B&W bookshelf speaker
Condition:. SOLD
[/size]
D M6 0 2
Sta nd- mount/Bookshelf loudspeaker system
Product Summary
● The DM 602 is twice the size of the small DM 601 and incorporates the larger 180mm,
(7-inch) Kevlar mid/bass unit. The Kevlar cone is modelled on the cone in the Silver
Signature loudspeaker - a proven design that eliminates the build-up of standing waves for
a more authentic reproduction of recorded sound.
● As well as the 600 Series standard features the DM 602 also boasts flared reflex ports
which dramatically increase bass efficiency and power handling. Added to this is rounded-
profile zinc clamping rings which connect the drivers to the cabinet and minimise the effect
of diffraction around the drive unit as sound waves travel out across the face of the speaker
cabinet.
● The DM 602 is recommended for shelf or stand mounted applications and is ideally suited
as front channel speakers in a Home Cinema system.
D e s c r i p t i o n
Drive units : 2 way vented-box system
1 x 25mm metal dome - high fre q u e n c y
1 x 180mm Kevlarcone -b a s s / m i d r a n g e
F requency res p o n s e : 52Hz – 20kHz ± 3dB on re f e rence axis
S e n s i t i v i t y : 90dB spl(2.83V 1m)
Nominal impedance : 8 ohms (minimum 4.3 ohms)
Power handling : 25W –120W into 8 ohms on
unclipped pro g r a m m e
D i m e n s i o n s : Height: 490mm Width: 236mm
Depth: 306mm
F i n i s h e s : Black Ash vinyl
Grille: Black Cloth
- Number of posts : 2967
» DLS R-60 BookShelf Speaker (USED)
» Atohm GT1 Special Edition Bookshelf Speaker (Second Hand) with a pair of Atohm Zef Mini Speaker Cable (FOC)
» Bookshelf Speaker
» JPW ML-510 Bookshelf Speaker (Used)
» DLS - R60 Bookshelf Speaker (Used)
» Bookshelf Speaker
