Roksan Caspian M Series-1 Pre and Power Amplifier
Post by pleong on Wed Sep 26, 2018 5:07 pm
This is one of my favorite amp that I felt  sad to have to let go off as I needed some space for my room and for my upgrade finance.
The Roksan Caspian M-1 is very transparent , clean , very clear and it does all the things I did expect from a British integrated and infact also better than I have expected. Things like pace, drive, and flow are all in.  Soundstage and Imaging was very good with a very stable center image. Width and depth were exceptional, and it allows you to experience an exceptional vertical soundstage;
The Bass goes down really deep and it was full of breath and air. I found the bass very musical, and with real slam and impact.
Caspian M series-1  Pre Amp Spec
Line Inputs: 5 plus Tape
Input Impedance :47 kΩ
Line Outputs :Tape, Preamplifier (x3)
Power Supply: 350VA Ultra Low Noise Toroidal Transformer
                        10 Regulated Supply Rails
Frequency response: -3dB, <0.5Hz – 110kHz
Gain: 9.3dB Preamplifier
Harmonic Distortion: <0.0015% 1kHz, <0.009% 20kHz
Signal to Noise Ratio: Line 108dBa (ref. 500mV)
Power Source : 220V – 240V 50Hz / 60Hz
Power Consumption :< 230 W
Dimension :432 x 330 x 70 (W x D x H) mm
                   432 x 330 x 80 (including feet)
Weight 12 Kg
Caspian M series-1 Power Amplifier Spec
Input Impedance: 38 kΩ
Input Sensitivity: 700mV RMS
Signal Inputs: Left & Right channels
Signal Outputs: Chain Output L & R Channels
Power Outputs: Loudspeaker, L & R
Output Power:> 85 Watts continuous, into 8ohm; both channels driven; 120 Watts continuous, into 4ohm; both channels driven
Power Supply: 330VA Ultra Low Noise Toroidal Transformer
Current Output: 50 Amps Peak to Peak
Damping Factor: & gt; 140 (8ohm)
Frequency response: -3dB, <1Hz -> 100kHz
Gain: 30.7dB
Harmonic Distortion: <0.003% 1 kHz - 8 ohm <0.003% 1 kHz - 4 ohm Signal to Noise Ratio:>          116dB (ref 70W, 8ohm)
Dimension: 432 x 330 x 70 (W x D x H) mm 432 x 330 x 85 (including feet)
Weigth: 10 Kg a
 http://www.stylelaser.com.my/category/roksan/
(only COD in PJ SS2 area)
Price : only RM 5,500 , negotiable.
Phone: whatApp me at 0123889665
THANK YOU
Last edited by pleong on Wed Feb 20, 2019 3:58 pm; edited 3 times in total (Reason for editing : price changed)
pleong
Club Member
Club Member
Number of posts : 32
Registration date : 2018-01-29
Re: Roksan Caspian M Series-1 Pre and Power Amplifier
Post by pleong on Wed Oct 10, 2018 9:34 am
ok
pleong
Club Member
Club Member
Post by pleong on Thu Oct 25, 2018 8:38 am
ok
pleong
Club Member
Club Member
Post by pleong on Thu Jan 24, 2019 8:50 am
pleong
Club Member
Club Member
