technical question regarding speakers & xovers
Page 1 of 1 • Share •
hi guys, can i use 8 ohm xovers on 6 ohm speakers? vice versa, tqs.
azri- Frequent Contributor
Number of posts: 1029
Registration date: 2009-01-21
Re: technical question regarding speakers & xovers
not recommended as the X-over components' values are selected based on the woofer's own impedance load.
X-overs are only effective for the woofers/tweeters they are designed for.
If u swap the woofers/tweeters, then the rollover freqs and highpass/lowpass attenuations will lari.
If u got access to PSPICE or some other circuit emulation software, u can test this out for yourself before attempting a real-world SNAFU.
Number of posts: 2667
Registration date: 2009-04-04
i dont have such eq. tqs 4 the advise. anyways, when there are 2 sets speaker terminals on amp (A & B), & with speakers that are bi-wireable, is it possible to use both output like A for high freq & B for LOw freq?
what r u trying to achieve here ?
sounds more like biwiring to me.
biamping means using two amps - preamp must have two sets of outputs connected to two power amps which are then connected to the speakers.
with an amp that has two sets of speaker outputs (speaker a and speaker b) it is perfectly ok to use two pairs of cables to connect them to the bass and tweeter terminals of the biwireable speakers. just switch the speaker a and b buttons on.
remember to remove the jumpers from the speaker terminals.
Similar topics» transfer T.A. of Technical Resignation
» Fishing question
» I have a question about MAP and graphic.
» Stocking question
» Dumbs question.
» Fishing question
» Stocking question
» Dumbs question.
» Malaysia - Negeri Sembilan Audiophiles Group
» Integrated Amplifier - The One To Rule Them All!
» WTB: Telefunken ECC82/83 Tubes
» Suggestion/Queries for this Forum
» EPOS14 [ cracked sound]
» AudioNote P2 SE (used)
» Sonographe SC26 preamplifier (Used)
» Marantz CD63SE CD Player
» Audio-Technica ATH-EP700 Instrument Monitoring Headphone (New)
