antenna)
  • Now available – Apple AirPlay 2
主要特色
  • 支持 Apple AirPlay 2
  • 機身超薄,高度僅為傳統AVR的一半,但性能和音質非常出眾
  • 5聲道分離式功率放大器,每聲道50W(8Ω,20Hz–20kHz,0.08% THD)
  • 6個HDMI輸入端口,1個ARC輸出端口——其中一個輸入端口位於前面板——均支持HDCP 2.2
  • 4K/60 Hz全速率直通、4:4:4彩色分辨率、HDR和BT.2020,外加Dolby Vision兼容性和Hybrid Log Gamma (HLG)
  • 支持Dolby TrueHD和DTS-HD Master Audio等環繞聲格式
  • 可以解碼高達24bit/192kHz的高清無損音頻文件ALAC、FLAC和WAV以及DSD 2.8MHz和5.6MHz曲目,讓您欣賞藝術家原聲音樂
  • 內置HEOS無線多房間音頻技術
  • 通過HEOS家庭娛樂技能進行Amazon Alexa語音控制(可用性因國家地區而異)。
  • 串流播放最流行的音樂服務 — Spotify、Tidal、TuneIn等 — 通過藍牙、AirPlay 2或HEOS應用程序
  • 內置唱頭輸入可直接連接黑膠唱盤
  • 使用AudysseyMultEQ、Dynamic Volume和Dynamic EQ優化您的音頻體驗,在您的聆聽環境中進行無縫設置
  • 設置助手、高級GUI和馬蘭士2016 AVR Remote App讓您享受開箱即用的輕鬆體驗
  • 內置Wi-Fi並支持2.4GHz/5GHz雙帶寬(雙天線)
Powerful, Slim Five-channel Discrete Amplifier
Featuring a high-current discrete power amplifier section, you get exceptional sound for movies and music with identical power on all five channels (85W per channel) with low-impedance drive capability for superb speaker control. Supports surround formats like Dolby TrueHD and DTS-HD Master Audio for an immersive home theater experience. Slim profile is half the height of a traditional AVR, while delivering the dynamic sound quality that defines Marantz excellence.
功能強大的分離式超薄五聲道放大器
產品配備高電流分離式功率放大器部分,可以使用最新的格式欣賞音質超酷的電影和音樂,全五個聲道功率相等(每聲道50W:8Ω,20Hz–20kHz,0.08% THD)。支持Dolby TrueHD、DTS-HD Master Audio等環繞聲格式,提供沉浸式家庭影院體驗。機身超薄,高度僅為傳統AVR的一半,但提供馬蘭士卓越的動態音質。
Marantz NR1509 Slim 5.2Ch Network Av Receiver NR1509_features_power_amp
Latest HDMI Connectivity
Includes six HDMI inputs — with one HDMI input on the front panel for quick connection — each one supporting HDCP 2.2, 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub-sampling, Dolby Vision, HLG, High Dynamic Range (HDR) and 21:9 video, 3D and BT.2020 pass-through.
最新HDMI連接
包括六個HDMI輸入端口(其中一個HDMI輸入端口位於前面板,用於快速連接) ,均支持HDCP 2.2、4K超高清60Hz視頻、4:4:4純色子採樣、Dolby Vision 、HLG、High Dynamic Range(HDR)和BT.2020直通。
Marantz NR1509 Slim 5.2Ch Network Av Receiver NR1509_features_HDMI
HEOS, Bluetooth, Wi-Fi and AirPlay 2 Capability
Dual antenna system lets you stream the most popular music services via Bluetooth, AirPlay 2 or the HEOS app. Listen to your playlists on Spotify, TuneIn, Deezer and more.
HEOS、藍牙、Wi-Fi和AirPlay 2功能
雙天線系統讓您通過藍牙、AirPlay 2或HEOS應用程序串流播放最流行的音樂服務。收聽Spotify、Tidal、TuneIn等上面的播放列表。
Marantz NR1509 Slim 5.2Ch Network Av Receiver Connectivity_tab_logos_V2_Marantz_24082018
HEOS Multi-room Streaming
Built-in HEOS technology lets you enjoy your favourite music in any room of your home for a wireless, whole-home audio experience. Play the same song in every room, or select a different song for each connected room — the choice is yours. Enjoy music from Spotify, TuneIn, Sound Cloud, Tidal, Napster, Deezer or your local music file libraries. With additional HEOS components, like HEOS-capable speakers, play all your music in one room or many.
HEOS多房間串流
內置HEOS技術讓您在家裡任何房間都能欣賞自己最喜愛的音樂,享受全家無線音頻體驗。在每個房間播放同一首歌,或為每個連通的房間選擇不同的歌——選擇權在您手裡。從Spotify、TuneIn、Tidal或您的本地音樂文件庫欣賞音樂。利用附加HEOS組件,如支持HEOS的揚聲器,可以在一個房間或多個房間播放您所有的音樂。
Marantz NR1509 Slim 5.2Ch Network Av Receiver NR1509_features_HEOS_Multiroom
Amazon Alexa Voice Control
Enjoy hands-free control with Amazon Alexa and your voice. Adjust the volume, skip to the next track, switch inputs for your media players and more — “Just Ask.” Download the HEOS Home Entertainment Skill to enable Amazon Alexa voice commands for NR1509, HEOS devices and other select Marantz products.
Amazon Alexa語音控制
使用Amazon Alexa和自己的聲音免提控制。為不同媒體播放器調節音量、跳到下一首曲目、切換輸入——“只需發出聲音指令”。下載HEOS Home Entertainment Skill,啟用適用於NR1509、HEOS設備和其他精選馬蘭士產品的Amazon Alexa語音指令(可用性因國家地區而異)。
Marantz NR1509 Slim 5.2Ch Network Av Receiver NR1509_features_dot
High-resolution Audio Support
Ability to decode high-resolution audio ALAC, FLAC and WAV lossless files up to 24-bit/192-kHz, as well as DSD 2.8MHz and 5.6MHz tracks (the audiophile format of SACD) lets you enjoy music exactly as the artist intended. Listen to your music via the front panel USB port or over network sources.
支持高清音頻
可以解碼高達24bit/192kHz的高解析度無損音頻文件ALAC、FLAC和WAV以及DSD 2.8MHz和5.6MHz曲目(SACD音響格式),讓您欣賞藝術家原生音樂。通過前面板USB端口或從網絡音源聆聽歌曲。
Marantz NR1509 Slim 5.2Ch Network Av Receiver NR1509_features_hi-res
Integrated Phono Input
Easily connect your analog turntable to the receiver and enjoy the pure intent of each recording within your vinyl collection.
內置唱頭輸入
輕鬆將黑膠唱盤連接到擴音機,享受黑膠唱片專輯裡每首歌曲純正的音色。
Marantz NR1509 Slim 5.2Ch Network Av Receiver NR1509_features_phono
Marantz 2016 AVR Remote
The Marantz 2016 AVR Remote app for iOS and Android gives you complete control over the latest Marantz network AV receivers. Use it to power on/off, adjust volume, input and settings, or switch instantly to the HEOS app.
適用於iOS和Android的Marantz 2016 AVR Remte App 賦予您對最新馬蘭士網絡AV接收機的全權控制。用它控制開機/關機、調節音量、輸入或設置或即時切換到HEOS App。
Marantz NR1509 Slim 5.2Ch Network Av Receiver NR1509_features_avr-app
Audyssey MultEQ for Simple Set-up and Room Calibration
Optimize your audio experience with Audyssey MultEQ, Dynamic Volume and Dynamic EQ for a seamless setup of your listening environment.
With the supplied measurement microphone, MultEQ analyzes each speaker's output (including the subwoofer) and generates precision digital filters that optimize each channel for the correct frequency and time domain response. Use Audyssey Dynamic EQ to deliver clear dialogue and wide-band response even at reduced volume levels, or Audyssey Dynamic Volume to avoid shocks and normalize volume when content switches between commercials, announcements and TV programs. The MultEQ Editor app (available for purchase) allows you to customize the sound more precisely to the specific problems in your room and tailor the sound to your personal preferences.
AudysseyMultEQ用於簡化設置和室內校準
使用AudysseyMultEQ、Dynamic Volume、和Dynamic EQ優化您的音頻體驗,在您的聆聽環境中進行無縫設置。
通過附帶的測量麥克風,MultEQ分析各揚聲器的輸出(包括超低音揚聲器),並產生能優化各聲道以獲得正確頻率和時域響應的精確數碼濾波器。即使音量降低,使用Audyssey Dynamic EQ也能帶來清晰的對話和寬頻帶響應,或者,在商業廣告、公告和電視節目之間切換時,使用Audyssey Dynamic Volume可以避免突然音量改變衝擊,使音量保持正常。 MultEQ Editor App允許用戶針對房間的特殊問題更精準地自定義聲音模式,量身打造適合個人偏好的聲音。
Marantz NR1509 Slim 5.2Ch Network Av Receiver NR1509_features_Audyssey-multeq
Dual Subwoofer Outputs
Supports dual subwoofers for even, low-frequency bass response within your listening environment. Enjoy accurate bass with no audible peaks or dips no matter where you place your subwoofer.
雙超低音揚聲器輸出
支持雙超低音系統,在您的聆聽環境內產生均勻的低頻低音響應。享受精準的低音,不管將低音炮置於何處,都沒有聲音波峰和波谷。
Marantz NR1509 Slim 5.2Ch Network Av Receiver Dual-sub
Smart TV Connectivity
Easily control the receiver with your Smart TV remote via the HDMI CEC functionality associated with your Smart TV. Simply set “HDMI Control” to ON in your receiver, then set “Smart Menu” to ON and begin controlling the NR1509 with your TV remote. The Smart Menu home screen gives you quick access to source and surround mode selections, the AVR's setup menu and four Smart Selects.
智能電視連接能力
通過與智能電視相關聯的HDMI CEC功能,使用智能電視遙控器輕鬆控制接收機。只需在接收器上將“HDMI控制”設為“ON”,接著將“智能菜單”設為“ON”,即可使用電視遙控器控制NR1509。智能菜單主屏幕上提供了音源和環繞模式選擇、AVR設置菜單以及四個智能選擇的快速訪問方式。
Marantz NR1509 Slim 5.2Ch Network Av Receiver Smart-tv
Simple Smart Select Functions
Four Smart Select function buttons on the included remote control store your preferred setup — including input, volume and Audyssey configuration — for particular sources. With the push of a button, the receiver perfectly configures for any source, from Blu-ray to TV set-top box, to your favourite Internet radio station and more.
簡易智能選擇功能
附帶的遙控器上有4個智能選擇功能按鈕,可儲存您對特定訊源的首選設置——包括輸入、音量和Audyssey配置。按下按鈕,接收機完美配置各種聲源,從藍光源到電視機頂盒,再到您喜愛的互聯網電台等等。
Marantz NR1509 Slim 5.2Ch Network Av Receiver Smart-select
Advanced Custom Installation Support
All Marantz 2018 AV receivers offer extended support for easy custom install integration. Features “ihiji Invision” remote system management technology, “Domotz Pro” remote monitoring and management technology with dedicated web interface to control and set up your AV receiver from a computer on the same network. Let your installer easily monitor the status of connected products and troubleshoot remotely from a separate location or on-the-go.
More than 60 Years of Audiophile Heritage
Founded in 1953, Marantz has a long and rich history of designing audio components embraced by music lovers and critical listeners around the world. Because Music Matters, the NR1509 carries on our long tradition of delivering a best-in-class listening experience for music and cinema.
超過60年的高傳真傳承
馬蘭士創辦於1953年,具有悠久豐富的音響元件設計歷史,其產品得到全球音樂愛好者和挑剔收聽者的推崇。因為“音樂至上”,NR1609延續了提供一流音樂和電影聆聽體驗的悠久傳統。
          Marantz NR1509 Slim 5.2Ch Network Av Receiver Es_328     Marantz NR1509 Slim 5.2Ch Network Av Receiver Es_224
Peter  012-2536225
Fong   016-3098668
Marantz NR1509 Slim 5.2Ch Network Av Receiver Trade
          Marantz NR1509 Slim 5.2Ch Network Av Receiver Es_715
Specification
Multichannel Surround
DTS HD Master / DTS:X o / -
DTS Neo:X / DTS Neural:X - / -
DTS Virtual:X -
Dolby TrueHD / Dolby Atmos o / -
Dolby ProLogic llz / Dolby Surround - / -
Auro 3D -
Audyssey DSX -
Multichannel Stereo o
Max Number of Processing (Preamp) Channels 5.1
Sound Enhancements
Discrete Power Amplifier o
Copper Plated Chassis -
Power Transformer: Toroidal / EI EI
Current Feedback Topology -
Hyper Dynamic Amplifier Modules (HDAM) -
Pure Direct o
High Grade Audio Components -
Gold plated RCA terminals -
Clock Jitter Reducer -
Audyssey MultEQ
Audyssey Dynamic EQ / Dynamic Volume o / o
Audyssey LFC -
Audyssey APP Support -
Compressed Audio Enhancer: MDAX2 o
Network
HEOS Multi-room and Streaming o
Network Audio Sharing o
Lossy formats: MP3 / WMA / AAC o / o / o
Lossless formats: FLAC / ALAC / WAV o / o / o
Lossless formats: FLAC HD 192/24 / WAV 192/24 / ALAC 192/24 o / o / o
DSD Audio Streaming up to DSD5.6
FLAC HD 192/24 o
WAV 192/24 o
ALAC 192/24 o
Gapless Playback o (FLAC, WAV, ALAC ,DSD)
AirPlay Audio Streaming o
AirPlay 2 Audio Streaming o
Internet radio o (TuneIn)
Spotify / Pandora / SiriusXM o / o / o
Compatible with Remote APP for Smart Phones Marantz 2016 AVR Remote
Compatible with Remote APP for Tablets Android / iOS / Amaz0n Kindle
Ethernet Ports o
Wi-Fi o
Bluetooth o
HDMI
HDMI Inputs: Back / Front 5 / 2
HDCP2.2 Support o
HDMI Outputs: Main / Zone 1 / -
Video Conversion Analog -> HDMI -
Analog to HDMI Scaling -
HDMI to HDMI Scaling -
GUI Overlay on HDMI o
HDMI: 3D / 4K / CEC / ARC / InstaPrevue o / o / o / o / -
Enhanced ARC -
HLG / Dolby Vision o (update) / o
3D Signal Pass-Through o
4K Signal Pass-Through / Scaling / GUI Overlay o / - / o
HDMI Pass-Through in Standby Mode o
Picture Adjust / Noise Reduction - / -
CEC o
DSD Audio Capability -
Audio Return Channel o
Auto LipSync o
VIDEO
Composite In / Out 3 / 1
Component In / Out - / -
HDMI In / Out 5+1 / 1
Multi-Room Video Out: Video / HDMI - / -
AUDIO
Analog In / Out 3 / -
Phono (MM) In o
Digital In: Optical / Coaxial 1 / 1
Multi-Room Out: Analog / Digital - / -
Multichannel Pre Out o (2.2)
Subwoofer Out 2
7.1 Multichannel Input -
OTHER
Speaker Terminal: Gold Plated Screw / Regular Screw - / o
Number of Speaker Terminals 5
Speaker A / B -
Bi-Amp Drive -
Multi-Room Speaker Terminal -
Front Inputs: Audio / Composite / Digital (Opt) / HDMI / USB - / - / - / o / o
USB Audio / Made for iPod / Made for iPhone o / - / -
AM/FM Tuner o
Number of Poweramps 5
Power Output (8 ohm, 20 Hz - 20 kHz, 0.08% 2ch Drive) 50 W
Power Output (8 ohm, 20 Hz - 20 kHz, 0.05% 2ch Drive) -
Power Output (6 ohm, 1 kHz, 0.7% 2ch Drive) 60 W
Power Output (6 ohm, 1 kHz, 10% 1ch Drive) 100 W
70% Guarantee -
General
Metal Front Panel -
System Remote Control RC040SR
Pre-Programmed / Learnable / LCD Display - / - / -
Power Consumption in W 180
Power Consumption No-Sound (ECO on / off) in W 25 W / 35 W
Standby Consumption in W 0.2
CEC Standby Consumption in W 0.5
Network Standby Consumption in W 2.7
Network Control On Consumption in W -
Maximum Dimensions
Antenna:Horizontal:(W x D x H) in inches
Antenna:Vertical :(W x D x H) in inches
W/o Antenna:(W x D x H) in inches 17.3 x 14.8 x 4.1
17.3 x 14.8 x 6.8
17.3 x 14.5 x 4.1
Weight in lbs 18.1
          Marantz NR1509 Slim 5.2Ch Network Av Receiver Es_615
Number of posts : 557
