Auralex Subdude Subwoofer Platform
Post by kk_key on Fri Oct 19, 2018 10:00 pm
Kills unwanted secondary resonance from your subs.
Auralex's SubDude is a 15" x 15" x 2.5" platform wrapped with ozite to fit any room setting. Its purpose is to prevent sound from transmitting through your subwoofer to surrounding surfaces and screwing up your mix.
Subwoofers create big vibrations (low frequencies) that you can feel in the floor and in objects placed nearby. When the source of the vibrations is coupled directly to the floor it causes these objects to vibrate or
resonate “ not only at the fundamental pitch the source is creating but also at harmonic frequencies that discolor the true sound from the source. When you have two (or more) objects vibrating, it creates an acoustical problem called ?secondary resonance?.
The SubDude was created to kill that noise. It effectively reduces secondary resonance by decoupling your subwoofer from the floor so you hear your sub and not the vibration of the other objects in your listening environment.
When speakers are tested in anechoic chambers, they are isolated from objects around them that could introduce resonance. With the SubDude, you can recreate a similar scenario in your living room, studio, garage, or wherever you want to record.
Dramatically reduces structural vibrations through walls, floors & ceilings
Preserves the accuracy of the original audio track
Tightens bass and increases low-end clarity
Item           : 1 x Auralex Subdude Subwoofer Platform
Dimension   : 15" x 15" x 2.5"
Condition    : 8.5/10 (in excellent condition)
Price           : RM220
Contact       : 012-211-1470
avatar
kk_key
Number of posts : 102
Registration date : 2009-05-27
Re: Auralex Subdude Subwoofer Platform
Post by kk_key on Sat Oct 27, 2018 3:07 pm
Basketball
avatar
kk_key
Post by kk_key on Sun Nov 04, 2018 12:29 pm
bounce
avatar
kk_key
Post by kk_key on Tue Nov 20, 2018 10:13 am
bounce
avatar
kk_key
Post by kk_key on Sun Dec 02, 2018 4:27 pm
Basketball
avatar
kk_key
Post by kk_key on Sat Dec 29, 2018 11:03 am
bounce
avatar
kk_key
